Knob For Adjusting Rear Shock Doesn't - BMW Luxury Touring Community
post #1 of 6 Old Sep 20th, 2013, 2:46 pm Thread Starter
Aufgeblassen's Avatar
I just recently bought a Y2K K 1200 LT, and the knob under the seat for adjusting the rear shocks does not turn either way after pivoting it up. Should I force it with channel lock pliers? If not, what can I do???
Aufgeblassen is offline
post #2 of 6 Old Sep 20th, 2013, 2:57 pm
vernvernvern's Avatar
Talking Re: Knob For Adjusting Rear Shock Doesn't
YEP. It's been turned against the stop fot to long. It'll come loose. Make sure you're turning it the right way. Right goes down, left comes up.
I never turn the adjuster completely in either direction. Never had a problem.
78 years young!
Converted HD rider.
Vern
vernvernvern is offline
post #3 of 6 Old Sep 20th, 2013, 5:47 pm
Scouter-50's Avatar
There are indicator lines showing how much preload. If you see no lines on the body then turn the knob counter clockwise. Pad the knob with a rag before Channellocks. Then add oil to the adjuster.
Robert
2000 K1200LT "Latifah"
1994 R1100RSL (wife's)
1981 R80GS
1976 R90S
2011 Bunkhouse Queen
Scouter-50 is offline
post #4 of 6 Old Sep 20th, 2013, 7:14 pm
Do not force it. The knob is plastic and the preload adjuster is a steel hex. You will shear the plastic hex on the bottom of the knob if you force it. The correct way is to remove the little screw on top of the knob, and carefully pull it off the adjuster body. There is an indent in the adjuster body with a spring and a small steel ball. It will eject when you slide off the knob, so pull a plastic bag over the entire assembly or take some other precaution not to loose the little ball. The adjuster can then be loosened with a wrench before you replace the knob.
André Strydom
BMW MOA #140995
Acts 4:12
andres is offline
post #5 of 6 Old Sep 20th, 2013, 8:59 pm
Andres, that is a great tip!
Where is the "like" button?
wardenross is offline
post #6 of 6 Old Sep 21st, 2013, 9:47 am
Aufgeblassen - Ric - no way, I saw "aufgeblassen" and I knew right off. So you got a 1200lt also? I bought a 2001 in the spring, came here. learned all the failure points, and then went completely through the bike. One warning, it's not a voyager, very high tech compared to the voyager.
As far as the shock preload adjuster, let me just put it this way - setting preload isn't going to be enough. we're both big guys; this bike will drag parts with stock springs easily. I did the hyperpro springs front and rear, and it's a HUGE improvement. Good luck! Steve
Steve_in_Sunny_Fla is offline
Rear Shock Questions Mike_H K1200LT 12 Feb 26th, 2013 8:24 am
shock removal question tnk12lt K1200LT 8 Dec 21st, 2008 10:32 am
OEM rear shock rattler50 Shocks and Suspension 1 May 19th, 2008 11:04 pm
Rear Shock Question Cycle_guy K1200LT 4 Jun 30th, 2006 8:04 pm
