Aftermarket cruise control recommendations - BMW Luxury Touring Community
post #1 of 17 Old Sep 20th, 2013, 12:31 am Thread Starter
I was the proud owner of 2 previously owned 2005 LTs but divorce and no time to ride forced the sale of both over a 5 year period. Now I have more time (and the bug) to renew my relationship with yet another.
Recently, I found a very low mileage 2005 LT from an original owner but found that this one was purchased in Germany. I'm told that this was supposedly sold as a US spec bike but did not come with the cruise control option (verified by my test drive).
Anybody have a suggestion for an aftermarket cruise control?
Thanks, Joe
videojoe is offline
post #2 of 17 Old Sep 20th, 2013, 1:54 am
Dragonwing's Avatar
Re: Aftermarket cruise control recommendations
Since your bike most likely is not equipped with the logic circuits that tie in the throttle with the brakes, brake lights, clutch, vacuum and speed sensor, the addition of a retro-fitted electronic cruise (even if available--see mccruise.com) would constitute a wiring and wallet nightmare. I'm thinking that you're going to be limited to the mechanical (and significantly less costly) alternatives from VisraCruise or Throttlemeister. Both are good units. I've found the Throttlemeister to be the more stylish of the two. Then, of course, there's always the $10 Cramp Buster......
DW
"A severed foot is the ultimate stocking stuffer."
BMW K1200LT "Carpathia"
Suzuki GV1400 Cavalcade "Paladin"
Kawasaki ZX14 Ninja "Shashka"
Kawasaki GPz1100 "Sicarius"
Buell S3 "Pazuzu"
Honda GL1100 Gold Wing "Aurore"
Honda PC800 Pacific Coast "Octavia"
Honda CB750F "Genvieve"
And other remnants of a misspent youth.
Dragonwing is offline
post #3 of 17 Old Sep 20th, 2013, 7:51 am
timgray's Avatar
I've had throttlemeisters on all om older bikes and they are fantastic.
timgray is offline
post #4 of 17 Old Sep 20th, 2013, 8:08 am
FatStrat's Avatar
This unit is popular with FJR and Valkyrie riders...
http://www.valkyrieriders.com/shopta...se-control.htm
Friends know the song in your heart, and can sing it to you when you have forgotten the words.
FatStrat is offline
post #5 of 17 Old Sep 20th, 2013, 8:34 am
VoIPwizard's Avatar
Here is a complete write up of one of the Chromeheads gurus (Pencin) installing a Rostra CC in his R1200C.
Rostra Cruise Control
Link to the Cruise Control thread @ chromeheads.org
You are going to have a lot of fun
Good luck!
2009 R1200RT
Past Rides: 2003 K1200LT "Gertrude" (sold) / 2004 R1200CLC "Petunia" (sold) 2005 Kawi Concours (gone)
VoIPwizard is offline
post #6 of 17 Old Sep 20th, 2013, 8:39 am
Dragonwing's Avatar
Strat: Maybe so, but (1) they are carburetted engines, and (2) look at all the extra parts and fabrication that's required. I'd foresee a boatload of 'issues' developing with the attempted insrallation of that on the LT.
DW
Buell S3 "Pazuzu"
post #7 of 17 Old Sep 20th, 2013, 8:44 am
Dragonwing's Avatar
Good luck!
Big, bold letters, right on the main page: Not recommended for MC use. And NO tech support if you do it, anyway. Why take the chance?
DW
Buell S3 "Pazuzu"
post #8 of 17 Old Sep 20th, 2013, 8:44 am
VoIPwizard's Avatar
I respectfully differ. The R1200C/CL are fuel injected. Yes, a lot of fiddling to get that installed.
The Throttlemeister is definitely the easiest way to go in this case.
But the point is to show that is complicated but possible.
2009 R1200RT
post #9 of 17 Old Sep 20th, 2013, 9:17 am
Dragonwing's Avatar
VoIP: My reply was to Strat and his VTX/FJR recommendations. You snuck in your post while I was composing my reply to him.
