Locked Out if K12OOLT - BMW Luxury Touring Community
post #1 of 5 Old Aug 14th, 2013, 12:43 pm Thread Starter
Red face Locked Out if K12OOLT
Testing the remote, all worked fine locking/unlocking side and top cases and glove box. HOWEVER, now my glove box is stuck in the "locked" position. I can put my ear to the glove box and "hear" the lock but does not unlock. Key rotates OK in the lock but does not "unlock" Even though the key insert is vertical (unlocked position), the button will not depress so glove box will not open. Local Dealer says take of fairing BUT can't get to screws under locked glove box!! Duh!! I've tried lightly hitting with my fist while depressing button but no go!! Local locksmith will not touch it!! Any suggestions??? Thanks. Spiceman/SOCAL
Spiceman
O5 LT
07 R12GS
02 K12rs
89 R100GS
dualbmw is offline
post #2 of 5 Old Aug 14th, 2013, 12:48 pm
JNW003's Avatar
Re: Locked Out if K12OOLT
Try pushing down on it as you hit the remote to relieve some of the pressure... There are some recent threads on opening stubborn locks you may want to review also if that doesn't work. Good luck!
JNW003 is offline
post #3 of 5 Old Aug 14th, 2013, 5:26 pm
sailor's Avatar
JZEILER posted a solution to this problem in an earlier thead:
http://www.bmwlt.com/forums/showthread.php?t=73580
John (Montreal, CANADA)
sailor is offline
post #4 of 5 Old Aug 14th, 2013, 5:40 pm
In the Similar Threads below - http://www.bmwlt.com/forums/showthread.php?t=38877
glenhinegarner wrote in #27
Good News
I put the key in and turned it side to side and whala opened, this site is amazing!!
Now I took the screw out and they are both 3/4 inches long, dealer error.
I will leave the one out and pick up the proper size Monday.
Thanks for all the help, and my bike is a 2005 KLT
Glen
and : On my 2005 book that info is on page 9 in section 2,
insert key in lock you want to open
turn the key 45 degrees and press the lock barrel with the key in the lock
thanks,
Glen
I was going to tell you to put the key in at the correct position and hit it but jzeiler noted in post #32 - It is just the other way around. If you lock it with the FOB you cannot open it with the key. Not even the 45 degree trick works on this one.
I absolutely know John is correct, but it couldn't hurt to try since it worked for Glen.
_____________
Kim Thomson
Motorcycle Cigar Smoker
85 K100 Standard - Big Red
Gone, but not forgotten...
85 K100RT - (wore out)
alabrew is offline
post #5 of 5 Old Aug 14th, 2013, 8:31 pm
wyorock's Avatar
I recently had the same thing happen to me and I found that I had to have the lock on the oddments lid in the locked position in order for the fob to work.
2005 K1200LT
wyorock is offline
Oddments Compartment Remains Locked djfalkenstein K1200LT 33 Apr 25th, 2012 8:29 pm
front brakes locked? pauleknight K1200LT 19 Aug 21st, 2010 7:07 pm
Locked 2007 Bike jrowlandesq K1200LT 17 Jan 22nd, 2008 9:35 am
petrol tank filler cap locked up... rickster Bike Talk 0 Oct 29th, 2007 2:55 am
Locked Keys In The Car lexlan Humor 2 Jun 12th, 2006 11:36 am
