FD Castle Speedo Ring Failure - BMW Luxury Touring Community
post #1 of 7 Old Nov 23rd, 2013, 2:44 pm Thread Starter
Enjoy The Ride
saddleman's Avatar
I thought I would post a few pic's of a 1999 LT FD that the castle speedo ring came off & got beat up pretty good. I have been able to repair them before without removing the tapered bearing but not this one.
The ring was deformed & three of the tabs were bent. one of the tabs was out .043". The rings are unavailable so I got it straight within .001" & I'll have to get a little creative to make sure it does not come off again.
This FD also had the pinion needle bearing race that had moved into the FD housing.
Name:	Christian Hugener 005.JPG
ID:	45225   Click image for larger version
Name:	Christian Hugener 004.JPG
ID:	45233   Click image for larger version
Name:	Christian Hugener 003.JPG
ID:	45241   Click image for larger version
Name:	Christian Hugener 009.JPG
Dave Selvig
2004 Black LT
2000 Canon Red LT
saddleman is offline
post #2 of 7 Old Nov 23rd, 2013, 3:42 pm
Re: FD Castle Speedo Ring Failure
Wow that was beat up pretty good. I have one from my CCR demo drive if you ever need one.
post #3 of 7 Old Nov 23rd, 2013, 3:58 pm Thread Starter
Enjoy The Ride
saddleman's Avatar
Any idea why the pic's are so big ?.
Dave Selvig
2004 Black LT
2000 Canon Red LT
post #4 of 7 Old Nov 23rd, 2013, 4:21 pm
mycamel's Avatar
Hijack: look at the pockets in the background of the 1st photo. wonderful
ok
end jack
Mike Hammel (My Camel) [WB9GMO/4]
2002 K1200LT-E
1998 ACE Burgundy (now 'retired')
1998 ACE Yellow/Black Tourer (now 'retired')
19?? Suzuki 500 (now 'retired')
1962 modifed 49cc>~55cc Sears MoPed (LONG 'retired')
US Army Security Agency 0582L68 ('64-68)
moderator and owner:
Retired from the business world (finally--sigh --poor and proud)
Georgia Patriot Guard Riders
Roswell, GA
mycamel is offline
post #5 of 7 Old Nov 24th, 2013, 7:41 pm Thread Starter
Enjoy The Ride
saddleman's Avatar
I cured the 620 Locktite at 65 degrees fahrenheit for 24 hours while still in the press & now the parts will cure for another 24 hours at 160 degrees fahrenheit in a oven.
Name:	Knee Pockets 008.JPG
Dave Selvig
2004 Black LT
2000 Canon Red LT
post #6 of 7 Old Nov 25th, 2013, 5:35 am
CharlieVT's Avatar
Hi Dave,
I'm curious, did the pinion bearing race wear through the housing? Do you think the "creeping" race was it the cause of the speedo sending ring being displaced? Or were they two unrelated events?
I've seen examples where the creeping race traveled far enough to actually rub on the speedo ring and cause it to be displaced. If the displacement of the speedo ring wasn't caused by the creeping pinion bearing, I wonder what caused it to come loose. Any ideas?
10 degrees F here this AM plus windy. Cool.
Happy Thanksgiving
CharlieVT is online now
post #7 of 7 Old Nov 25th, 2013, 7:05 am Thread Starter
Enjoy The Ride
saddleman's Avatar
Hi Curtis, The two are unrelated. I've had two other speedo rings that were loose but they had not come off. I was able to Loctite them on without removing the taper bearing.
I'm not sure what causes the ring to come loose other than there is not very much area for a press fit. I have no way I can measure how much press fit it had because the ring was out of round.
Dave Selvig
2004 Black LT
2000 Canon Red LT
Poll...How many folks have had final drive problems missusfinz RT Series 126 Aug 16th, 2015 7:59 pm
What are the suspected reasons for final drive failures av8trto K1200LT 49 May 31st, 2012 7:02 pm
00 Speedo jerky, Sensor Ring loose jello4 K1200LT 16 Oct 1st, 2010 11:14 am
Final Drive Failures at 4% rate? hallzee K1200LT 27 Nov 24th, 2007 3:49 pm
Speedo failure 1st bustedknuckles K1200LT 6 Feb 15th, 2007 8:17 pm
