Air in front brake system - BMW Luxury Touring Community
post #1 of 5 Old Sep 3rd, 2013, 4:20 pm Thread Starter
seahabit's Avatar
I flushed the brake fluids last January, 8 months ago. I made the mistake of letting the front brake reservoir run dry and pumped air into the system. After flushing a quart of fluid through the system, the brakes were still spongy. So, I pumped it up and strapped a zip tie on to hold it in place. The next morning, the brakes were operating as they should.
2000 miles later - I took a trip and ended up on Tioga Rd. (10,000ft). On the way down the hill, the brakes all but disappeared. When I grabbed the front brake, it would engage, but the handle would quickly bury itself into the hand grip and was forced to pump the brake continuously. 2 days later, I was staying at about 150ft above sea level and for the next 4 days would daily grab the front brake handle, just to see if it was still acting up. On day 4, the brake was back.
I had no ABS flashing and think the problem is residual air in the brake line coupled with an extreme altitude change.If the problem hadn't have disappeared, my next step would have been to reverse flush the front brake. Because without pulling off the tupperware to check the path of the brake line, it seemed to be the simplest way to remove any residual air. I'm wondering if any one else has run into this.
seahabit is offline
post #2 of 5 Old Sep 3rd, 2013, 6:36 pm
zippy_gg's Avatar
Re: Air in front brake system
What year is your bike?
On my 05 there are separate circuits for the wheels and the controls, so this may be your issue...or not, depending on the model you have.
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #3 of 5 Old Sep 4th, 2013, 1:19 am Thread Starter
seahabit's Avatar
It's a 99 and has separate brake circuits, With only a few more months to go until the next winter service, I'll re-bleed it. I'm fairly sure it's altitude related and won't be riding over 7000' until then, It's fine at sea level and the mountain passes around the tahoe basin,
Forgot to mention, there was no fluid loss. I did consider the possibility of a failing master cylinder or a bit of debris in the system
Thanks for the reply, TB
seahabit is offline
post #4 of 5 Old Sep 4th, 2013, 9:19 am
it's quite possible the master cylinder piston will not return when lever released, on my 85 similar problem replaced piston, cleaned bore, piston was sticking part way in, the lever does not pull the piston out
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
gary45 is offline
post #5 of 5 Old Sep 4th, 2013, 5:49 pm Thread Starter
seahabit's Avatar
Gary, thanks for the info. If the problem re-occurs, I'll reverse flush and then look into the master cylinder.
seahabit is offline
Used 2005 vs.2007, To SERVO or not? njfatz RT Series 13 Apr 2nd, 2016 8:37 pm
Comfortable riding: pegs? LeftCoastMan RT Series 41 Aug 24th, 2013 11:20 am
Brake hose in control circuit kend52 K1200LT 6 Jun 16th, 2013 7:49 pm
Did I kill my front brake? Silverhair K1200LT 7 Feb 11th, 2012 11:21 pm
Front Brake - is this right? myk_edwards K1200LT 16 May 27th, 2009 10:03 am