DW
Buell S3 "Pazuzu"
post #10 of 17 Old Sep 20th, 2013, 9:18 am
VoIPwizard's Avatar
Yes Sir, you are right and I did not read...
2009 R1200RT
post #11 of 17 Old Sep 20th, 2013, 11:08 am
Dragonwing's Avatar
Been there, too......
DW
Buell S3 "Pazuzu"
post #12 of 17 Old Sep 20th, 2013, 11:11 am
Typically wiring harnesses are designed and built to accommodate all options, and I'd be surprised if your bike doesn't already have the wiring and the connectors for the cruise control. There may be an additional dedicated sub-harness that is needed, but it should be possible to retrofit cruise control depending on the amount you want to spend. You'll probably need new handlebar controls both left and right, and then the modulator on the throttle bodies and the control unit. I haven't looked at the wiring diagram yet and I don't pretend to know exactly what's required, but it does seem to be an interesting exercise!
André Strydom
BMW MOA #140995
Acts 4:12
andres is offline
post #13 of 17 Old Sep 20th, 2013, 12:54 pm
Far cheaper to buy an LT with factory cruise. But if you are a glutton for punishment, have at it!
post #14 of 17 Old Sep 20th, 2013, 1:03 pm
FatStrat's Avatar
I hear you. It would be nice if someone had already done this on an LT and documented it. I'm sure it can be done. Just a matter of someone taking the time to fabricate and apply it.
Before I sold my FJR I was a member of a few of the forums catering to FJR's. A fellow member worked out a process to install the Audiovox unit on an FJR and publicized it on one of the forums. With some tweeks and suggestions from other members, an accepted install method was formed. Many people bought in. One of my bestest running buddies did the mod. Worked flawlessly. The only drawback that I could see was the sizable vacuum chamber (servo) that resided above the left passenger peg for all the world to see. Other than that...it was cruise control!
FJR's are fuel injected. Throttle bodies...carbs... whatever... are all actuated by hard linkage that controls all units simultaneously. This common linkage has a cam with a cable(s) attached to it from the hand grip throttle control. This is where the ball chain from the servo attaches. The servo doesn't care what's down stream of the linkage cable cam...carb or throttle bodies. The end result is the same in either case. When the servo ball chain pulls or releases, the throttle plates open and close changing the( fuel)/ air volume entering the intake respectively..
FatStrat is offline
post #15 of 17 Old Sep 20th, 2013, 1:36 pm
STEBS's Avatar
We put one on a k100rs and it worked great, at the time the audiovox cruise was about $100, I see them on amazon for $185, fairly easy install on the older K engines.
2015 R1200Rt- Ebony
2005 K1200Lt- Dark Graphite
1978 KZ1000 Ltd- Black
St Clair Shores, Mi
BMWMOA # 185482
STEBS is offline
post #16 of 17 Old Sep 20th, 2013, 6:56 pm
azccj's Avatar
+1 on that. There are plenty of K1200LTs in the US for sale. I would get one that already has cruise control, (one of my favorite features on the LT) instead of trying to rig something up.
Current Bikes
2013 Triumph Trophy SE
2013 Suzuki Burgman 650, Ya it's a scooter but it will do over 100 MPH
2005 BMW K1200LT
2004 BMW R1150RT
1972 Moto Guzzi Eldorado
azccj is offline
post #17 of 17 Old Sep 21st, 2013, 10:15 pm
giarcg's Avatar
I installed a Rostra on my FJR and documented it in FJR forum. It would be my choice for any aftermarket installation.... Works great.
An LT without cruise.... Brrrrrrrrr!
giarcg is offline
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Busa33
Electronic Cruise Control - R1150RT LaChuparosa RT Series 9 Dec 29th, 2012 4:08 pm
Cruise Control OD with new cables. airborneod K1200LT 24 Jun 14th, 2011 7:42 am
MCCruise.com electronic cruise control installed Randy GS Series 16 Jun 22nd, 2007 10:04 am
Section speed trap in The Netherlands vvk Europe 4 Apr 18th, 2006 4:40 am
Speed traps in The Netherlands vvk Chit Chat 0 Oct 24th, 2005 10:38 am
