Quick Main Seal Question - BMW Luxury Touring Community
post #1 of 4 Old Aug 31st, 2013, 8:12 pm Thread Starter
Hairpin's Avatar
Hello Gents, I haven't been here in awhile as my '99 LT has been laid up for nearly 18 mos. It's a long story that I won't bore you with. My immediate concern is that I'm in fairly deep, servicing the starter clutch. I changed the drive clutch and main seal about 20k ago. Getting down to the clutch cover, all looked good in the bell housing. Once I went about pulling the clutch cover and O-ring, oil started pouring out from the output shaft. I realize I wasn't smart enough to drain the oil first, but perhaps I've revealed a failed main seal? I don't know. Is everything held back by the O-ring? Lemeno. Your help is always appreciated. Thanks!
Bill MacDonald
Redmond, WA
'99 LT "Luther"
'03 Aprilia Tuono "Thunder"
'09 K1300S "Rufus II"
"The more I learn, the less I know"
Hairpin is offline
post #2 of 4 Old Aug 31st, 2013, 11:00 pm
Re: Quick Main Seal Question
Yes oil will flow out when you pull the o-ring but not much. The oil level should be below that but there is always some oil trapped in the output shaft coupling.
jzeiler is online now
post #3 of 4 Old Aug 31st, 2013, 11:48 pm Thread Starter
Hairpin's Avatar
Thanks John! I got more than a quart, but the engine back end is dropped as low as I can get it. Still sound like I'm ok?
Bill MacDonald
Redmond, WA
'99 LT "Luther"
Hairpin is offline
post #4 of 4 Old Sep 1st, 2013, 11:12 pm
Yup, just replace the oil you lost when you are done!
Fuel Line Quick Disconnect Question patrick2000 Other K-Bikes Discussion 1 Dec 18th, 2011 6:50 am
Rear Brake Pad Instl - quick question lurch102 K1200LT 3 Aug 10th, 2011 10:24 am
Joining the ranks of rear main seal woes CharlieVT K1200LT 11 Jul 12th, 2011 12:51 pm
Rear Main Seal Healed? A Miracle? hmmmm90s K1200LT 10 Mar 23rd, 2011 1:27 pm
rear main seal - TBob K1200LT 3 Jun 4th, 2009 1:19 pm
