LT brake piston - BMW Luxury Touring Community
post #1 of 6 Old Aug 18th, 2013, 7:45 pm Thread Starter
LT brake piston
Doing the rear brake on my lt and all was well until I went to put my pucks in after the flush. I had not noticed that the right spacer had fallen out during the process. Anyway I now can put my left puck in but the right pistons are all the way out and I am not sure how to get them back in so I can put my brake in. They just seem to be stuck and I can't move them fear of the unknown!
08 BMW k1200lt
05 BMW K1200lt sold
01 Kawi 800 clasic my loud pipe bike
94 Hon RX 100cc going strong
91 Hon 750 gone
87 Suz 750 gone
76 Goldwing 1000 retired
71 Hon 750 long gone
Jesus said I give you a new command "Love one another as I have Loved you". John 13;34 niv
Bajasteve is offline
post #2 of 6 Old Aug 18th, 2013, 7:51 pm
Re: LT brake piston
If they are not puking fluid then you should be able to push them back. Best way is use a wooden shim (home depot etc used for shimming up door frames). This is the easiest way as you can insert the one pad and a couple of shims to push the pistons back. I'll be passing through MO tomorrow on the way to CCR but not anywhere close to you, Festus then St Joseph.
post #3 of 6 Old Aug 18th, 2013, 10:18 pm
Re: LT brake piston
It takes a bit of force. Some leverage like John suggested will help. I assume the caliper is not mounted since you don't want to lever against the brake disc.
André Strydom
BMW MOA #140995
Acts 4:12
andres is offline
post #4 of 6 Old Aug 18th, 2013, 10:37 pm Thread Starter
Re: LT brake piston
Thanks for the quick reply Guys the wood shims worked great, but wow I had to drive those right side pistons back in withe the wood shim with the back of a hammer. Case and point "keep the pucks or shims in place" while doing the procedure.
John your 2005 th 2009 LT brake CD was oh so worth witting for, your expert advise a made it easy. You all be safe on your trip to Oregon
08 BMW k1200lt
05 BMW K1200lt sold
91 Hon 750 gone
87 Suz 750 gone
post #5 of 6 Old Aug 19th, 2013, 6:50 am
Re: LT brake piston
I made wood blocks that are a snug fit in each caliper to use after I push the pistons in with an automotive compression tool. Works great for flushing and other times I have the brakes off and don't want to worry about a lever getting squeezed inadvertently.
post #6 of 6 Old Aug 19th, 2013, 7:20 am
TeddyTelco's Avatar
Re: LT brake piston
with the calipers off I used a C clamp to push in the pistons but went a little too fast and ended up with some fluid on the floor..
2009 BMW K1200LT "Shelly"
2002 Honda VT1100 Sabre Sold
1979 Harley Davidson FXEF 1340 Sold
1975 Norton 850 Commando Sold
TeddyTelco is offline
Another Brake Problem and a Near Miss chuckle K1200LT 31 Mar 14th, 2016 12:56 pm
Brake hose failure registry? cmartin248 K1200LT 53 Nov 11th, 2014 2:34 am
R1200RT 2010 Brake Failure buiduc_hung RT Series 17 Mar 9th, 2013 1:51 pm
Brake Question jimdeluca RT Series 12 Jan 14th, 2013 11:22 pm
Brake Question chuckle K1200LT 13 Jun 30th, 2010 4:36 pm
