EHCS Removal - BMW Luxury Touring Community
post #1 of 9 Old Aug 10th, 2013, 12:34 pm Thread Starter
rattler50's Avatar
Exclamation EHCS Removal
I can't get the bike up on the centerstand. Can I remove the EHCS with the bike on the side stand?.........Thanks.........
2006 R1200RT
2005 K1200LT Ocean Blue
2003 K1200LTE Black
Totaled Oct 2, 2010
2006 Kawasaki Vulcan 2000
rattler50 is offline
post #2 of 9 Old Aug 10th, 2013, 1:53 pm
Re: EHCS Removal
Yes you can. The nut on the end of the shaft can be a challenge as you have to drop the stand down a bit to get on it. But everything else is fairly easy to do on the side stand. You can look at CWS's video here removal
post #3 of 9 Old Aug 10th, 2013, 2:10 pm Thread Starter
rattler50's Avatar
Re: EHCS Removal
Thanks. I got it off fairly easily. I took it apart and the motor spit out one of the brushes. It was full of oil so I'm gonna order the kit and overhaul the whole thing and get a new motor. That centerstand is quite handy when changing oil............
2006 R1200RT
2003 K1200LTE Black
Totaled Oct 2, 2010
post #4 of 9 Old Aug 11th, 2013, 3:55 pm
beerbiker21's Avatar
beerbiker21 is offline
post #5 of 9 Old Aug 11th, 2013, 9:19 pm
Re: EHCS Removal
Figure out where the oil came from, as in external or internal. There is a seal on the pump drive shaft that can be the source of an internal leak. Look at the cavity where that pump gear is and see if there is a coating of grease (normal) or a pool of oil (not normal). If there is oil you need one of those shaft seals as well.
post #6 of 9 Old Aug 12th, 2013, 6:57 am Thread Starter
rattler50's Avatar
Re: EHCS Removal
I ordered a new motor. Now I need to order the seals and Orings to completely overhaul the pump and cylinder. Anyone have a parts list handy?...........Thanks.
2006 R1200RT
2003 K1200LTE Black
Totaled Oct 2, 2010
post #7 of 9 Old Aug 12th, 2013, 1:26 pm
Re: EHCS Removal
These guys have a "kit" for the LT and it has one shaft wiper, on shaft seal and the two o-rings for the cylinder body. They get $25.00 for it. Just ask for the BMW kit for the center stand.
Allied Metric Seals and Fasteners Inc.
2 Wilson Drive
Unit 4
Sparta, NJ 07871
Phone: 973-383-2487
FAX: 973-383-3329 alliedme[email protected]
post #8 of 9 Old Aug 13th, 2013, 7:09 pm Thread Starter
rattler50's Avatar
Re: EHCS Removal
I ordered the kit today. I got it all cleaned up and ready to go back together. If this works, the total cost of the rebuild will be $90. The motor was $65 shipped and the kit was $25 plus freight. So it cold run around a hundred or slightly over. The only reservation I have is that the pump is very hard to turn when you tighten the bolts down. Not sure if that's gonna be a problem or not............
PS: The oil was very thin and black and nasty. It was nowhere near 150ml.
2006 R1200RT
2003 K1200LTE Black
Totaled Oct 2, 2010
post #9 of 9 Old Aug 13th, 2013, 7:42 pm
Re: EHCS Removal
Rattler, see this thread for a fix using paper as a gasket to enable you to tighten the pump nuts..... Has worked for me for a few years now. In fact it was my Dad ( old school mechanic ) that first thought of it when I had same problem.
http://www.bmwlt.com/forums/showthread.php?t=73988
EHCS flushing and elec. motor maintenance TSQUARED North West 1 Mar 26th, 2013 7:34 am
Brake failure and EHCS problem on same day Craigo17 K1200LT 12 Sep 26th, 2012 7:52 am
Bleeding/Flushing fluid in EHCS on 05+ LT's TSQUARED North West 2 Apr 27th, 2011 3:15 am
EHCS motor problem - solved. pozo_izquierdo K1200LT 2 Dec 4th, 2010 7:48 am
Most likely cause for EHCS not working? atps1234 K1200LT 4 Mar 11th, 2007 2:29 pm
