Bouncy Handling - BMW Luxury Touring Community
post #1 of 20 Old Aug 11th, 2013, 10:52 am Thread Starter
beerbiker21's Avatar
Bouncy Handling
I've just realised..having had a whizz around autoroutes in France that there is something seriously amiss with the handing. Short pottering in the UK lead me to blame the state of our roads but on longer runs the bike seems to "hobby-horse". I had the front seals done a while back and it might relate to that. Softening the rear damper helped but the movement leads to strained backs and a miserable passenger. Any thoughts welcomed.
beerbiker21 is offline
post #2 of 20 Old Aug 11th, 2013, 11:11 am
Super Moderator
dfinazzo's Avatar
Re: Bouncy Handling
Basic engineering:
1. Springs resist displacement
2. Shock Absorbers (dash pots) resist velocity change
If you are bouncing around I would say that your shock absorbers have given up their life
and you are ready for some replacement ones. The inability to tame the spring as it
compresses and uncompressed is a tough job - especially for such a heavy weight bike!
You have about 4 choices - BMW, Wilbers, Ohlins or Hyperpro
Dan Finazzo
dfinazzo is offline
post #3 of 20 Old Aug 11th, 2013, 11:29 am
Palerider's Avatar
Re: Bouncy Handling
That pretty well sums that up.................
Jim and Cyndy
'03 Black..."Ol' Dollar"
TDMTT
Palerider is offline
post #4 of 20 Old Aug 11th, 2013, 11:33 am Thread Starter
Re: Bouncy Handling
I guess you mean the central one rather than the front forks. Could it be low oil level...read somewhere it can be topped up.
Last edited by beerbiker21; Aug 11th, 2013 at 11:36 am. Reason: additional thought
post #5 of 20 Old Aug 11th, 2013, 4:26 pm
Guest
2191's Avatar
Re: Bouncy Handling
How many miles on the bike. An there is a front shock which is hidden from view.
Travel safe. New SHOCKS WILL HELP.
2191 is offline
post #6 of 20 Old Aug 11th, 2013, 4:53 pm
timgray's Avatar
Re: Bouncy Handling
If adjusting the rear you feel NO resistance, then yes you can top up the oil. you have to fill the adjuster from the banjo hole where the hose connects to the shock.
http://www.youtube.com/user/illinois...?feature=watch One of the videos from the Illinois BMW Riders group covers this.
timgray is offline
post #7 of 20 Old Aug 21st, 2013, 6:54 am Thread Starter
Re: Bouncy Handling
She's only done 60k miles. Surely the units must last longer than that? Seen one for sale on eBay...done 169k! Any further thoughts? Am guessing that it's the hidden front one. My 1960 650 Triumph didn't have one at all!
post #8 of 20 Old Aug 21st, 2013, 11:09 am
Razmataz's Avatar
Re: Bouncy Handling
Another alternative is HyperPro Springs on the old shocks, which I hope to do this winter. Much cheaper than whole new shocks and according to many does the trick. For around $350 that last I looked.
BMW 1200 LTC 2002
Razmataz is offline
post #9 of 20 Old Aug 21st, 2013, 1:42 pm
BecketMa's Avatar
Re: Bouncy Handling
One time, I increased the front tire pressure by 2 lbs, it stopped the hobby horse feeling. Another time replacing the rear tire a Metz I had run a few thousands of miles in interstates so that it was waring pretty flat in the center with a new B'Stone.
Another it was playing around with the front adjuster on an after market shock that stopped the rockin after I set the rear adjust for a stiff vrs soft ride.
BecketMa is offline
post #10 of 20 Old Aug 21st, 2013, 7:14 pm
Re: Bouncy Handling
Shock absorber life is a lot shorter than most people think. I would seriously consider replacing at about 40K miles, sooner if problems develop, such as no oil in the rear shock adjuster. I replaced mine at about 20K miles for that reason (used Wilbers fwiw).
