Mobil 1 (0 w 40) - BMW Luxury Touring Community
post #1 of 21 Old Apr 10th, 2006, 9:59 am Thread Starter
Mobil 1 (0 w 40)
I just turned over 23000 miles on my bike. I decided to change from synthetic blend oil to full synthetic. Went to two different places to get Mobil 1 10 w 40, all I could find was 10 w 30 and 0 w 40. I went with the 0 w 40 since it had a higher viscosity rating. My question I live in the south (very hot) and I change my oil every 5000 miles, is it ok to run a oil with the low number being 0.
Thanks.
CARNEYM is offline
post #2 of 21 Old Apr 10th, 2006, 10:29 am
I'd be more concerned about using *only* 40 weight. I don't know about MS, but our temps here in AZ are already exceeding the 30 degree C / 86 F ceiling BMW recommends for 40 weight.
Motor On ,/'
jkersh1 is offline
post #3 of 21 Old Apr 10th, 2006, 12:33 pm
I would also be concerned of running a 0W40 weight oil in a bike that specifies 20W50. Many 40 weight car and motorcycle oils are known to shear to a 30 weight in a few thousand miles. Many 50 weight motorcycle specific oils shear to a 40 weight. See https://www.amsoil.com/lit/g2156.pdf for some info on motorcycle oils.
If your oil shears below the specified weight shown in the manual, it gives the opportunity for your warranty to be voided if a lubricated part fails.
TimVipond is offline
post #4 of 21 Old Apr 10th, 2006, 12:39 pm
amarider's Avatar
I believe the BMW synthetic is 15W-50 not 20W-50. There is a Mobil 1 available in 15W-50.
John & Cathy
Northern CA
01 K1200LTC Basalt - Moose
Posse #2
amarider is offline
post #5 of 21 Old Apr 10th, 2006, 2:11 pm
PATTERSON's Avatar
I agree with AMARIDER.......do the 20w50.
Patterson/USAF1....'05 LT
and the little guy behind me is the world famous "Marty Hill"
Never look into a lazer with the remaining eye
363K on BMW's
PATTERSON is offline
post #6 of 21 Old Apr 10th, 2006, 7:54 pm
Daman858's Avatar
Unless you ride in ridiculously cold weather, like around zero degrees, do not use 0W40 in your motorcycle. I use Mobil 1 15W50 full synthetic in my LT and Mobil 1 5W20 in my Honda Accord. It's like water but it is what the manual calls for.
Monkton, MD
and Pawleys Island, SC
2002 K1200LTC
Daman858 is offline
post #7 of 21 Old Apr 10th, 2006, 8:17 pm
avonfloater's Avatar
Cool
Someone told me to look for the Mobil "motorcycle" synthetic suggesting it was better for the heat ranges experienced in motorcycle engines. Anybody know about that? Tks.
avonfloater is offline
post #8 of 21 Old Apr 10th, 2006, 8:51 pm
Mobil 1 makes a 20 w- 50 motorcycle oil called 20w-50 V Twin and 10w- 40 MX4T. The V Twin name is a marketing exercise by Mobil. Since most air cooled V twins require 20- 50W ( and there are allot of V Twins out there), Mobil labeled there 20-50 V-Twin. We sell both if your interested.
nplenzick is offline
post #9 of 21 Old Apr 10th, 2006, 10:32 pm
Avonfloater - there are indeed differences between the Mobil1 v-twin 20w50 motorcycle oil and the 15w50 Mobil1 EP oils. The EP oil is API SM, SL and SJ, whereas the v-twin is not. The EP flash point is 241C compared to the v-twin at 270C. You can read all about these oils at www.mobil1.com. The tech line people will say the car oils are not recommended, formulated, or tested for motorcycle use, whereas their motorcycle oils are.
post #10 of 21 Old Apr 11th, 2006, 3:04 am
BecketMa's Avatar
It must be summertime. We have blown bearing and oil threads again.
The results of using the wrong weight oil can be a disaster.
Subbing 40 weight for 50 weight probably isnít good for your engine.
I seem to remember reading that 0X40 oil was developed for autos to increase their EPA gas mileage.
I havenít looked at Mobile synthetic formulation, but I do seem to remember that many synthetic oils are not full synthetic.
I seem to remember Dave having good luck with Castrol 20W50 SI/SJ?, for many 10 thousands of miles.
Bob, 00LT
BecketMa is offline
post #11 of 21 Old Apr 11th, 2006, 6:16 am
Why not just use standard mobil 1 20w-50
Several times I have read threads on this forum claiming that the LT is not like typical motorcycle engines. It does not have a wet clutch system that shares the oil with the engine. It is more like an auto. Therefore, I fail to understand the reasoning behind the need to use motorcycle specific oil in the LT.
Why not just go with standard automotive Mobil 1 20/50? It will give you the same benefits of synthetic but for less money. It meets the BMW requirement for oil as well. That is what I am going to do.. I have just over 15K on my '03 LTC and when it turns 18K, in goes the Mobil 1.
