rear brakes hot - BMW Luxury Touring Community
post #1 of 8 Old Aug 21st, 2013, 7:30 am Thread Starter
TeddyTelco's Avatar
rear brakes hot
I got of the bike the other day and noticed that the rear caliper was hot the rotor also is this normal or are they dragging? the fronts weren't hot
2009 BMW K1200LT "Shelly"
2002 Honda VT1100 Sabre Sold
1979 Harley Davidson FXEF 1340 Sold
1975 Norton 850 Commando Sold
TeddyTelco is offline
post #2 of 8 Old Aug 21st, 2013, 8:44 am
patroa1's Avatar
Re: rear brakes hot
Ted, I would check to make sure that the rears are not dragging , but they do get quite hot compared to the fronts. I would say this is normal as the rears will burn your fingers after even a short ride.
Pat Rourke
White Lake,MI.
2002 K1200 LTC, Champange
patroa1 is offline
post #3 of 8 Old Aug 21st, 2013, 6:13 pm
Enjoy The Ride
saddleman's Avatar
Re: rear brakes hot
The only way to know for sure is to coast to a stop using engine braking only & then check the rotors.
Dave Selvig
2004 Black LT
2000 Canon Red LT
saddleman is offline
post #4 of 8 Old Aug 21st, 2013, 10:02 pm
GaryEm's Avatar
Re: rear brakes hot
I agree with Pat ;the rears do get really hot compared to the fronts.
GaryEm is offline
post #5 of 8 Old Aug 21st, 2013, 10:12 pm
BecketMa's Avatar
Re: rear brakes hot
Rears are always HOT if I try and check air pressure or intall air pressure when I'm not in my garage.
BecketMa is offline
post #6 of 8 Old Aug 21st, 2013, 10:14 pm
BecketMa's Avatar
Re: rear brakes hot
Oh.
FUN Toy from harbour freight is the cheap temp sensor, infared temp gun?
Shoot the disk and see what u get?
BecketMa is offline
post #7 of 8 Old Aug 21st, 2013, 10:40 pm
Re: rear brakes hot
hypoid gears (FD) develop a lot of heat, limited air flow, rear brake picks up heat
with the bike on the center stand and neutral wheel should rotate freely, if moved back and forth, rev forward, and caliper sticking you should be able feel it sticking on direction change
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
gary45 is offline
post #8 of 8 Old Aug 22nd, 2013, 9:28 pm
Re: rear brakes hot
I have a TPS that displays temp and when it is hot (over 100 degrees) the tire temp can reach 160 degrees. I have checked the tire temp multiple times with an infrared temp gun and the temp is accurate. Every time I checked the temp with the gun I also checked the rear end and the rear rotor and all three at the same temp. Front temps are always slightly less.
2001 Black LTC
2015 Blue R1200GSA
jackd is offline
Comfortable riding: pegs? LeftCoastMan RT Series 41 Aug 24th, 2013 11:20 am
Beryl Beemer goes through 3rd rear drive bearing PhillWard Australia, New Zealand, and AsiaPac 6 Apr 1st, 2008 9:10 am
Rear brakes, skreeeeeeach, metal on metal BecketMa K1200LT 11 Feb 6th, 2007 5:59 pm
Now that was a good bit of AG rubber PhillWard Australia, New Zealand, and AsiaPac 2 Jan 1st, 2007 4:00 am
