Brake fluid leaking from vent tube - BMW Luxury Touring Community
post #1 of 2 Old Aug 26th, 2013, 8:44 pm Thread Starter
Exclamation Brake fluid leaking from vent tube
I have a 2002 K1200LT with almost 87000 miles on it and I can sometimes find brake fluid leaking out the vent tube. This usually happens when the bike is on the side stand angled AWAY from the tube end. This tube is already routed to the back of the bike (non muffler side) but can't figure out why it would leak. At one point I had to add two cap fulls of brake fluid to make the flashing lights (low fluid) alarm go away. Any ideas?
KWIMV is offline
post #2 of 2 Old Aug 27th, 2013, 12:41 am
Re: Brake fluid leaking from vent tube
Usually it will only leak out of the vent tube if the reservoir was full and you pushed the pads/pistons back in one of the calipers. I would look for the source of the leak if you have to keep adding fluid frequently.
Brake flush- newbie question beemer100 K1200LT 19 Apr 13th, 2012 3:31 pm
Speed Bleeders and DOT 5 atrovarious K1200LT 11 Jun 24th, 2010 10:27 pm
Question about brake fluid RT-Hollywood RT Series 2 Aug 22nd, 2008 8:56 pm
Pull Front Tire- Get brake fluid from vent hose SkipI K1200LT 8 Mar 3rd, 2008 11:04 pm
Brake fluid indicator issues Rich_in_Tampa K1200LT 2 Oct 2nd, 2005 11:30 am
