are Moto lights killing battery? - BMW Luxury Touring Community
post #1 of 9 Old Sep 9th, 2013, 9:38 am Thread Starter
TeddyTelco's Avatar
I just checked voltage on battery on idle 13.80v. Turned on motos and it dropped down to 13.18. The motos were installed by a PROFESSIONAL ?? by P.O. I am not sure what caused my pc680 Odyssey to die after 5 months I used a tender except one week when I was away without bike.Just wondering if any one with motos have had a problem... Thanks
2009 BMW K1200LT "Shelly"
2002 Honda VT1100 Sabre Sold
1979 Harley Davidson FXEF 1340 Sold
1975 Norton 850 Commando Sold
TeddyTelco is offline
post #2 of 9 Old Sep 9th, 2013, 11:05 am
Razmataz's Avatar
Re: are Moto lights killing battery?
I seriously doubt it. There's a lot of things that come on when that key is turned on, and you are still well above 13 volts.
BMW 1200 LTC 2002
Razmataz is offline
post #3 of 9 Old Sep 9th, 2013, 11:17 am
Old Slow Guy in A Fast Car
katnapinn's Avatar
I had Moto Lights on my LT & never had a problem. It could just be a bad Battery. I'll seen bad ones from time to time. A few years ago the local dealer got in a bad batch of batteries. They had 7 or 8 dead bikes before they found the problem was the 20 or so batteries they just got in from BMW.
Stevie Shreeve
katnapinn is offline
post #4 of 9 Old Sep 9th, 2013, 1:22 pm
Only if they are on when you have the bike parked.
Seriously anything above 12.7 will be charging the battery anyway. A functioning alternator supplies all the electrical loads on the bike and what ever is left over charges the battery.
post #5 of 9 Old Sep 9th, 2013, 1:44 pm
PMitchell's Avatar
If you are concerned about current draw, try these
http://dx.com/p/mr16-4w-4-led-6500k-...hite-12v-30208
They match the "color" of my HID as well.
Some where on this site there is a thread with photos that I took showing an "A"-"B" comparison.
pm
Ride till you can't!
"Der Weg ist das Ziel"
2006 Tuscany
2008
2011 South Africa
'18 R1200RTW
Sold in '67
PMitchell is offline
post #6 of 9 Old Sep 9th, 2013, 2:17 pm
deanwoolsey's Avatar
All of that and 13.2 is the "float" value for a fully charged battery. So no, it's not the auxiliary lamps.
deanwoolsey is offline
post #7 of 9 Old Sep 9th, 2013, 7:27 pm
timgray's Avatar
Motorcycles dont really charge the battery at idle. What is the voltage at 2000 rpm with them on and off?
And you want to see a power draw? measure the voltage at idle when the fans kick on.
timgray is offline
post #8 of 9 Old Sep 9th, 2013, 9:05 pm
james216's Avatar
Only problem I had with mine was. The right one was flickering on & off. Then didn't work at all. Figured out it was a broken wire in the jacket Pulled the light off the fork mount, cut the jacket back.Turned out who ever ran the wires pulled the wire ties to tight. It cut thru the ground wire. That's the only problem I've had.
2004 K1200LT. Big Mama
I'm a 4 percenter.
james216 is offline
post #9 of 9 Old Sep 9th, 2013, 11:55 pm
Super Moderator
dfinazzo's Avatar
I run with Motolights and bought the 4W single bulb MR16s from them here in CIncinnati.
I can tell you the 4W LEDs put out less light that the 35W halogen - but mine are there for
the triangle of light not necessarily more light to see by!! I also took out the switch and run
my all the time and with on 8W load in the battery I am fairly happy that any current draw is
very small.
Since you have been posting a lot about the Odyssey battery I would would get a top
quality charger and the Battery Tender brand in my opinion if ok but certainly not the top of
line charger. In fact I have had two battery tenders go bad and they replaced them except
for the shipping both ways on my part - more expensive than the tender. I now run an
Optimate and that unit is quality, quality, quality!! Check them out:
http://www.tecmate.com/
Dan Finazzo
dfinazzo is offline
TPS after battery change FuzzyWuzHe K1200LT 3 Sep 5th, 2012 7:16 pm
Charging the gel battery! gladiator99 K1200LT 4 Aug 24th, 2009 1:34 am
PIAA lights vs . . . (product review) Seattle Lighting 7 Jul 11th, 2009 2:13 pm
What keeps killing my battery markmoloney K1200LT 12 Oct 11th, 2008 6:09 am
Flat battery - no lights - no starter Ajlelectronics K1200LT 9 Aug 25th, 2008 2:00 pm
