Oil leaking from sump front weep hole. - BMW Luxury Touring Community
post #1 of 12 Old Sep 7th, 2013, 12:53 pm Thread Starter
I notice oil on the garage floor under my 2000 K1200LT (54000 miles) this morning after returning from a 50 mile round trip last night.
I'm not sure what the weep hole is for as the Clymer manual shows the water/oil pump seal weep hole on the left side of the pump so is it the the front crank seal. I don't want to pull the wrong things apart. Thanks for any suggestions.
gdb32 is offline
post #2 of 12 Old Sep 7th, 2013, 3:02 pm
Re: Oil leaking from sump front weep hole.
That is actually the vent for the oil pump seal. The oil/water pump assembly has the oil pump in the rear and that is a vent for it. It vents the "no mans" land between the oil side and the water side of the pump assy. If oil is coming out the oil side has failed. If water is coming out the water side has failed. I would just get a used combo from e-bay.
post #3 of 12 Old Sep 7th, 2013, 3:09 pm Thread Starter
Thank you John.
So if its the vent does that mean that the oil seal needs replacing and if that's the case should I do anything else while I'm in there?
gdb32 is offline
post #4 of 12 Old Sep 7th, 2013, 3:13 pm
I recommend a used unit as it takes special tools to take it apart and you have to remove the water side seal to fix it.
post #5 of 12 Old Sep 7th, 2013, 3:30 pm Thread Starter
Thanks again John.
I have found one from a 2006 LT with 7000 miles on it for 99 GB pounds, are they all the same or have they changed over the years?
gdb32 is offline
post #6 of 12 Old Sep 7th, 2013, 3:44 pm
All the same.
post #7 of 12 Old Sep 7th, 2013, 5:11 pm
blueknightga6's Avatar
John,
Just curious but is this meaning the oil pump has failed or something else? A few weeks back I too had just a few drops after an oil change, cleaned the area around the front sump cover bolt (and tightened it) and haven't had more since. But this thread has me curious.
Chris Ehlbeck
blueknightga6 is offline
post #8 of 12 Old Sep 7th, 2013, 5:14 pm Thread Starter
I have just bought this , hope it will sort the problem. Looks like I will also need an O ring and some sealant to seal it to the crankcase and a full oil and coolant drain plus refill and filter.
gdb32 is offline
post #9 of 12 Old Sep 7th, 2013, 9:02 pm
Originally Posted by blueknightga6
John,
There are two seals on the shaft. One seals oil from the oil pump and the other seals water from the water pump. There is a small dead area between the two. It just means one of the seals is leaking, not necessarily a failed pump. Only needs attention if the drip is constant.
post #10 of 12 Old Sep 7th, 2013, 9:08 pm
Engage the gear in the output shaft (top oil pump gear) and install the bolts loosely, rotate the crank (engine in 5th and bump the rear wheel) to center the gears as you tighten the housing bolts. Use a sealant on the surfaces and the o-ring on the water passage. Bolts are 10 Nm.
post #11 of 12 Old Sep 8th, 2013, 4:27 am
K100Dennis's Avatar
Just a little info on installing and getting an oil-tight seal between the oil pump housing and engine case (front face) - this is a metal to metal joint which is under full oil pump pressure, unlike most other joints on the engine, which are sealing at atmospheric pressure only. That said, BMW used to specify a 3Bond product for this joint, I think it was 3Bond 1209 or some such. I used Loctite 515 Master Gasket and primed the surfaces with Loctite Primer T. You must not scratch the aluminium surfaces and be scrupulously clean, otherwise you may be repeating the exercise. HTH
Dennis
1987 Yamaha TY250R
1991 Aprilia Climber 280
1988 K100RT (the pack horse)
K100Dennis is offline
post #12 of 12 Old Sep 8th, 2013, 7:48 am Thread Starter
Thanks Dennis, that's all useful info. Clymer calls the sealant ThreeBond 1207B, its on my shopping list, but its good to know there is something else I could use it I can't find a supplier.
gdb32 is offline
Weep Hole Poll JPSpen K1200LT 7 Feb 10th, 2012 8:02 pm
Output shaft seal & weep hole? Ron_Kendall K1200LT 3 Aug 2nd, 2010 8:52 pm
More slave cylinder weep hole pics Schweintechnik K1200LT 5 Aug 6th, 2007 5:10 pm
Front Brake Pad R&R (looong story) was K1200LT 1 Sep 3rd, 2006 11:48 pm
