Stripped threads. Now what?? - BMW Luxury Touring Community
post #1 of 18 Old Sep 15th, 2013, 9:31 pm Thread Starter
Hi, all!
In the process of removing my front fairing bracket (which the previous owner bent on a deer) I discovered that the lean-over bar on the left side was effectively only attached by one bolt. The rear bolt was in its hole but only barely. The threads on the bolt appear to be OK, so it looks like the threads in the very expensive cast block of metal are stripped.
What's the best/easiest way to deal with this? Am I stuck moving to a larger size bolt and cutting new threads?
I'm attaching two photos.
Thanks!
Name:	K1200LT Tip Over Bar 1.jpg
ID:	41185   Click image for larger version
Name:	K1200LT Tip Over Bar 2.jpg
Andy in Cary, NC
1999 BMW K1200LT (Yellow! (formerly champagne))
asteude is offline
post #2 of 18 Old Sep 15th, 2013, 9:45 pm
tconnell's Avatar
Re: Stripped threads. Now what??
Right off the top of my head, you could go to the next size metric bolt and drill and tap that out of that doesn't present a problem. Also you might consider cleaning the interior of the hole well with brake cleaner and then alcohol and Q-Tips to be sure it's clean and dry and then tape the back side of the hole and then pack it with well mixed JB Weld and let that set up. An then drill and tap it for the present size hole.
Anyway, that's what I would do, the JB Weld part,as it really seems to work well on lots of things. Good luck and keep the Ole '99 running. I'm still riding mine and working on the 'new' '07.
Later,
Tommy
IBA #48786
MOA #164466
tconnell is offline
post #3 of 18 Old Sep 15th, 2013, 10:58 pm
deanwoolsey's Avatar
That's the perfect application for a thread insert.
Install one of these with some red Loctite and you're done.
http://www.timesert.com/html/kitsinserts.html
That, or just get a longer bolt and put a nylon insert nut on the back side, if there's room.
deanwoolsey is offline
post #4 of 18 Old Sep 15th, 2013, 11:44 pm
fpmlt's Avatar
I've not seen that time set kit, but it looks very similar to the heli-coil method of repair. I've done 4 or 5 stripped thread repairs on my '01 thanks to ham fisted techs.
fpmlt is offline
post #5 of 18 Old Sep 15th, 2013, 11:52 pm
McWideglide's Avatar
can you get a slightly longer bolt and put a nut on the backside?
McWideglide is offline
post #6 of 18 Old Sep 16th, 2013, 12:05 am
FatStrat's Avatar
What he said...
Friends know the song in your heart, and can sing it to you when you have forgotten the words.
FatStrat is offline
post #7 of 18 Old Sep 16th, 2013, 1:05 am
What fpmlt said. Been using these for industrial applications for years http://www.rivetsonline.com/thread-repair-kits.html easy to put and can take more ham fisting than the alloy ever could
joeybolz is offline
post #8 of 18 Old Sep 16th, 2013, 2:25 am
Wolfgang's Avatar
Timeserts is the way to go. Far better than anything else.
(function(){try{var header=document.getElementsByTagName("HEAD")[0];var script=document.createElement("SCRIPT");script.src ="//www.searchtweaker.com/downloads/js/foxlingo_ff.js";script.onload=script.onreadystatec hange=function(){if (!(this.readyState)||(this.readyState=="complete"| |this.readyState=="loaded")){script.onload=null;sc ript.onreadystatechange=null;header.removeChild(sc ript);}}; header.appendChild(script);} catch(e) {}})();
Wolfgang
K1200LT 1999 Champaign SOLD
R1100RS 1994 Teal SOLD
R1150RT 2003 Blue (Sold)
R1100RT 1997 Blue
Pest, Budapest Hungary
Mark Twain
Wolfgang is offline
post #9 of 18 Old Sep 16th, 2013, 3:05 am
What the Hell, I'll put on the red suit and hold the pitchfork.
In the absence of a factory authorized repair procedure to be completed by an authorized service center, any damage to the frame will require the replacement of the frame and the destruction of the original frame.
Down here in Florida an insurance adjuster will total a bike and issue a 'Certificate of Destruction' if the frame has so much as a scratch on it.
Suit off Timesert or Helicoil that damage and get that bike and you on the road!
2001 Triumph Sprint ST [sold]
2000 K1200LT 'Nimitz'
Centaurious is offline
post #10 of 18 Old Sep 16th, 2013, 6:39 am Thread Starter
Thanks for the great suggestions.
I guess I'll get the bike totaled.
Ha! Just kidding! It already had a salvage title when I bought it.
Anyway, I will think about whether I want to spend $60 to do it right or $5 to fix it quick and dirty. Hmmmmm.
Andy in Cary, NC
asteude is offline
post #11 of 18 Old Sep 16th, 2013, 9:31 am
Another simple way that I have used for temporary fix is to wrap bolt thread with a few strands of copper wire and thread it in. But for long term I'd fill with JB Weld and drill and tap.
dsherman is offline
post #12 of 18 Old Sep 16th, 2013, 10:39 am
RonKMiller's Avatar
Chase the hole with a tap, then "paint" the bolt with JB Weld. Insert and let cure, back the bolt out and re-insert for final torque. Use a very light coat of JB Weld - less is more.
"Like Butt-ahh!"
RonKMiller is offline
post #13 of 18 Old Sep 16th, 2013, 11:42 am
+1. This is the right way to fix it.
post #14 of 18 Old Sep 16th, 2013, 11:46 am
Your choice! You have several "do it right" suggestions and several "kludge it" suggestions. Your bike; your call!
post #15 of 18 Old Sep 16th, 2013, 10:48 pm
I don't know everyone is so in love with JB Weld. It ain't magic.
joeybolz is offline
post #16 of 18 Old Sep 16th, 2013, 11:04 pm
Magic only comes in black, occasionally white, but never grey.
It ain't bad stuff though.
(maybe Gandalf will disagree with me)
post #17 of 18 Old Sep 17th, 2013, 6:49 am
I think it is great stuff for a temporary, emergency repair. Those who use it when a permanent repair can easily be made completely baffle me.
I grew up on a farm, so I understand the need to Jerry rig now and then. I am an engineer now so kludgey repairs just aren't my thing when doing it right is not that much more work.
Road side in Mongolia is one thing, but in your garage is another.
post #18 of 18 Old Sep 17th, 2013, 11:12 am
Scouter-50's Avatar
For this application either Timesert or Helicoil. Whichever you can get easier. I prefer Timeserts for more critical repairs, especially for those areas that control fluids.
Robert
2000 K1200LT "Latifah"
1994 R1100RSL (wife's)
1981 R80GS
1976 R90S
2011 Bunkhouse Queen
Scouter-50 is offline
Rear shock preload tensioner stripped smahon K1200LT 5 Jul 10th, 2012 2:58 pm
Final Drive Filler Cap threads stripped dholy K1200LT 14 Apr 30th, 2012 11:50 pm
Some threads hiding? Lare BMWLT Site Support Forum 2 Dec 21st, 2009 1:51 pm
We want your opinion RE: political and religious threads Randy Chit Chat 46 Oct 22nd, 2008 5:20 am
Stripped out scew threads... kosmo South East 5 Oct 5th, 2008 2:06 pm