Current:
2006 BMW K1200LT
2010 BMW R1200RT
Previous:
1999 BMW K1200LT
2007 Yamaha FZ6
1986 Suzuki GS550L
1985 Suzuki GS650L
1977 Kawasaki KZ650
1975 Kawasaki F7
1973 Honda CB175
r_figueroa is offline
post #11 of 20 Old Aug 21st, 2013, 7:39 pm
Re: Bouncy Handling
they are gas struts same as on a car, with the spring off it should be very hard to compress and when you let go the rod should slowly fully extend, they put really weak springs on the bike for a soft ride and with 50K miles on mine the springs were nearly compressed all the time very little stroke left, bottomed out easily, Hyperpro springs fixed mine and it actually leans when on sidestand
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
gary45 is offline
post #12 of 20 Old Aug 21st, 2013, 9:46 pm
Re: Bouncy Handling
So, what is the function of the oil in the rear shock?
Current:
2006 BMW K1200LT
2010 BMW R1200RT
Previous:
1999 BMW K1200LT
2007 Yamaha FZ6
1986 Suzuki GS550L
1985 Suzuki GS650L
1977 Kawasaki KZ650
1975 Kawasaki F7
1973 Honda CB175
post #13 of 20 Old Aug 21st, 2013, 10:31 pm
Re: Bouncy Handling
separate hydraulic device applying pressure to spring raising bike - preloading spring
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
gary45 is offline
post #14 of 20 Old Aug 22nd, 2013, 4:00 am Thread Starter
Re: Bouncy Handling
Thanks for that. A bit of research is clearly required before getting the wallet out. Which of the non-BMW are considered the best? Our local agent in the Surrey, UK cannot supply for at least 4 weeks claiming BMW have "a new system" which is causing supply difficulties. More likely they haven't paid their last invoice and are on stop!
post #15 of 20 Old Aug 22nd, 2013, 9:29 pm
Re: Bouncy Handling
A lot of LT'ers have changed over to Wilbers and love them... I'm one of them. Not the cheapest option by far, but makes a huge difference.
Your UK stockist might be http://wilberssuspension.co.uk/ or http://www.revsracing.co.uk/wilbers.php
As mentioned above, Ohlins or HyperPro (or just change the springs to HyperPro)... search the threads, there's a lot of discussion over the various types. There was also another 1 or 2 newer manufacturers in Europe somewhere... you'll probably find those names in recent threads on suspension .
post #16 of 20 Old Aug 23rd, 2013, 10:06 am Thread Starter
Re: Bouncy Handling
Am back on the autoroutes again...have adjusted the rear suspension and that has improved matters but it's not perfect..getting close tho.. so will have a look at the oil in the rear shock when I get back. Have suggested the wife might lose a few pounds off her ass but not sure if that went down too well! Thanks for the thoughts and advice on alternative shocks.
post #17 of 20 Old Aug 23rd, 2013, 11:48 am
deputy5211's Avatar
Re: Bouncy Handling
Refill the rear pre-loader and replace springs front and rear with the HyperPro. She will ride like a totally different girl (the LT, not the wife!).
Antony (Tripod)
Dallas' Northern Suburbs
and many, many others.
deputy5211 is offline
post #18 of 20 Old Aug 23rd, 2013, 4:18 pm
JNW003's Avatar
Cool Re: Bouncy Handling
I went to the HyperPro US distributor's website, and it looks like HyperPros for the LT include both the spring and shock. It doesn't look like they just sell the springs separately. What exactly are you replacing of the existing stock suspension components - is the stock preloader retained with the new HyperPros? Thanks!
JNW003 is offline
post #19 of 20 Old Aug 23rd, 2013, 6:31 pm
Re: Bouncy Handling
EPM Performance - you can buy just the springs
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
gary45 is offline
post #20 of 20 Old Aug 24th, 2013, 12:48 am
Razmataz's Avatar
Re: Bouncy Handling
And you're still alive! You must be quick!
BMW 1200 LTC 2002
Razmataz is offline
Handling of the new 2013 GS Hammam GS Series 10 Nov 2nd, 2013 2:13 pm
Looking for a GW/KLT handling comparison CharlieVT K1200LT 14 Dec 25th, 2008 3:26 pm
"Loose" Handling Fixed! Dude K1200/1300GT (The Next Generation) 1 Oct 18th, 2008 6:02 pm
Newer LT Handling cruisin92 K1200LT 5 Mar 19th, 2008 1:32 pm
low speed handling gpolakow K1200LT 25 Jun 20th, 2007 8:37 pm
