spongey rear brake - BMW Luxury Touring Community
post #1 of 5 Old Sep 12th, 2013, 7:53 am Thread Starter
spongey rear brake
My 2000 my LT has developed a rear break problem. Over the last couple of rides the rear brake has gone spongey. I have checked the reservoir , its over half full. checked for leaks , non to be found . There are no leaks on the master cylinder, the pistons on the caliper were checked and were free approx. 1500 miles ago and pads replaced. Does anyone have any idea what to check next. If I pump the brake and keep it under pressure overnight the brakes feel normal for a few rides.
Any help would be greatly appreciated
Thanks in advance
hovis is offline
post #2 of 5 Old Sep 12th, 2013, 8:35 am
dvgb131's Avatar
Re: spongey rear brake
Well, I gotta believe a caliper is a caliper. I just had these exact same symptoms with my Honda Ridgeline. Turns out the slider pins were locked up. Freed, cleaned and greased and spongy brake feeling is gone!
Easy to check.
HTH.
Doug B.
2000 LT purchased July 2013
dvgb131 is offline
post #3 of 5 Old Sep 12th, 2013, 11:22 am
GaryEm's Avatar
Did you ever replace the brake lines ;sometimes that can do strange things because they will look good on the outside but will collapse in the inside.
Gary
2003 K1200LT
GaryEm is offline
post #4 of 5 Old Sep 12th, 2013, 11:44 am
sounds like air but if the piston in the master cylinder not moving freely so that it does not return completely you can get the same feeling, stoke is reduced, need to get new master they do not sell parts for it
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
gary45 is offline
post #5 of 5 Old Sep 12th, 2013, 12:51 pm
Caliper is a hard mount on the LT the floating is done at the rotor so no slide pins. My bet is on 14 year old brake lines that are about to pop. Seriously the LT at that age is ready for a brake line failure. But check to make shure there is some free play in the foot pedal to push rod into the MC. That can cause a problem if there is none.
Brake Question jimdeluca RT Series 12 Jan 14th, 2013 11:22 pm
Rear Brake stopped working. NCCCC1 K1200LT 26 Oct 7th, 2012 10:19 pm
Lowering the rear brake pedal lemiller K1200LT 14 May 20th, 2012 11:34 am
Rear Brake Reservoir Hollywood K1200LT 10 Oct 20th, 2009 1:49 pm
Drilled rear brake rotor???? DRothermel K1200LT 10 Apr 7th, 2006 2:01 pm
