Starting rear disc change - BMW Luxury Touring Community
post #1 of 5 Old Aug 29th, 2013, 3:39 pm Thread Starter
RocketRon's Avatar
Was going to replace rear cowbell. Reading in the Clymer it seems like the ABS ring is a big deal. If you mark the location and put it back in the same location should it be a problem or do you still have to go thru shimming and air-gap setting? Also...how neccessary is it to get two new attachment screws? Is it due to heating them it takes away any temper?
Thanks!
Rocket Ron
2002 LT
2005 Triumph Rocket
2002 Honda VTX1800R (gone)
RocketRon is offline
post #2 of 5 Old Aug 29th, 2013, 5:36 pm Thread Starter
RocketRon's Avatar
Re: Starting rear disc change
guess I need to give you guys a little more notice. Job is done. It looks like the "shimming" is only important if you move the sensor. Shimming has nothing to do with the ring. Hopefully the ring isn't critical (in thousandths anyway) to getting it right. Going to test ride now to see if the ABS light comes on....that's my only concern.
Rocket Ron
2002 LT
2005 Triumph Rocket
post #3 of 5 Old Aug 29th, 2013, 10:05 pm Thread Starter
RocketRon's Avatar
All is well. Lived with the cow bell for a year untill I had to replace the tire. Had the disc ready and waiting. Forgot what it was like to have "silence" during braking.
Rocket Ron
2002 LT
2005 Triumph Rocket
post #4 of 5 Old Aug 30th, 2013, 12:58 am
The check is done at the point where the ring is the farthest from the sensor and that gap must not be exceeded or it will loose contact. I have never had to adjust one but I always check it.
post #5 of 5 Old Aug 30th, 2013, 11:22 am Thread Starter
RocketRon's Avatar
Thanks John. Took it out...no flashing lights....brakes worked well....no cowbell! All is good!
Rocket Ron
2002 LT
2005 Triumph Rocket
unscheduled rear tire change on 2012 RT Bracati RT Series 6 Nov 14th, 2012 7:56 pm
Rear brake disc replacement. blueheaven K1200LT 7 Nov 11th, 2011 8:32 pm
K1200GT rear disc on LT larrikin K1200LT 6 Oct 3rd, 2007 8:08 am
Rear end bearing change now or later.... Dock K1200LT 1 Jul 5th, 2007 4:26 pm
