LT gas gauge adjustment - BMW Luxury Touring Community
 1Likes
  • 1 Post By jzeiler
post #1 of 5 Old Aug 13th, 2013, 10:16 am Thread Starter
timgray's Avatar
IS there a proper way to adjust the accuracy of the Fuel gauge? when I have used 3 gallons I am at the 1/4 tank left mark, and when I fill the tank to about 1.5" from the gas fill hole it shows that I am 1/8th from full.
I just would like a more accurate representation of the fuel level instead of having the low fuel light go off at a little under a 1/2 a tank.
timgray is offline
post #2 of 5 Old Aug 13th, 2013, 10:30 am
mtrevelino's Avatar
Re: LT gas gauge adjustment
The dealer has to re-calibrate the gauge. I believe that they will drain out the fuel and install 1 gallon then calibrate it.
I do not know if the gs-911 tool will perform the calibration.
Mike Trevelino
Williamsburg, VA
2008 RT
mtrevelino is offline
post #3 of 5 Old Aug 13th, 2013, 10:26 pm
You can calibrate the low fuel light and set it anywhere you want. Drain the tank and then add one gallon (or what ever you want). Just have the exact amount of fuel in the tank you want it to indicate. Turn on the key and short pin 3 to pin 4 on the diagnostic connector for a few seconds until the low fuel light starts flashing and when it stops flashing it is set.
The only way to get a full tank indication is to fill the tank on the side stand and get the fuel right up to the bottom of the filler tube. You cannot fully fill the tank on the center stand.
CaliDefector likes this.
post #4 of 5 Old Aug 14th, 2013, 1:16 am
K100Dennis's Avatar
John, forgive my ignorance, but where is the diagnostic plug located ? Handy to know.
Dennis
1987 Yamaha TY250R
1991 Aprilia Climber 280
1988 K100RT (the pack horse)
K100Dennis is offline
post #5 of 5 Old Aug 14th, 2013, 8:36 am
johnbaker15's Avatar
It's under the rear seat, at the back, a little off center to the right. From John's photo you can see it is round and it will have a cap on the end. It is the only one back there that only has wires going to it from one side. HTH
John Baker
2005 BMW K1200LT
1979 Suzuki GS1000E
1978 Honda CB350
1975 Suzuki GT380
johnbaker15 is offline
2010 RT Fuel Gauge Problem fl0950 RT Series 58 May 2nd, 2017 10:50 am
Fuel Gauge Anomaly mtrevelino K1200LT 6 Sep 24th, 2010 10:11 am
Fuel Gauge continuing problems JOHNF K1200LT 18 Jul 14th, 2009 10:32 am
Gas Gauge Adjustment deanwoolsey K1200LT 6 Apr 30th, 2009 9:27 pm
gas gauge malfunctioning? starky K1200LT 13 Jul 20th, 2006 5:06 pm
