Questions about removing rear caliper - BMW Luxury Touring Community
post #1 of 8 Old Aug 26th, 2013, 9:08 pm Thread Starter
2002 LTC - 65K miles
Like another poster this evening, I'm having trouble with a sticking rear caliper causing some greater than normal drag on the rotor. But, mine will not release with a few pumps of the front brake lever, as his will. So, I will remove the caliper and either rebuild or replace it.
I've read the integral brake instructions in the service manual for removing the rear caliper and have a couple of questions.
The manual (page 34.28) says one of the first steps is to bleed the front wheel circuit. Is this necessary? Is the rear wheel circuit not separate from the front wheel circuit?
I need to remove the ABS sensor, and the manual (page 34.31) says to first clean the ABS sensor and bore. But, it does not say how. Just wipe with a clean rag, or what?
kend52 is offline
post #2 of 8 Old Aug 27th, 2013, 12:48 am
Re: Questions about removing rear caliper
Page 34.28 is for the front calipers on a 99-2001.
Page 34.32 top right is for the rear caliper on a 2002.
Page 34.35 is for the rear sensor in the 2002 section (all rear calipers and sensors are the same for all years). Yes just wipe off any dirt or metal particles.
post #3 of 8 Old Aug 27th, 2013, 9:26 am
tombstone's Avatar
Not sure if it is different to the 2000/2001 caliper but when I had problems with mine sticking (just enough to rub, not lock up) I pulled the pads out, put in a bit of wood that was about 2mm thinner and then applied the brakes (engine NOT running), this pushed the pistons out a little further than normal, I then removed the wood and the caliper, leaving the pipework attached.
It was then easy to see that there was a ring of hard crud around where the seals had been sitting. careful use of brake cleaner and somebody else's toothbrush soon had it good as new.
You then need to squeeze the pistons back in just enough to be able to refit the pads and problem solved.
2001 K1200LT Bought Nov 2011
1963 Norton Electra 400
1960 Norton Navigator Delux 350
1977 Norton Commando 850 MkIII, owned since new.
tombstone is offline
post #4 of 8 Old Aug 27th, 2013, 1:49 pm
the rubber o rings (seals) the pistons run in also harden with age and if you are very carefull you can split the calipers remove the plastic pistons and replace the o rings - the pistons will then move as new - I did that with both my K100 and K1100 - the o rings are cheap - it's time to do the ones on my LT this winter
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
gary45 is offline
post #5 of 8 Old Aug 28th, 2013, 10:30 pm Thread Starter
Well, it appears the service manual version I have is an early version, since my page numbers don't line up with yours, John. It came with my bike when I bought it last May. Probably a good idea for me to buy the latest service manual. I found part number 01 79 0 309 672. Is that the correct part number?
kend52 is offline
post #6 of 8 Old Aug 28th, 2013, 10:33 pm Thread Starter
Great idea! Think I'll try that before rebuilding the caliper.
kend52 is offline
post #7 of 8 Old Aug 28th, 2013, 10:39 pm Thread Starter
That's where I'm headed if I'm unsuccessful cleaning the crud off the pistons. I've rebuilt airhead calipers, so it's good to hear from someone who has successfully rebuilt an LT caliper.
kend52 is offline
post #8 of 8 Old Aug 29th, 2013, 12:19 am
You could be right. My manual does not show a PN but has a print dates of 02/02. My CD is 2,000 miles away and I am using the copy on my laptop. But to answer the real question you should not have to do anything special to remove the caliper and the bleed after you re-install is pretty simple as well. Fluid will run out of the hose if you do not plug it with something.
R1100RT Rear Caliper brake pad retaining pin? biometrics RT Series 9 Oct 17th, 2012 10:58 am
Removing and replacing rear wheel pathy RT Series 6 Oct 6th, 2012 7:24 pm
LT rear speakers come on initially and then cuts out joseph_p K1200LT 10 Apr 29th, 2010 8:27 pm
Removing rear side luggage hd2bmw K1200LT 8 Nov 1st, 2007 5:15 pm
Rear END????? kip K1200LT 13 May 24th, 2006 9:32 am
