Removing abs/servo - BMW Luxury Touring Community
 6Likes
  • 4 Post By jzeiler
  • 1 Post By norton
  • 1 Post By whtmtn2000
post #1 of 40 Old Aug 21st, 2013, 8:32 pm Thread Starter
Removing abs/servo
Anyone have instructions on removing abs and servo for 04 Lt.? I found the video on rtp but nothing on the Lt.
hphammer is offline
post #2 of 40 Old Aug 21st, 2013, 8:58 pm
GaryEm's Avatar
Re: Removing abs/servo
I think Chris Harris has a video on it from Affordable Beemer;just google once.
Your does not work or just want to get rid of the noise
Gary
2003 K1200LT
GaryEm is offline
post #3 of 40 Old Aug 21st, 2013, 9:07 pm Thread Starter
Mine quit and servo works intermittently making it unsafe. I do not want to spend $2200 for a new unit.
hphammer is offline
post #4 of 40 Old Aug 21st, 2013, 9:10 pm
james216's Avatar
I just contacted Chris. Not because I have a problem, but if I do. I want to bypass it. Chris emailed me saying he's working on 2 LT's yanking the servos now. And will have more info and how to do it. In September.
2004 K1200LT. Big Mama
I'm a 4 percenter.
james216 is offline
post #5 of 40 Old Aug 21st, 2013, 9:15 pm Thread Starter
Awesome. Thanks
hphammer is offline
post #6 of 40 Old Aug 22nd, 2013, 8:32 pm
That'll be an interesting video.... bitchin' the whole time he's working on the LT's... looking forward to those ones..
post #7 of 40 Old Aug 27th, 2013, 1:33 pm
printcraft's Avatar
Tagging for future updates.
2002 K1200LT-E
printcraft is offline
post #8 of 40 Old Sep 1st, 2013, 9:10 am Thread Starter
Well i decided to dive into it. I removed the plastics, battery, stingray and fuel tank. Little bit of a mess with the brake fluid as i disconnected the lines. Abs unit out and servo unit out. Brake lines out. The front two brake lines come up under the handlebars and join into one. The same type of connector as in the rtp video is mounted front of the fuel tank on the frame. (4 lines). I cut the connector just like in the video and joined the line for the front calipers and the front master cylinder/brake. I bled and they pressurized like a normal system. For the rear, the rear caliper line runs along the right side and along the swing arm. There is a connector there. The rear brake master cylinder line runs up and stops with a connector in front of the battery. I went to a shop and they made me a ss line for $40. 1 ft 7 in plus the end length. the front was a banjo with a bend back and to the right side of the motorcycle. The rear was just straight. I screwed it right in bled it and two minuted later i had rear brake.
The wiring is where i am currently at. There are three connectors. A setup like in the rtp video for the abs unit. The servo is a separate unit and has two round barrel connectors. Turned the key without connecting any of the wiring and found the neutral safety switch was one of the wires in one of the barrel connectors and it would not kick over. I then connected the two barrel connectors and pos and neg attached to the servo and the neutral light lit and it would crank but not start. Also if you do not connect the pos and neg on the servo unit the mc will still crank and neutral light lights up. This is where i am currently. Help with the wiring would be appreciated. I have not cut any wires yet.
hphammer is offline
post #9 of 40 Old Sep 1st, 2013, 9:32 am
james216's Avatar
Contact Chris Harris. He will help you.
I'm a 4 percenter.
james216 is offline
post #10 of 40 Old Sep 1st, 2013, 10:04 am Thread Starter
Stupid mistake on switching fuel lines when i put the tank back on. Switched them and runs like a champ
hphammer is offline
post #11 of 40 Old Sep 1st, 2013, 11:24 am
timgray's Avatar
Are the masters large enough to do adequate braking without the servo assist/Abs in place?
timgray is offline
post #12 of 40 Old Sep 1st, 2013, 10:16 pm
They are the same for all years so if they work for a 99 (no power assist) they will work on any year. But I do not advocate removing the ABS functionality.
post #13 of 40 Old Sep 2nd, 2013, 1:57 pm Thread Starter
Just finished the wiring. Everything went good. used two relays just like in the video. Originally I thought the wiring was different but I was able to find the same colored wires as in the RTP video. The only thing I have yet to figure out is the speedometer. Test drove it and it stops normally without that loud whine.
hphammer is offline
post #14 of 40 Old Sep 2nd, 2013, 3:12 pm
GaryEm's Avatar
Thats pretty good hphammer to bad you did not have video to go with it.;now I know where to go if I get get sick of the whine.
GaryEm is offline
post #15 of 40 Old Sep 2nd, 2013, 3:47 pm
hphammer, congrats on the new brakes. I have the same issue and I'm trying to decide which route to go (MM - rebuild (available Dec 2013 time-frame @ around $450), remove ABS module like you did, buy new unit ($2300)). I'm very interested in hearing more about the task and your thoughts on the bike now. All sounds positive, but just want to gather more information.
