Transmission Woes?? - BMW Luxury Touring Community
 4Likes
  • 1 Post By jzeiler
  • 1 Post By Wazza
  • 1 Post By Voyager
  • 1 Post By mondrage
post #1 of 17 Old Aug 22nd, 2013, 11:50 am Thread Starter
bulletbill's Avatar
Transmission Woes??
My Transmission shift drum as stopped rotating? I thought the lever was dragging on the body works, but when I removed the lever disconnected linkage, bumped the rear wheel the transmission down shift from 5th -4th -3rd and stopped down shifting? And now won’t shift up or down? Any thoughts?
Bill Jennings, fhp
Denison, TX
BMW States
BMW years and miles, 32 years 500K+
AMA, CMA, IBA, POG, MSF, FHP, etc
'99 K1200lt
'76 R900/6
Various Vintage Dirt Bikes
-Greeves (Sold), Pentons, Hodaka, etc.
Remember you are not lost till you run out of gas!
bulletbill is offline
post #2 of 17 Old Aug 22nd, 2013, 1:56 pm
Razmataz's Avatar
Re: Transmission Woes??
I have one sitting in my garage with 75,000 miles on it. Worked fine on my bike with Mobil One in it. The only reason its not on my bike is I bought a motor,clutch, and tranny all together with only 5500 miles on it when I screwed up the engine on my bike.
BMW 1200 LTC 2002
Razmataz is offline
post #3 of 17 Old Aug 22nd, 2013, 3:58 pm
zippy_gg's Avatar
Are you using the clutch to change gears? Can you take a photo of your shifter assembly (the one directly connected to the shaft on the rear side of the transmission)?
It may be something obvious to those who were just there...
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #4 of 17 Old Aug 22nd, 2013, 4:29 pm
Scouter-50's Avatar
I had a similar problem when I lubed the shifter ball joints. Somehow, I got the reverse assy. out of time with the shifter. I just fiddled with the shifter and the reverse lever till it all started working. I know that is not very scientific but it worked for me. Somehow I had the reverse mechanism locking out the shift mechanism.
Robert
2000 K1200LT "Latifah"
1994 R1100RSL (wife's)
1981 R80GS
1976 R90S
2011 Bunkhouse Queen
Scouter-50 is offline
post #5 of 17 Old Aug 22nd, 2013, 7:44 pm Thread Starter
bulletbill's Avatar
I'm down on the Gulf Coast today, be back at the shop Tomorrow or Saturday and I'll do the picture bit.
Bill Jennings, fhp
Denison, TX
BMW States
'99 K1200lt
'76 R900/6
post #6 of 17 Old Oct 13th, 2018, 2:10 pm
Mine started to not shift down from 3rd.
Haven’t removed the covers but I put liberal amounts of WD40.
Nothing.
While trying to get home (wouldn’t shift now down from 4th) I noticed that if I pushed the lever a bit up (while not making a shift but kind of a false neutral) and then down it would shift perfectly.
So, what’s going on here?
What do I have to check?
Mike is a K12LT 2007 with 42k km.
BMW K1200LT 2007
BMW K1200R: "Drophammer" 2006
BMW R1200GS 2008
BMW K1200S 2007
Suzuki DR-Z400E 2000
Sachs MadAss FY125-20
mondrage is offline
post #7 of 17 Old Oct 13th, 2018, 9:37 pm
Checked the linkage by removing the Chromed covers.
Probably just stiff.
Put WD-40 and seems fine now.
BMW K1200LT 2007
BMW R1200GS 2008
BMW K1200S 2007
mondrage is offline
post #8 of 17 Old Oct 14th, 2018, 5:01 pm
Always best to take it apart, clean and lube and replace the missing bushes that seal out water and dirt. Also check each of the ball pins and make sure they are tight.
Also look here for a good article on the linkage.
Patric likes this.
post #9 of 17 Old Oct 14th, 2018, 6:37 pm
The best thing I did was to replace the old original linkages with the more robust, service free Power Shift linkages. It improved my gear shifts straight away.
kbob12 likes this.
Wazza is offline
post #10 of 17 Old Oct 15th, 2018, 10:59 am
Care to share a link on where to buy them?
BMW K1200LT 2007
BMW R1200GS 2008
BMW K1200S 2007
mondrage is offline
post #11 of 17 Old Oct 15th, 2018, 4:42 pm
I bought it off eBay and at the time all I did was put BMW K 1200 LT shifter linkage kit into the search function. They cost me $154 Au dollars
Wazza is offline
post #12 of 17 Old Oct 15th, 2018, 4:45 pm
I just checked and it says there is one left for the 2005 to 2010 model. They also do one for the earlier models bikes.
Wazza is offline
post #13 of 17 Old Oct 16th, 2018, 10:36 am
I just watched Kirk Johnson's excellent YouTube video (
These videos are so great, that everytime one helps me with something. I send him a donation.
I dont' think he needs the money, but I'm sure it's gratifying to know that someone appreciates all that hard work to produce those videos. They are outstanding.
Anyways, I didn't do the whole shebang disassembly that Kirk shows, but did WD-40'ed the links.
The shifting is now butter-smooth.
But this weekend I'm planning to do it.
BMW K1200LT 2007
BMW R1200GS 2008
BMW K1200S 2007
mondrage is offline
post #14 of 17 Old Oct 16th, 2018, 2:06 pm
I just watched Kirk Johnson's excellent YouTube video (https://youtu.be/4o-ysRHinLU).
WD-40 is not a good lubricant, especially for high stress joints. You definitely want to get some good EP grease into those joints.
post #15 of 17 Old Oct 16th, 2018, 2:09 pm
True but if its dirty and stiff WD-40 is good to clean it out, followed by a proper cleaning and lube.
post #16 of 17 Old Oct 16th, 2018, 2:15 pm
Yes, WD-40 makes a fine solvent and water displacer, but it is not a good long-term lubricant.
Painterman likes this.
post #17 of 17 Old Oct 16th, 2018, 2:35 pm
That's why I said I'm planning to do it this weekend.
It got me out of a pinch. In the middle of city traffic, lots of start stops in 4th... wouldn't have been good for the clutch.
So the WD-40 did its job.
I'll do a proper lube job this weekend.
Patric likes this.
BMW K1200LT 2007
BMW R1200GS 2008
BMW K1200S 2007
mondrage is offline
Transmission case has hole in it The_Big_M K1200LT 8 Aug 26th, 2012 12:14 am
RT1200 Rough Transmission.... Triple Threat RT Series 1 Dec 23rd, 2011 12:11 am
transmission plug fuzz lstinthot K1200LT 15 Aug 5th, 2008 11:09 pm
transmission rebuild sheldan2 K1200LT 4 Dec 4th, 2007 8:38 am
Still looking for a Transmission, but... black1200lt K1200LT 11 Oct 24th, 2005 6:29 pm
