rear vibration - BMW Luxury Touring Community
post #1 of 11 Old Sep 18th, 2013, 9:46 pm Thread Starter
rear vibration
Need help with my 05 LT.When riding straight I have a vibration that goes away when cornering.It doesn't change when powering or coasting only when in a lean.Is this a pending final drive failure? Bike has 42000 miles on it.When spinning wheel on center stand seems to roll smooth.
zebber is offline
post #2 of 11 Old Sep 18th, 2013, 10:52 pm
Super Moderator
dfinazzo's Avatar
Re: rear vibration
What make tires . . . and how many miles on them!
Typically vibrations are due to tires . . .
Dan Finazzo
dfinazzo is offline
post #3 of 11 Old Sep 19th, 2013, 7:55 pm
Re: rear vibration
I vote an ME 880 with about 4,200 miles on it. But then they normally get noisier when you lean not the other way around...
Any side to side play in the rear wheel?
post #4 of 11 Old Sep 19th, 2013, 8:36 pm
timgray's Avatar
Re: rear vibration
If it's cupped it will vibrate in the middle but not on the sides where it's barely used.
what air pressure is the tire kept at? I have heard pressures as high as 46 psi are needed to keep the rear tire from cupping.
timgray is offline
post #5 of 11 Old Sep 20th, 2013, 1:47 am
deanwoolsey's Avatar
Re: rear vibration
It's probably a bad tire. If the bumping correlates with each revolution of the tire, it's a bad tire. Just because it looks round doesn't mean it'll feel round when riding. There's about seven or eight things that'll make it go "bump" and still look round when you inspect it. You probably have a wide belt splice. Safe to ride, annoying as hell.
deanwoolsey is offline
post #6 of 11 Old Sep 20th, 2013, 2:11 am
mwnahas's Avatar
Re: rear vibration
first check the tires. Keep tires at
42 psi front
48 psi rear
That will delay but won't reverse the issue.
Get new tires or turn up the radio.
Just Go
Cleveland Ohio
mwnahas is offline
post #7 of 11 Old Sep 21st, 2013, 12:29 pm Thread Starter
Re: rear vibration
Shouldn't be the tire, it's brand new. It's more like a buzz I guess. I thought it was the speed sensor rubbing the slots in the rotor but I can't feel anything by spinning the wheel on the centerstand. It only does it when the bike is straight up, in a lean to either side it stops.It sure sounds like it's in the rear drive.It kinda makes me nervous,my wife and grandkids go on a lot of rides with me. I have only had the bike since March and rode it home from South Carolina when I bought it and just started noticing the vibration on a trip to Kentucky in late July. I did replace the rear rotor about that same time with a EBC rotor. Could that be the problem?
zebber is offline
post #8 of 11 Old Sep 21st, 2013, 2:51 pm
Re: rear vibration
Well there is nothing in the rear drive (when it is going south) that will get quieter in a lean so I think you are OK there. Also when the drive goes it goes pretty fast on a big bearing failure. Make sure the tire is not rubbing on the swing arm. Also which tire did you just install? There are only three out there that are correct for the LT rear.
post #9 of 11 Old Sep 21st, 2013, 5:05 pm
timgray's Avatar
Re: rear vibration
A tire can get cupped in under 300 miles if you ran too low of pressure. I cupped a set of brand new tires on a car within 100 miles because the dealership set the tires at 30 psi instead of the 42psi that they are supposed to be at.
timgray is offline
post #10 of 11 Old Sep 22nd, 2013, 6:54 pm
casualemt's Avatar
Re: rear vibration
Check your lug nuts
RICH CANNON
2000 K1200LT "a great ride"
1979 XS1100 (gone)
1986 VT500 Ascot (gone)
1972 Honda 500-4 (gone)
1961 Lambretta (way gone)
casualemt is offline
post #11 of 11 Old Sep 22nd, 2013, 8:39 pm Thread Starter
Re: rear vibration
I put a Metzler ME880 back on it.I took a ride on it today and the same thing ,a buzzing type of vibration when straight up and goes away in a lean. Next weekend I'll year into it to see what I can find. Thanks for all of the help.
zebber is offline
Another Rear Drive Bites the Dust - Question lad K1200LT 63 Jul 19th, 2013 1:34 pm
Can I make it home with oil on the rear wheel av8trto K1200LT 23 Jun 25th, 2011 1:54 pm
Thought I had blew by rear drive slmorley K1200LT 2 Oct 29th, 2010 11:51 am
Rear end vibration StLHeadake K1200LT 0 Apr 16th, 2007 1:39 pm
Linked brakes negative bmwrubbercow K1200LT 19 Aug 4th, 2006 4:00 am
