Trailering the LT - BMW Luxury Touring Community
post #1 of 14 Old Aug 14th, 2013, 9:33 pm Thread Starter
that_guy11's Avatar
Trailering the LT
Well I didn't think I'd ever do it but I'm trailering my LT to CCR. My wife and I can't do the long days on the bike to get to Oregon so I got a 6 x 12 Haulmark and put in a Condor chock with the 4 tie downs as described by several on this site.
So my question is there anything special I need to do while the bike is in the trailer for 2 to 3 days at a time? I figure at the end of the day I'd release most of the tension in the tie downs. But is there any thing else I need to watch for?
Thanks from the newbie trailererer,
Chuck
Chuck
1997 Suzuki Bandit 1200
2009 BMW K1200LT
that_guy11 is offline
post #2 of 14 Old Aug 14th, 2013, 10:28 pm
davebullock's Avatar
Re: Trailering the LT
For the first time we also trailered to CO from WI this month, so we have a car and bike for the month we are here. I picked up a Stinger trailer, and loaded it Tuesday, unloaded it Thursday night in CO, and didn't touch it in between. I can't think of what you would need to do-except sneak it off the trailer for a ride somewhere along the way!
davebullock is offline
post #3 of 14 Old Aug 14th, 2013, 10:41 pm
wilbar00c's Avatar
Some of us have noted that with the pressure change when going to 12,000 feet and then lower, the rear drive might weep out gear oil from the vent from air pushing out a few drops of gear oil. Just stuff an old towel in that area to keep the trailer floor dry.
BMWMOA 89402
wilbar00c is offline
post #4 of 14 Old Aug 14th, 2013, 11:27 pm
Super Moderator
dfinazzo's Avatar
I trailered to my first 2 CCRs - as usual when I arrived people did not know what that was under my bike - just funnin around.
Some tips:
1. Make sure you load the bike going down hill - very little motor and clutching to load
2. Make sure you have a wide ramp at least 30" wide - ride the bike on with good foot support
3. Make sure the engine is warmed up and the servo brakes are working - no flashing lights
4. I always took off the front fender
5. I always undid the right side brake line hose block
6. I used tie straps that go around the front fork legs just above the cross brace
Do not tie anything on the handle bars
7. I use tie downs that have ratchets to go into the tie straps
8. Let some air out of your front tire as compressing the tire will help lock it down and give good resistance to the ratchet type tie downs
9. Go down the road a bit and check the front tie downs - 90% of the hold power on the bike is on the front tie downs!!
10. If you tie down in the manner your bike suspension will be active
11. You need very little tie down on the rear - just a slight pull straight down is good enough
12. Make sure you unload the bike going down hill - thus you only need to use brakes
As others mentioned when I towed to Breckenridge - rear oil weeped out of the top vent -
without the rear tire ever rotating - what a surprise but the dealer in Colorado says this
happens all the time on our rear drives when towed.
Good luck travel safe and hope to see you in Bend, OR - counting the days!!
Dan Finazzo
dfinazzo is offline
post #5 of 14 Old Aug 15th, 2013, 7:13 am
Old Slow Guy in A Fast Car
katnapinn's Avatar
If using "NEW" straps I would check then after about 100 miles. Then again after another 100 miles as new straps tend to stretch some.
Stevie Shreeve
katnapinn is offline
post #6 of 14 Old Aug 15th, 2013, 8:13 am
johnbaker15's Avatar
Dan,
Nice write-up, thanks for sharing!
BTW, what is that under your bike?
John Baker
2005 BMW K1200LT
1979 Suzuki GS1000E
1978 Honda CB350
1975 Suzuki GT380
johnbaker15 is offline
post #7 of 14 Old Aug 15th, 2013, 8:50 am
Palerider's Avatar
Some LT's have a special licence tag holder that says "If you see this on a trailer, it's being stollen"..........I'd check that.............