I need to find out if your system is the same as my 2006 LT. I think it is, but need to confirm.
Sammy
sgroover is offline
post #16 of 40 Old Apr 9th, 2014, 12:03 pm
johnT's Avatar
How and/or where does the speedo tie into all this?
Is it connected to the abs or servo unit?
johnT is offline
post #17 of 40 Old Apr 9th, 2014, 2:57 pm
johnT's Avatar
John,
yes it does... alternator too...
Name:	lt wiring.jpg
johnT is offline
post #18 of 40 Old Nov 25th, 2014, 12:53 pm
vfgarza's Avatar
Location: Reynosa, Tamaulipas, None (International), México
hphammer Did you figured out the Speedometer and Alternator wiring?
vfgarza is offline
post #19 of 40 Old Nov 25th, 2014, 1:30 pm
vfgarza's Avatar
Any Luck with Speedometer and Alternator?
vfgarza is offline
post #20 of 40 Old Nov 25th, 2014, 2:26 pm
The only connection to the alternator is for ABS power (also ties to battery +). The ABS "brain" develops the signal for the speedometer based on the rear ABS sensor. Only way to make it work correctly is to remove the circuit card "brain" from the ABS and hook it back up to the harness. You will still have the flashing warning lights but can disable that by cutting one wire or removing a relay. The brake lights will also work with no additional wiring.
That is the only way to get the speedo working again short of designing your own circuit to drive it.
post #21 of 40 Old Nov 25th, 2014, 4:23 pm
deanwoolsey's Avatar
Just a thought, would it be feasible to simply plug the hydraulics on the ABS unit and leave the circuit board in place for the speedo function? Then just build your bypass hydraulics directly to the wheels.
deanwoolsey is offline
post #22 of 40 Old Nov 25th, 2014, 7:22 pm
Enjoy The Ride
saddleman's Avatar
That is exactly what I'm doing to my 2004 LT now.
Dave Selvig
2004 Black LT
2000 Canon Red LT
saddleman is online now
post #23 of 40 Old Nov 26th, 2014, 12:04 pm
Is the LT safe to ride without the ABS setup? How much difference in the brakes?
Notahog is offline
post #24 of 40 Old Nov 26th, 2014, 1:23 pm
If you are going to leave the unit on I recommend pulling the leads to the servo motors as they will just consume energy and eventually burn out. The leads with the red and grey, red and black wires. The others are for the ABS solenoids.
Name:	Electronics internal board 6.JPG
post #25 of 40 Old Jan 7th, 2015, 4:36 pm
vfgarza's Avatar
My servo unit failed misserably! What I did is to bypass the servos directly to the calipers without removing servo unit al all. Everything works ok. Obvious, you loose ABS but I have a Goldwing 1500 also and I aplied exactly the same presure to brake as any motorcycle. So far everything works fine.
PS. Where I can find the the cables you say to pull and cut the power to the servos? What cable do I need to cut to rid of the shitty ABS warning lights?
Is it the "green" cable?
vfgarza is offline
post #26 of 40 Old Jan 7th, 2015, 4:37 pm
vfgarza's Avatar
vfgarza is offline
post #27 of 40 Old Jan 8th, 2015, 11:24 am
I will get you the details tonight. Don't cut anything until then
post #28 of 40 Old Jan 8th, 2015, 2:51 pm
vfgarza's Avatar
Thank you! I'm speaking of cables 'cause to reach the Module where ABS warning relay is deep bellow the fuel tank. (Good design BMW engineers), and I don't wanna spend a big deal of time removing all this sucker.
vfgarza is offline
post #29 of 40 Old Jan 8th, 2015, 7:39 pm
The wires to cut are in the big connector on the top of the ABS unit. These will stop the warning lights. The only way to disconnect the servo motors is to pull the end cap off the ABS like in my post number 24 above. Pull off the big connector and pop the back off of it. Find the Brown/Red wire on pin 9 and the Brown/Yellow wire on pin 10 and cut them. Replace the cover and re-connect the connector. Your warning lights will now be out but you will have Speedo, Odo and cruise still available.
The picture shows the big connector (red arrow) and the end cap is circled in green.
sailor, Frenchy, vfgarza and 1 others like this.
post #30 of 40 Old Jan 26th, 2015, 1:44 pm
vfgarza's Avatar
Thank you very much!
On next weekend I'll spend a time doing this.
vfgarza is offline
post #31 of 40 Old Jan 27th, 2015, 3:45 am
norton's Avatar
It always amazes me how mechanically savvy some of you guys are to figure this complex shit out. This site is lucky to have the wealth of knowledge that it does.
