High Pitched Whistle - BMW Luxury Touring Community
post #1 of 6 Old Sep 12th, 2013, 2:18 pm Thread Starter
Question High Pitched Whistle
On a recent long trip, my 2001 K1200LT started to emit a high pitched whistling sound (like someone actually blowing on a whistle). It seemed to happen only after a few hours riding and the bike/weather were hot. It eventually stopped but then did it again later in the day and again the next day. I can't tell if the sound is coming from the front or rear of the bike. It's not the brakes, I know that sound and how to stop it. I've checked the rear bearings and there is no wiggling. Any other ideas as to what may cause a sound like this?
Thanks for your thoughts.
TonyStanley is offline
post #2 of 6 Old Sep 12th, 2013, 9:00 pm
fpmlt's Avatar
Re: High Pitched Whistle
My best guess, and the first place I'd look, is the radiator cap. High pressure air blowing out, whistling.
My other guess would be toward the exhaust, but I sort'a doubt it.
fpmlt is offline
post #3 of 6 Old Sep 12th, 2013, 9:53 pm
The fuel pump can whistle when the filter is restricted. Open the fuel filler when you hear the whistle. If it is the pump, it should get louder
Ron
beets is offline
post #4 of 6 Old Sep 12th, 2013, 10:12 pm
Check the windshield screw covers, I've had similar things happen when some crosswind occurs.
2001 Triumph Sprint ST [sold]
2000 K1200LT 'Nimitz'
Centaurious is offline
post #5 of 6 Old Sep 13th, 2013, 9:25 am
thynk3r's Avatar
Fans. Same thing on my 02.
thynk3r is offline
post #6 of 6 Old Sep 13th, 2013, 9:16 pm
I had a similar problem a few years ago. Problem would come and go only when riding and it would go when I pulled over to investigate. Bottom line is that it turned out to be easily diagnosed over time because it got progressively worse. It was the fuel pump. During the repair I found I had silt in my tank, probably pumped in during a gas stop.
I was traveling at the time (1K from home) and I ordered the pump ahead to where I was heading and replaced the pump in a motel parking lot. I also bought a new fuel filter at the time so I didn't have to pull the tank again to replace it on the next maintenance schedule. I am glad I did since I also had to clean the bottom of the tank out. You can rinse out the nylon stick and stone filter very easily.
2001 Black LTC
2015 Blue R1200GSA
jackd is offline
High beam won't work 2wheeljunkie K1200LT 16 Nov 11th, 2008 2:29 am
HID lights in both high and low? parishollow K1200LT 6 Jul 19th, 2008 9:28 am
H7 High Beam? cjklemp Lighting 3 Jul 7th, 2008 10:25 pm
High idle moondog Other K-Bikes Discussion 4 Mar 25th, 2008 4:55 pm
High Beam / Low Beam Adjustment tomandmelanie K1200LT 3 Aug 4th, 2007 9:26 pm
