front wheel install - BMW Luxury Touring Community
post #1 of 6 Old Aug 17th, 2013, 7:00 pm Thread Starter
TeddyTelco's Avatar
front wheel install
I replaced my tires today (Metzelers Thanks for asking). I am attempting to put the calipers back on but the pads are pressed together.What is the best way to get them apart to slide disc in?
2009 BMW K1200LT "Shelly"
2002 Honda VT1100 Sabre Sold
1979 Harley Davidson FXEF 1340 Sold
1975 Norton 850 Commando Sold
TeddyTelco is offline
post #2 of 6 Old Aug 17th, 2013, 7:18 pm
johnbaker15's Avatar
Re: front wheel install
Don't know if there is a best way.
But if you can get a wide flat pry bar to open them up, slowly, try to not dig into the pad. Just rock the pry bar back an forth until you get them opened. Once you have then opened you can rock them onto the disk.
Or you could take the pads out and use large slip joint plier to compress the pistons back into the caliper.Then reinstall the pads.
Something that helps compressing the pads is to crack open the bled valve while you are pushing the pads back in, just remember to keep constant pressure so you don't suck air back into the caliper.
John Baker
2005 BMW K1200LT
1979 Suzuki GS1000E
1978 Honda CB350
1975 Suzuki GT380
johnbaker15 is offline
post #3 of 6 Old Aug 17th, 2013, 7:50 pm Thread Starter
TeddyTelco's Avatar
Thanks John you got me heading in the right direction. I broke out ol Mr C clamp and pushed those pistons out of the way
post #4 of 6 Old Aug 17th, 2013, 7:51 pm
All the big box home improvement stores sell wood shims that are great to wedge in the pads to push them back. Oops I see I am too late.
post #5 of 6 Old Aug 17th, 2013, 7:59 pm
Enjoy The Ride
saddleman's Avatar
When you push one caliper back the other pads on the other caliper can come out some. So install the one caliper before you push the other caliper pads back.
Dave Selvig
2004 Black LT
2000 Canon Red LT
saddleman is offline
post #6 of 6 Old Aug 17th, 2013, 8:25 pm
Great you got it done.
Another reason to like this forum, folks here are always ready to respond, even on Saturday night!
The reason for the slowly part was you are pushing fluid back into the ABS unit and it could overflow and make a mess. Also like Dave mentioned it is a dual caliper so when you push on one the other moves also.
Next time you might want to use wooden wedges JohnZ was talking about, just slide them in between the pads as soon as you get them off the mount so they will not compress.
John Baker
2005 BMW K1200LT
1979 Suzuki GS1000E
1978 Honda CB350
1975 Suzuki GT380
K1200LT Low speed front wheel wobble ironhorsenc K1200LT 18 Jun 29th, 2015 8:10 pm
Noticed a little "growling" from the front wheel GHOSTRACER K1200LT 23 Oct 27th, 2013 3:24 pm
Portable front wheel jack tony_voorn RT Series 14 Aug 19th, 2013 9:58 am
front wheel bearing cover orientation bartman49 K1200LT 2 Mar 19th, 2013 2:28 pm
Front wheel wobble-ing ??? Frenchy K1200LT 18 Jul 2nd, 2006 1:19 pm
