how about playing name that fluid - BMW Luxury Touring Community
post #1 of 8 Old Aug 17th, 2013, 9:17 pm Thread Starter
TeddyTelco's Avatar
While putting on front wheel the bike was up on center stand used a jack to put the front up just enough to get wheel off. When I was putting it on I noticed a clear oily fluid in a puddle as big as a saucer right underneath the breather tube that is at the front of the back wheel. Was it brake fluid if so where from? I did use a C clamp to push in the pistons on the brakes so I could get the wheel back on. Who's the 1st to play Name that Fluid...
2009 BMW K1200LT "Shelly"
2002 Honda VT1100 Sabre Sold
1979 Harley Davidson FXEF 1340 Sold
1975 Norton 850 Commando Sold
TeddyTelco is offline
post #2 of 8 Old Aug 17th, 2013, 9:25 pm Thread Starter
TeddyTelco's Avatar
Re: how about playing name that fluid
"The reason for the slowly part was you are pushing fluid back into the ABS unit and it could overflow and make a mess. " This from John Baker from my other thread. John I think you may have won "Name that Fluid"...
post #3 of 8 Old Aug 17th, 2013, 10:20 pm
azccj's Avatar
I've done the same thing on my RT. If the brake fluid reservoir is topped off and you push 8 brake pistons back into the calipers, this will overflow the reservoir and the excess will end up on the floor. Next time you do the brake fluid flush, put the funnel on the reservoir, then push the brake pistons back into their bores. You'll see just how much brake fluid is held in the calipers.
Current Bikes
2013 Triumph Trophy SE
2013 Suzuki Burgman 650, Ya it's a scooter but it will do over 100 MPH
2005 BMW K1200LT
2004 BMW R1150RT
1972 Moto Guzzi Eldorado
azccj is offline
post #4 of 8 Old Aug 17th, 2013, 10:25 pm
johnbaker15's Avatar
Teddy,
Lift the seat and look down on the left side at the top of the ABS unit, if it is looking wet you found the source.
John Baker
2005 BMW K1200LT
1979 Suzuki GS1000E
1978 Honda CB350
1975 Suzuki GT380
johnbaker15 is offline
post #5 of 8 Old Aug 17th, 2013, 10:37 pm Thread Starter
TeddyTelco's Avatar
I looked under seat can't see anything past the battery. Did I blow a seal or do I just need to top it off. Pretty sure it's brake fluid
post #6 of 8 Old Aug 17th, 2013, 11:31 pm
azccj's Avatar
On top of the ABS unit there will be 2 quarter size caps that have allen wrench sockets. These caps have hoses attached to their sides. These two hoses connect somewhere down below and become one, and I imagine from this one hose your brake fluid is draining from. You didn't blow any seal. And you don't need to do anything really. But the hose will continue to drip a bit of fluid until the hose is drained. Just remember that brake fluid damages paint, so any that drips on the rear wheel might damage the finish. If when you pushed the brake pistons back, and a lot of brake fluid was pushed into the hose, it is possible that the reservoir might be low when the pistons returned to their original positions. If the fluid is very low the ABS light will start flashing. If the light doesn't flash then the fluid level is ok. If you want you can unscrew the plastic caps with the appropriate allen wrench to see the brake fluid level. The bigger reservoir is for the front brakes.
Current Bikes
2005 BMW K1200LT
2004 BMW R1150RT
azccj is offline
post #7 of 8 Old Aug 18th, 2013, 8:56 am
Jim_McG's Avatar
The front brake wheel circuit uses one of the rear reservoirs. Both rear reservoirs have overflow hoses that snake down to the front right side of the rear wheel. When you pushed the front caliper pistons back in, you overflowed the reservoir. I trick I learned here is when I bleed the brakes I take those overflow hoses and dip them into a bottle of fresh DOT 4 fluid so it refills the reservoir as I bleed away.
Jim
Jim_McG is offline
post #8 of 8 Old Aug 18th, 2013, 11:38 am
His is an 09 so both the wheel circuit reservoirs are ON the ABS unit. He has one small one behind the pannier for the rear control circuit (not monitored). Fo the 05 and up it is best to set the level in these reservoirs with the caliper pistons fully retracted. Then pump the pistons out. They are not as sensitive as the early bikes and using this method when you get the wig wag lights your pads are worn out. No need to add fluid between flushes like the 2001-2004 bikes.
2002 i-ABS Question, fluid change and bleeding ColoradoGrant K1200LT 0 Sep 4th, 2011 12:03 am
Speed Bleeders and DOT 5 atrovarious K1200LT 11 Jun 24th, 2010 10:27 pm
Just did an easier tranny fluid change PrimePower K1200LT 21 Jul 27th, 2009 11:02 pm
Front brake fluid and Will Be Selling the bike Jabrown K1200LT 11 Oct 22nd, 2007 2:07 pm
Does Old Brake Fluid Smell? Jerrod Maguire K1200LT 7 Dec 13th, 2005 3:00 pm