Jim and Cyndy
'03 Black..."Ol' Dollar"
TDMTT
Palerider is offline
post #8 of 14 Old Aug 15th, 2013, 7:29 pm
The two most important tie downs are the front as it holds the front wheel in the chock. If the front wheel stays in the chock everything is good. The rest are just there for stability. No need to loosen at the end of the day but do check them at every gas stop in case they come loose on their own.
This is the first CCR that my wife has been to that we did NOT trailer the bike. So don't feel bad.
post #9 of 14 Old Aug 15th, 2013, 11:09 pm Thread Starter
that_guy11's Avatar
Thanks everyone for the info. The bike is loaded up and ready go. We leave early tomorrow morning. So much to see and not enough time.
Chuck
Chuck
2009 BMW K1200LT
post #10 of 14 Old Aug 16th, 2013, 12:26 am
mycamel's Avatar
how about a couple of photos strapped down?
Mike Hammel (My Camel) [WB9GMO/4]
2002 K1200LT-E
1998 ACE Burgundy (now 'retired')
1998 ACE Yellow/Black Tourer (now 'retired')
19?? Suzuki 500 (now 'retired')
1962 modifed 49cc>~55cc Sears MoPed (LONG 'retired')
US Army Security Agency 0582L68 ('64-68)
moderator and owner:
Retired from the business world (finally--sigh --poor and proud)
Georgia Patriot Guard Riders
Roswell, GA
mycamel is offline
post #11 of 14 Old Aug 16th, 2013, 12:30 am
mycamel's Avatar
what trailer is that?
where'd you get it?
approx cost?
do you like it?
2002 K1200LT-E
Roswell, GA
mycamel is offline
post #12 of 14 Old Aug 16th, 2013, 9:54 pm
In case you are wondering why (I'll admit it didn't occur to me), the reason you don't want to use a 2x12 or similar is putting an LT up on a 2x12 is a bit like walking a tightrope ... except you can't see either your feet or the rope. The bike is just too big, when you are walking next to it, you can't see the wheels or the board.
Getting it on the trailer wasn't too bad. Getting it off scared the **** out of me... I had no idea if the wheels were staying on the ramp or not. (that was with a second ramp for me to walk up and down).
Fortunately, no harm done. That time.
Nice looking trailer, btw. But I'm rapidly deciding my bikes don't belong on trailers.
NickHolland is offline
post #13 of 14 Old Aug 17th, 2013, 1:14 am
Super Moderator
dfinazzo's Avatar
The trailer I had that a few of you may be referring to is a BMW MultiTrailer - picture was
taken at the Cincinnati BMW Dealers showroom - before I took it home!! Dealer is long
gone - 6 years ago!!
More pictures here:
http://s1026.photobucket.com/user/dg...20Multitrailer
I owned if for about 4 years and sold it for a very handsome profit . . . it was ideal for
towing the LT. Many many cool items - independent suspension, surge braking system,
on board ramp that folds out very wide and stores on board, on board 12v power socket,
very sturdy wheel chock, adjustable 3rd wheel with lock, independent on board stabilizing
jacks - you could load the bike off vehicle, made for BMW and came with a BMW title.
Boy I really miss that thing - really regret selling it but my wife got more comfortable riding
long distance and we took the money and bought a Unigo!!
Dan Finazzo
dfinazzo is offline
post #14 of 14 Old Aug 17th, 2013, 1:21 am
mycamel's Avatar
dan that is one exceptional trailer. glad you at least, made a profit!!
thanks for the photos and information!
2002 K1200LT-E
Roswell, GA
mycamel is offline
Trailering LT on a landscape trailer ? rbots K1200LT 6 Jul 13th, 2008 11:44 am
1st Time Trailering, straping suggestions? jericbrinley Trailers, Sidecars, & Trikes 2 Jul 13th, 2007 12:21 pm
Trailering a Bike John_LT K1200LT 12 Jun 6th, 2007 7:37 pm
Trailering a K1200LT nbbusa K1200LT 16 Jan 7th, 2007 9:56 pm
As if trailering wasnt enough! Gene_Chapman Bike Talk 30 Oct 6th, 2006 9:34 am
