Trunk light question - BMW Luxury Touring Community
post #1 of 11 Old Aug 13th, 2013, 1:13 am Thread Starter
Seems my trunk light only worked for about a month after I got the bike. Could have swore it came on when you opened the trunk but don't see a door switch. Thought maybe it has a built mercury switch. Also it isn't to obvious how to pop the lense out to check it.
joeybolz is offline
post #2 of 11 Old Aug 13th, 2013, 3:04 am
Re: Trunk light question
Depends on year model of your bike, whether or not a trunk light is lit upon opening the lid. Early model years had the light manually operated by the slide switch similar to the dash light. I'm not sure of the model year when a change wuz made to a plunger type switch that activated the light when the trunk lid wuz raised.
With regard to checking the bulb in the vanity light fixture, you can remove the lens by inserting a small-blade screwdriver into the opening on the side of the lense and prying it out - same procedure for the dash light. You'll see the bulb snap-fitted to the back of the plastic lens. HTH.
post #3 of 11 Old Aug 13th, 2013, 9:47 am
Jim_McG's Avatar
My 2003 LT has a plunger switch at the right rear corner of the lower case and a slide switch on the lens. It only gets power when the key is at ACC. or ON positions.
Jim
Jim_McG is offline
post #4 of 11 Old Aug 13th, 2013, 4:51 pm
Palerider's Avatar
That may be the reason BMW was so helpful by supplying a little bitty flash light in the accoutraments dept..................
Jim and Cyndy
'03 Black..."Ol' Dollar"
TDMTT
Palerider is offline
post #5 of 11 Old Aug 13th, 2013, 5:11 pm
timgray's Avatar
Yup it will not work until you turn on the ignition to at least the ACC position. at least my 03 works that way.
Still can not figure out why the switch has 3 positions. On, Off, and more off?
timgray is offline
post #6 of 11 Old Aug 13th, 2013, 5:53 pm
00K1200LT's Avatar
No no that little flash light was to check your oil window... you cant see the oil window without it...
00K1200LT is offline
post #7 of 11 Old Aug 13th, 2013, 5:56 pm
00K1200LT's Avatar
I always like the part where you get off the bike. Pull the key and get to the truck to look in and try to turn the light on and then have to put the key back and turn it one spot to ON, so you can tun the light on in the trunk... wow..
post #8 of 11 Old Aug 13th, 2013, 8:07 pm
Palerider's Avatar
I'm hip................
Jim and Cyndy
TDMTT
post #9 of 11 Old Aug 13th, 2013, 10:00 pm
lesn's Avatar
On my 2003, the slider switch has 3 positions : off, manual on or automatic on when openned.
lesn is offline
post #10 of 11 Old Aug 13th, 2013, 10:04 pm
deanwoolsey's Avatar
Imagine how small you would need to be to utilize that manual override "on" setting.
deanwoolsey is offline
post #11 of 11 Old Aug 13th, 2013, 10:09 pm
Think of it as ON, Accessory and OFF. Why they used "R" I'll never know. You can turn on the radio in "R" but everything should be dead when you have it all the way off (bars locked). Just don't go too far and put it in park and run the battery down with the lights.
hyper brake light question itspossible K1200LT 3 May 13th, 2011 3:03 pm
Trunk Rack (newbie question) tdraper K1200LT 4 Jun 14th, 2006 8:36 pm
Warning Light Question jorawro K1200LT 7 May 24th, 2006 3:19 pm
How many forum members does it take to change a light bulb? RoyvL Humor 12 Feb 13th, 2006 1:49 pm
