LT noise - BMW Luxury Touring Community
post #1 of 15 Old Sep 4th, 2013, 9:29 pm Thread Starter
MartyBlok's Avatar
LT noise
A while ago I posted about a noise sounding like it was coming from the front of the bike. We went to the Springfield Mile over the weekend and the noise got quite loud on the way home. There was also fluid on the rear wheel. I pulled the drain plug on the final drive and I found it so full of bright shiny stuff that you couldn't even see the tip of the plug. Looks like a repair job is in my future.
Marty Blok
99 LT
MartyBlok is offline
post #2 of 15 Old Sep 4th, 2013, 9:31 pm
dthogey's Avatar
Re: LT noise
That's a real bummer.
David Hogerheide
2015 K1600GTL
2009 K1200LT (traded for GTL)
1984 Kawasaki Spectre: long gone
BMWMOA# 163123
BMWRA member
AMA member
Saddle sore 1000 Sept 2011
Bun Burner 1500 Sept 2011
CCR 2012 Duluth, MN
CCR 2014 Chattanooga, TN
dthogey is online now
post #3 of 15 Old Sep 4th, 2013, 10:21 pm
GaryEm's Avatar
Re: LT noise
I am sorry to hear about that Marty ;John or Dave I am sure can fix you right up,
GaryEm is offline
post #4 of 15 Old Sep 4th, 2013, 10:32 pm
deanwoolsey's Avatar
Re: LT noise
Yep, don't ride it until it's fixed or you risk progressive damage. Right now it's probably just a shim adjustment and new bearing.
deanwoolsey is offline
post #5 of 15 Old Sep 4th, 2013, 11:42 pm
Super Moderator
dfinazzo's Avatar
Re: LT noise
Don't fret if done with friends and tool worthy associates its an $89 bearing, a $32 seal with
some $6 shims and very little time or effort. Many write ups here on the board. Maybe visit
Countryside BMW (Chicago) so you can get a 15% discount online.
BTM neither of my two LTs (2002 ad 2009) have seen a dealer - since there are none in
Cincinnati!! This site, this forum and its people have provided me all the information I have
needed for the past 10 years!!
Not handy or mechanically inclined then try John Zeiler or others to rebuild it for you.
Once the silver pieces show up stop riding and get it fixed . . .
Dan Finazzo
dfinazzo is offline
post #6 of 15 Old Sep 5th, 2013, 5:32 pm
Enjoy The Ride
saddleman's Avatar
Re: LT noise
The bearing & seal are priced right $89.47 & $31.90 but the last shims I bought were $13.94.
When the drain plug has that many metal flakes I also take the pinion area apart to properly clean the the FD. It's about an 8 hour rebuild for me.
Dave Selvig
2004 Black LT
2000 Canon Red LT
saddleman is offline
post #7 of 15 Old Sep 6th, 2013, 8:43 am
jers99lt's Avatar
Re: LT noise
Hey Marty,
Good catch!!! My FD not only blew out it's guts, but also took out the rear brakes. As others suggest, don't ride until repaired.
Jer
Jerry Palma
85 R80RT 'Lady in Red'
08 535xi Space Gray metallic
09 328i Silver Convertable
17 X3 Glacier Silver metallic
jers99lt is offline
post #8 of 15 Old Sep 6th, 2013, 12:34 pm
GaryEm's Avatar
Re: LT noise
Jer and Marty looks like you guys will not be coming to the campout;but really you guys got me wondering if I should be looking for something different for Wheels
Gary
2003 K1200LT
GaryEm is offline
post #9 of 15 Old Sep 6th, 2013, 2:27 pm
jers99lt's Avatar
Re: LT noise
Gary
2003 K1200LT
Hey Gary,
My FD issue happened to me 6 years ago. No problems, at all, since. No, I still won't be camping. Sorry, been a long time since I've slept on the ground. Now, laying on a Lake Michigan beach under the stars is as close as I get.
Have fun,
Jer
Jerry Palma
jers99lt is offline
post #10 of 15 Old Sep 6th, 2013, 10:15 pm Thread Starter
MartyBlok's Avatar
Re: LT noise
Help is on the way. Thanks guys.
Marty Blok
99 LT
post #11 of 15 Old Sep 6th, 2013, 10:20 pm
GaryEm's Avatar
Re: LT noise
I take it your not going to fill us in what help is coming;buy the way are you going for breakfast tommorrow
GaryEm is offline
post #12 of 15 Old Sep 8th, 2013, 6:16 pm Thread Starter
MartyBlok's Avatar
Re: LT noise
No secret. Saddleman is going to rebuild it for me. As soon as I get the socket I will get it off and send it to him. Thanks Dave,
Marty Blok
99 LT
post #13 of 15 Old Sep 15th, 2013, 7:53 pm
Enjoy The Ride
saddleman's Avatar
Re: LT noise
I disassembled Marty's FD today. The factory preload was .005" & was only .001" over spec. and is probably why it went so many miles before it failed. The crown bearing had 8 bad ball bearings & both the inner & outer bearing races had a lot of spaulding. The needle pinion bearing race had moved & was riding on the FD housing. Here are some pic's. Pic 2 is the needle bearing before repair & pic 3 is after repair.
Name:	Marty Blok FD 004.JPG
ID:	41113   Click image for larger version
Name:	Marty Blok FD 008.JPG
ID:	41121   Click image for larger version
Name:	Marty Blok FD 009.JPG
Dave Selvig
2004 Black LT
2000 Canon Red LT
post #14 of 15 Old Sep 15th, 2013, 9:49 pm
K100Dennis's Avatar
Re: LT noise
Dave, you may be able to clarrify for me - I have written previously that my pinion needle bearing inner raceway appeared to have moved away from the pinion face by approximately 1mm. Noted this during crown bearing replacement, however, looking at your 2 pics it may be that I didn't notice the inner race does not abut the pinion face, rather there is a small land which is proud of the pinion face and the raceway rests on that. Can you please confirm this for me as it's not quite visible on the pics due to the angle they were taken. I may not have a displaced inner raceway (yet) if this is the case. Also, on the 8 bolt holes in the alloy casing, does anyone apply sealant around the threaded holes prior to final assembly ? I believe it would be possible for oil to leak out along the bolt shank and under the bolt head if that casing joint was not sealed. I just applied a small amount of Permatex, but there didn't appear to have been anything there ex the factory.
Dennis
1987 Yamaha TY250R
1991 Aprilia Climber 280
1988 K100RT (the pack horse)
K100Dennis is offline
post #15 of 15 Old Sep 17th, 2013, 5:19 am
Enjoy The Ride
saddleman's Avatar
Re: LT noise
The gap you see in pic 2 between the pinion gear & needle bearing race should not be there. I just use a light coating of oil on the bolt threads. I've never known any housing to leak there. Any sealer between the housing & cover could affect the preload.
Dave Selvig
2004 Black LT
2000 Canon Red LT
diagnosis for 2000 KLT intercom noise? agschmidt K1200LT 0 Jul 11th, 2012 2:24 am
Noise from Transmission / Clutch area NRuest K1200LT 5 Jun 6th, 2011 4:30 pm
Unconventional solution for the brake noise. Smith K1200LT 16 Oct 22nd, 2007 8:45 am
voice separation on the LT's loudspeaker jusufbw K1200LT 6 Oct 8th, 2007 11:03 pm
BMW CB and CQ HID Lights Creating noise? bman28 Intercom, CB, & 2-Way Radios 8 Mar 28th, 2007 3:55 pm
