gearbox shaft - BMW Luxury Touring Community
post #1 of 4 Old Aug 19th, 2013, 10:48 am Thread Starter
gearbox shaft
Where can one get part. Is from namibia no part.
Looking for contact nr
Please
Mail [email protected]
Ride in water river and seal and shaft got wet so shaft need to be replace and seal.
Jacqe_Andre is offline
post #2 of 4 Old Aug 19th, 2013, 12:53 pm
Re: gearbox shaft
If you state what model bike you have, someone may perhaps jump in with advice. Also, you can identify the parts needed at www.ascycles.com and order online. If that doesn't work, post what exactly the problem is and I'm sure you'll find assistance in this forum, if it relates to a K1200LT that is. If you prefer you can also send me a private message in the other language.
Andre
André Strydom
BMW MOA #140995
Acts 4:12
andres is offline
post #3 of 4 Old Aug 19th, 2013, 3:38 pm Thread Starter
Re: gearbox shaft
I have a k1200lt 2007 model 30 thousand km on the clock.
Clutch was replaced 3 times within 1000km due to oil on the clutch..
Dealer found slave cylinder fine. Found leak on gearbox seal.
Also found rust on shaft an he suspects this damaged the seal. Can source everything in Namibia exept for the shaft. Was advised to look for a part in Germany. Would like to find out if anyone herehad a similar problem and have any suggetsions. Dealersuspects previous owner might have driven through water frequently. Also would welcome some advice on where to source the part. I do have the part number.
Would appreciate any help
post #4 of 4 Old Aug 19th, 2013, 6:46 pm
FatStrat's Avatar
Re: gearbox shaft
Jaque Andre,
Investigate whether you could use a "Speedy Sleeve" on your old shaft. Speedy sleeves press onto a shaft that is worn and give the seal a new surface to ride on. I have used these things on many applications with great success. Sure would be an easy, cost effective solution to your problem. Good luck.
Here's a link... https://www.google.com/search?q=spee...bm=isch&tbo=u&
http://www.youtube.com/watch?v=09LiVbqL6ss
http://www.oit.edu/libraries/facilit...ze_listing.pdf
Friends know the song in your heart, and can sing it to you when you have forgotten the words.
FatStrat is offline
Problems with gearbox drive shaft output seal cluainsi K1200LT 14 Apr 6th, 2012 2:42 pm
Shaft seal pulling made easy Schweintechnik K1200LT 4 Aug 6th, 2007 7:21 pm
Gearbox Tale of Whoa pwmac2005 K1200LT 4 Jul 25th, 2007 5:54 pm
Drive line oil leak near gearbox barryst1100 K1200LT 13 Jul 11th, 2006 5:25 pm
