Pre-load Hose Replacement - BMW Luxury Touring Community
post #1 of 3 Old Sep 17th, 2013, 11:07 am Thread Starter
Has anyone had to replace the hose that goes from the pre-load adjustment knob to the shock absorber? Mine is cracked and I'm wondering if it is the same size as a brake line. If so, I'm considering going with a stainless replacement. Any thoughts?
sdm1174 is offline
post #2 of 3 Old Sep 18th, 2013, 11:39 am
wa1200lt's Avatar
Re: Pre-load Hose Replacement
There are companies that make up hydraulic hoses. They are generally for agricultural clients but they can make anything you need. I used one once, 250 miles from home, to make a pair of tilt hoses for the outdrive on my boat. Quick, cheap, and still effective 12 years later.
Look up hydraulic hoses in the "yellow pages". There should be several companies in the PHX area.
Loren
WAK1200LT
Loren
wa1200lt is offline
post #3 of 3 Old Sep 19th, 2013, 12:00 am Thread Starter
Ok, I'll look into it. Also, is there a process to bleed the air out of the new line? I know how to do the refill on the knob.
sdm1174 is offline
Brake hose in control circuit kend52 K1200LT 6 Jun 16th, 2013 7:49 pm
Fuel Filter Replacement and the Rotten Hoses. azccj K1200LT 11 Jun 6th, 2013 10:32 pm
Brake hose replacement procedure ? mkiesel K1200LT 9 Aug 23rd, 2012 8:57 am
Brake hose to brake master cylinder replacement pauleknight K1200LT 12 Nov 25th, 2011 8:24 pm
Brake Hose Replacement tonyn1 K1200LT 19 Apr 29th, 2010 11:34 am
