Gearbox technical question - BMW Luxury Touring Community
post #1 of 9 Old Aug 28th, 2013, 10:11 pm Thread Starter
K100Dennis's Avatar
We have discussed previously here about clutch problems and the fact that our first geasr ratios are quite tall. I am thinking of making a project around reducing the gearing in first gear, but need some answers to the following questions in order to decide whether or not this could be a "goer". It looks to me from the cutaway drawing that first gear set is at the rear of the gearbox, could someone confirm this please ? That being the case, does the electric reversing gear train engage with the fourth gear ratio driven gear ? What I'm wanting to confirm is that in any first gear set modification, the reverseing function won't be compromised, and that the modification (manufacture and install 2 new gears) will be technically possible. Then the challenge will be to find a project gearbox in Australia.
Just checked the specs, first gear ratio is stated at 2.050 : 1. I make that gear teeth numbers of 20 on the input shaft and 41 on the output shaft. can someone please confirm those numbers also ? Thanks.
Name:	k1200ltgearbox cutaway.jpg
Dennis
1987 Yamaha TY250R
1991 Aprilia Climber 280
1988 K100RT (the pack horse)
K100Dennis is offline
post #2 of 9 Old Aug 29th, 2013, 12:29 am
Re: Gearbox technical question
Reverse has it's own gear on the output shaft. Not sure if there is room in the case for a different ratio on first gear. Didn't we go through this a few months ago?
post #3 of 9 Old Aug 29th, 2013, 1:02 am Thread Starter
K100Dennis's Avatar
I commented some time back that it may be an option John, I'm wanting to get some potential show stoppers confirmed before I commit to hunting down a gearbox. I have a contact in a gear design company and can source a gear manufacturer. If it is too cost prohibitive then I won't pursue it of course, but it would be nice to do as I can see quite a few benefits.
Dennis
1987 Yamaha TY250R
post #4 of 9 Old Aug 29th, 2013, 8:10 am
If you change the first gear ratio you may find going into second awkward, big rpm change going into second, end up in second at a lower rpm than "normal", most boxes are close ratio and the rpm change gear to gear is the same
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
gary45 is offline
post #5 of 9 Old Aug 29th, 2013, 8:27 am
jwacree's Avatar
I wonder if there might be more intrest in a lower gear set for the R1150GS trans.?
1999 K1200LT Rat Bike Sold
2000 K1200LT Black Bike SOLD
2003 K1200RS Alpine White and Blue SOLD
2002 R1150GS sold
2008 "smart"
2001 K1200LT current project, AKA M1.2, AKA Horten 229
2002 F650GS It's runnin y'all
2005 K1200S
2012 R1200GS Rally
jwacree is offline
post #6 of 9 Old Aug 29th, 2013, 5:31 pm Thread Starter
K100Dennis's Avatar
In standard form, the ratio difference between 1st and 2nd gears is extremely small at 2.050 : 1 for 1st and 1.60 : 1 for second, it's really noticeable when shifting that the bike almost decellerates if you shift into second gear and don't gas it. In comparison, K100 gearing is 4.50 : 1 in 1st and 2.96 : 1 in second. Those bikes never ever toasted the clutch and could be ridden quite slowly whist still having resonable spacing between the gears, argueably they were a little low in 5th if anything. I would be aiming to have a 1st gear ratio change to around 2.9.: 1 but it may not be possible due to restrictions in the casing.
Dennis
1987 Yamaha TY250R
post #7 of 9 Old Aug 29th, 2013, 8:37 pm
azccj's Avatar
I really don't have any problems with the gearing of my LT. I would be far more interested in a once and for all clutch fix solution. Like redesigning the entire clutch system and making it a wet clutch. Then if any of those seals fail it wouldn't matter. Perhaps a clutch like most other bikes use, then seal the seam between the engine and transmission. Could it be done? I don't know. But it would be nice to replace a clutch only because it is worn out and not because some seal leaks all over the dry clutch plate.
Current Bikes
2013 Triumph Trophy SE
2013 Suzuki Burgman 650, Ya it's a scooter but it will do over 100 MPH
2005 BMW K1200LT
2004 BMW R1150RT
1972 Moto Guzzi Eldorado
azccj is offline
post #8 of 9 Old Aug 29th, 2013, 10:04 pm
wa1200lt's Avatar
It's not difficult to get a wet clutch on an LT.........
WAK1200LT
Loren
wa1200lt is offline
post #9 of 9 Old Aug 30th, 2013, 12:00 am Thread Starter
K100Dennis's Avatar
Lowering the 1st gear will preserve the clutch, the rest of the "wet clutch" problems are from leaking seals and failed clutch slave units, so no real reliability problems with the dry clutch itself other than a short life. As for converting to a wet system, unfortunately the operating principle is totally different, ours spin at engine speed, typical wet clutches spin at the speed of the primary reduction, very much slower than the crankshaft, so oil churning is not a problem.
Dennis
1987 Yamaha TY250R
Oil seal removal from gearbox in front of slave cylinder K12Rick K1200LT 4 Sep 6th, 2012 8:51 pm
Inside my gearbox.... please look / Question johnT K1200LT 17 Apr 4th, 2011 10:10 pm
Heavy throttle - Technical question sittonb K1200LT 10 Aug 20th, 2010 12:45 pm
Gearbox removal davek100rt K1200LT 2 Apr 18th, 2010 1:45 pm
Drive line oil leak near gearbox barryst1100 K1200LT 13 Jul 11th, 2006 5:25 pm