Tricky_dickey likes this.
norton is offline
post #32 of 40 Old Jan 28th, 2015, 8:41 am
jers99lt's Avatar
Hi All,
I'm just wondering if the video referenced above had been produced (removal of the ABS unit)? If so, could someone please provide a link? I currently have the LT torn down (have not removed the battery holder, yet) and bled the lines. I'm about to remove the ABS (to have it refurbished) and would like to know of any helpful hints or specific tools needed that I don't currently have.
I going off both the BMW and Climer's manuals, but they are less than comprehensive about specific ways to remove things. I'm a shade tree mechanic, at best.
Thanks for all comments/suggestions,
Jer
Jerry Palma
85 R80RT 'Lady in Red'
08 535xi Space Gray metallic
09 328i Silver Convertable
17 X3 Glacier Silver metallic
jers99lt is offline
post #33 of 40 Old Jan 28th, 2015, 4:55 pm
Hi Jerry
Just wondering why you'd bleed the lines (brake lines I assume) if you are going to remove the ABS unit for overhaul? Practice?
post #34 of 40 Old Jan 28th, 2015, 7:48 pm
jers99lt's Avatar
Originally Posted by cws View Post
Hi Jerry
Hi Chris,
I'm also replacing the original rubber brake lines. Piked up the Spiegler replacements (sportbiketrackgear.com; SP S-BM0140-CLR-NAT clear, natural).I will also be bleeding the ABS unit, too. The lines going into the ABS need to be drained or there's a BIG mess.
Have fun,
Jer
Jerry Palma
jers99lt is offline
post #35 of 40 Old May 12th, 2015, 10:54 am
whtmtn2000's Avatar
Well fellas, I have my 02 all apart. Tank off, Battery Out. I'm ready to drain the brake lines and remove the ABS Unit hopefully without making a mess.
I have a couple of questions that I hope you don't mind answering.
1) The relay that is under the tank that you say to disconnect to stop the wig wag brake failure lights from flashing. What does is look like? Which side is it on? What color wires come out of it? Do I cut it out and just tape off the wires left from it OR just unplug?
2) Do we continue to use the rear brake reservoir? If so how do I manage the few hoses that are on it?
Thanks guys!
Mark D.
Groveland,MA
2002 KLT (JETBLUE)
1993 ST1100 (retired)
1982 GPz 1100 EFI (retired)
1979 750F (retired)
whtmtn2000 is offline
post #36 of 40 Old Jun 10th, 2015, 1:49 pm
whtmtn2000's Avatar
O.K. answering my own questions for you.
The ABS relay is located in the large compartment under the tank. Right hand side. Cover held with 8 screws. It is also part of the air filter compartment assembly. ABS relay is in the top relay holder. It is the blue relay. Back row left hand side of the relay holder.
Rear brake tank. I cut and plugged the two rear hoses that would feed the ABS unit. The front hose continues to be used and feeds the rear master cylinder. I refilled both ends of the rear master cylinder tank. I think though that filling the rear master cylinder rear tank (ABS reservoir) is not necessary.
Thanks to all that provided info here. This process is not difficult.
sailor likes this.
post #37 of 40 Old Jan 6th, 2017, 12:36 pm
Talking Re: Removing abs/servo
Hi.Is this the same as on a r1200rt year 2006 your help would be very helpful Brendan
post #38 of 40 Old Jan 7th, 2017, 2:11 pm
The servo brake units are pretty much the same across the different models with the programming being the difference. So if you need to pull the board and look for corrosion I say go for it. Bypassing the unit all together is the same.
post #39 of 40 Old Dec 7th, 2018, 5:24 am
good day all
ive got a gs 1200 04 model from my father,,,, we removed the abs pump and servo assisted breaks and bypassed all that..
new problem is the speedo doesnt work....any help????
...N.0.X... is offline
post #40 of 40 Old Dec 7th, 2018, 4:13 pm
Yes you need to open up the unit you pulled out and remove the circuit board. Just remove the end of the ABS and cover the open end to insulate the board and plug it back into the harness. The ABS brain uses the rear ABS sensor to drive the speedometer and odometer, it also drives the brake light relay.
This may work based on the similarity to the LT but be aware the GS started with the CAN buss in 2004 so it may not work.
If the ABS looks like this one you may succeed. If it was the other one (b&w pic) you could have just left it in there.
Name:	Electronics internal board 6.jpg
ID:	148837   Click image for larger version
ID:	148839   Click image for larger version
Clutch Fading 2011 R1200RT SquareHead RT Series 19 May 6th, 2013 2:35 pm
Removing Windscreen Adjustment Assy. Woolly K1200LT 2 Nov 13th, 2012 9:52 am
RT Clutch Adjustment Nebish RT Series 17 Apr 1st, 2009 9:51 am
Removing the Side compartment? DanDiver K1200LT 1 Oct 27th, 2008 3:22 pm
removing the rear tire Michaeldale K1200LT 23 Sep 8th, 2008 3:56 pm