Somebody give me a good reason why we shouldn't?
rglassma is offline
post #12 of 21 Old Apr 11th, 2006, 6:38 am
murray's Avatar
Question Suzuki 15-50 Synthetic
Not to muddy the waters but, Suzuki has there brand of motorcycle oil. The suggested use is for both air and water cooled motors. The Suzuki oil is about $3.00 less / quart. I would think this would be compatible with our motors. I bought some and was ready to try it but my paranoia got the best of me. I exchanged it for the BMW stuff.
Anyone know why the Suzuki oil may not be compatible?
Pete Murray
IBA # 359 and
2014 RT
1973 R75/5
2002 LT 171 K Gone
2008 FJR 36 K Gone
Stroudsburg, PA
murray is offline
post #13 of 21 Old Apr 11th, 2006, 8:26 am Thread Starter
Thanks all, I'm going to drain it out and get some 15 w 50.
Mickey
CARNEYM is offline
post #14 of 21 Old Apr 11th, 2006, 10:58 am
HornHonker's Avatar
I'm new to the LT (as of last week) but wonder if the gearbox is also lubed by the engine oil ? If so perhaps it is an anti-foaming characteristic that we use motorcycle oil ? There is also the matter of the new very slippery oils that are bad for a wet clutch on most bikes. Why should we not use these as well with our dry clutch ?
2011 BMW 1600GTL
2000 BMW R1100R
2008 Burgman 650EX
HornHonker is offline
post #15 of 21 Old Apr 11th, 2006, 12:32 pm
"Motorcycle" oils are formulated for two things, high heat found in aircooled engines, and wet clutches that are lubricated by engine oils.
The LT is a water cooled automotive style engine, and it has a dry clutch, also like an automobile. There is absolutely NOTHING to be gained on the LT by using a more expensive "motorcycle" oil. Just use standard automotive oils the weight required.
I would NOT use 0-40W oil though! Especially in warm climates. Way out of BMW's specification.
post #16 of 21 Old Apr 11th, 2006, 12:38 pm
When manufacturers state "motorcycle" use, they are covering the entire range, which in the market is overwhelmingly air cooled V-twins, so they do not differentiate between those (which have the most difficult requirement), they also have to cover those that have engine oil lubed wet clutches.
The LT is for all practical purposes an automotive engine/clutch, which needs none of the special formulation required by the other end of the motorcycle spectrum. "Motorcycle" oils offer nothing to the LT, except greater cost.
post #17 of 21 Old Apr 11th, 2006, 2:01 pm
usmctpdog's Avatar
Very Well Stated David !!
I have never had any problems using other than factory recommended oils.
It is the oil weight that should be the same.
Infact I am using Rotella oil, made by Shell and sold by Walmart in most of my vehicles, that includs my Suzuki DL1000
2005 PearlBlue FJR1300 (Sold)
*Ridin steady since 1973
usmctpdog is offline
post #18 of 21 Old Apr 11th, 2006, 7:51 pm
bruce2000ltc's Avatar
Nor has anybody else. I've been involved with motorcycles and cars for the past 40 years. Through my experience in car and motorcycle clubs --and since the internet came into being -- many car and motorcycle groups, I've heard and read many oil discussions. The one thing I've never heard is a motor that failed because of the type of oil that was used. Now I don't mean an oil pressure failure (either clogged or broken oil pump) or poor maintenance (failure to change oil regularly) but the oil itself failing and causing motor damage. I've asked this question many times: Has anyone had, or do they know anyone who has had, an oil caused engine failure? No one has ever answered: yes.
Use the manufacturer recommended oil grades, change intervals and choose any brand you like.
Bruce Hodges
bruce2000ltc is offline
post #19 of 21 Old Apr 11th, 2006, 9:34 pm
"I've asked this question many times: Has anyone had, or do they know anyone who has had, an oil caused engine failure? No one has ever answered: yes."
Actually there are thousands of oil caused engine failures (or engine caused oil failures). Just ask Toyota or any auto consumer protection group (for example http://www.autosafety.org/getcat.php?cid=28. ) For several of their engines they no longer recommend 7500 mile petroleum oil changes due to the high number of oil sludged up engines that are requiring extensive engine repairs and replacement. For certain engines they have changed the oil change interval to 5,000 miles and synthetic motor oil only.
post #20 of 21 Old Apr 12th, 2006, 7:54 am
I don't see Toyota, VW or Chrysler blaming the oil. Looks more like engine design flaws or poor maintenance.
Bruce
post #21 of 21 Old Apr 12th, 2006, 9:13 am
Bruce
They are blaming the oil if you are not using their newly recommended oils. A few of the manufactures are sending out letters to potential sludgies with a new list of specific oils. They used to recommend petroleum oils and are now recommending synthetic oils. Oils can vary alot in evaporation and flash point which can make some oils more sludge prone than others.
Lubricant change JPSpen K1200LT 15 Oct 16th, 2005 4:19 pm
