tire pressures for avons - BMW Luxury Touring Community
post #1 of 11 Old Aug 22nd, 2013, 9:03 am Thread Starter
bobst2's Avatar
well put on a set of avons for the first time they seem excellent, but don't know what pressures to run in the radials. for now i set front 42 rear 48
but heading for ccr with two up and pulling the unigo.
those of u that run avons please give me your thoughts for. 1 up front & rear &
2 up loaded front & rear
bobst2 is offline
post #2 of 11 Old Aug 22nd, 2013, 9:52 am
Eric_R's Avatar
Re: tire pressures for avons
I run 42/48 regardless of loading. Hit the scales @1450 lbs one time, I stay away from the scales now
Ran loaded like that on Hwy1 to the Bay area and back with no issues.
Works just fine.
2002 K1200LTC Ocean Blue
Eric_R is offline
post #3 of 11 Old Aug 22nd, 2013, 10:58 am
max cold pressure as stated on tires is 42, I run 42 cold pressure front and back
Bill Dowdy
2014 RT
2006 LT
2000 HD Ultra Classic
theoldone is offline
post #4 of 11 Old Aug 22nd, 2013, 8:16 pm
rattler50's Avatar
Look on the side of the tire and it will tell you the max pressure to run. Run the max pressure.................
2006 R1200RT
2005 K1200LT Ocean Blue
2003 K1200LTE Black
Totaled Oct 2, 2010
2006 Kawasaki Vulcan 2000
rattler50 is offline
post #5 of 11 Old Aug 22nd, 2013, 9:18 pm
I run 38/42 one up exclusively. My LT is setup for 230 LBS rider and luggage.
I am ready to replace this set (will be my third) and I have just over 12K with a little more to the wear indicators. I came upon this pressure by monitoring the tire temps using my Smartire TPS. I used Stones after my first tire change and I never had both tires wear to replacement at the same time. So this is a first.
2001 Black LTC
2015 Blue R1200GSA
jackd is offline
post #6 of 11 Old Aug 22nd, 2013, 11:38 pm
I've run probably at least 10 sets of Avon S2 Ultras on my '05 LT, and the max pressure posted on both tires is 42. I stay with that, sometimes a lb over. Nice, smooth running tire compared to the bias ply Metz.
BMRBOB
bmrbob is offline
post #7 of 11 Old Aug 23rd, 2013, 6:52 am
14wntr's Avatar
Wow. so many different pressures!
I spoke directly with Avon Tech on this issue and was told this. Start at 40F and 44R and adjust according to peak pressure at operating temp. He said you want the tire to increase 10% when it is fully hot. If it is too low the pressure will increase more and if it is to high it will be lower than 10%
He said to ignore the max pressure on the side. Its for chumps
2000 K1200LT-C "Tsukune"
2013 Honda NC700X "Moka"
Kirk Johnson
President of
14wntr is offline
post #8 of 11 Old Aug 23rd, 2013, 8:53 am
dukey33's Avatar
Did you get that in writing?
-2000 K1200LT
dukey33 is offline
post #9 of 11 Old Aug 23rd, 2013, 1:04 pm
I've gotten the same info from an avon tech rep, minus the "chumps" part. In fact some of his exact words were " there are 10 things that effect the life of the tire. The first is pressure. the second is pressure. the third is pressure, the fourth is pressure. want me to keep going?"
I got the point! Steve
Steve_in_Sunny_Fla is offline
post #10 of 11 Old Aug 25th, 2013, 9:28 am Thread Starter
bobst2's Avatar
well i guess i will try 40 & 44 and see how it goes
bobst2 is offline
post #11 of 11 Old Aug 25th, 2013, 12:16 pm
Zeke's Avatar
Avon rep and a bridgestone rep told me same thing. i run avons now for last forever. 10+ sets
Just use the 10% rule and ignore the side pressure.
Mine seem to be at 43/48.
2002 K1200LT
2016 R1200RT
IBA # 41935
Zeke is offline
Bridgy BT-020 review UncleMark Tires 9 Mar 22nd, 2012 7:43 pm
LT tire change Voyager K1200LT 11 Sep 8th, 2011 8:08 pm
Tire pressure fluctuation tom39 K1200LT 7 Jun 22nd, 2010 1:39 pm
Tire Plug/Tire Independence a MUST LAF Tires 31 May 26th, 2008 8:02 pm
Tire Repair warning from Dunlop cfell Tires 3 Dec 3rd, 2006 7:35 pm
