k1200lt 1999 wont start - BMW Luxury Touring Community
post #1 of 6 Old Sep 14th, 2013, 5:10 am Thread Starter
Hi. Im new to this site and require help. I have a 1999 k1200lt and it turns over but won't start. I left it on its side stand for about 1 month then went to start it and wouldn't fire. I checked all spark plugs and all is good. Is it possibly my fuel filter? I also remember when bike was working as I turned key on a little buzz sound came on. Now it doesn't. Not sure what to do. Please help.
shartog is offline
post #2 of 6 Old Sep 14th, 2013, 7:29 am
Re: k1200lt 1999 wont start
Hi. Have you checked the battery? Very often they will not have the right charge especially after resting for a month!.
Start there.
motoman56 is offline
post #3 of 6 Old Sep 14th, 2013, 7:37 am
lesn's Avatar
No " buzz" may mean no fuel pump ?? It's the first thing you hear when you turn the ignition on.
lesn is offline
post #4 of 6 Old Sep 14th, 2013, 4:38 pm
Xsubmariner's Avatar
After a month of non use I'm going with dead battery. Our bikes use a small amount of battery power just sitting there. (clock, computer, etc...)
I'm editing the above typos as you read this.
1999 Basalt Grey
Xsubmariner is offline
post #5 of 6 Old Sep 14th, 2013, 9:09 pm
You can pull some of the Tupperware where the fuel pump is and there is an "always hot" connector there for an additional power outlet. This will fit and power the fuel pump to confirm operation. Often the connector gets dirty and you lose contact, just pulling it apart and re-inserting it will restore the connection.
If the pump is running and still no start you may have a ruptured fuel hose inside the tank.
post #6 of 6 Old Sep 20th, 2013, 7:30 pm Thread Starter
Thanks Team for your ideas. Tomorrow I will have a look at your suggestions and see what happens. I dont think its the battery because Its only new and I charged it up over night and still wont fire. Will definitely check the fuel pump and hoses.
Once again guys thank you. Will let you know the outcome.
shartog is offline
2009 K1200lt cranks, will not start luis993 K1200LT 5 Aug 4th, 2013 12:31 pm
K1200LT Won't Start Mswill0286 K1200LT 7 Apr 22nd, 2013 10:13 pm
K1200LT turns over but won't start PaulDickson_VA K1200LT 3 Mar 10th, 2013 9:53 pm
1999 K1200LT Died - need post mortom bmw4jrd K1200LT 12 Sep 6th, 2006 11:23 am
