Supplies for Speedo correction? - BMW Luxury Touring Community
post #1 of 8 Old Aug 8th, 2013, 7:42 pm Thread Starter
Since I have the LT torn apart for a variety of things I'm working on, I figured I might as well perform the speedometer correction fix too. I'm having trouble finding the 24 ga solid copper conductor as called for in the instructions. I found 24 ga pretinned solid bus at Radio Shack......will this work? Where can I get the copper wire that is called for?
Jim_B is offline
post #2 of 8 Old Aug 8th, 2013, 7:47 pm
jers99lt's Avatar
Re: Supplies for Speedo correction?
As long as an electrical connection is made across the solder pads, it will work. Make sure all locations match or are jumped as in the H.O.W. picture. I did the mod and only jumped one location, per instructions, and the mod didn't work. I did another teardown looked again at the picture versus the back of my speedo and noticed my speedo needed to be jumped in two locations.
HTH,
Jer
Jerry Palma
85 R80RT 'Lady in Red'
08 535xi Space Gray metallic
09 328i Silver Convertable
17 X3 Glacier Silver metallic
jers99lt is offline
post #3 of 8 Old Aug 8th, 2013, 8:00 pm Thread Starter
Jer,
Did you have some old instructions that only called for one jumper? I looked at two different sets of instructions and both called for two jumpers.....one at the JB location and another at the JC location.
Now that you've completed the fix, is the speedo working as it should?
Jim
Jim_B is offline
post #4 of 8 Old Aug 8th, 2013, 9:53 pm
Goalie's Avatar
The fix works. Any strands of copper wire will work. The span is so small that when you solder them the wire will 'tin' all the way across and make the bridge anyway. Just snip a few strands off of any small gauge wire you have laying around, nothing special.
2002 K1200LT
Goalie is offline
post #5 of 8 Old Aug 8th, 2013, 10:48 pm
already answered...but a bit more detail.
"tinned" wire is (almost always) copper wire with a thin layer of solder already on it. It makes soldering a bit easier, probably a lot easier if you are a novice at it.
Almost all electric wire is copper. For very large wire (household feed wire), you sometimes see aluminum, for very fine wire, you sometimes see gold or silver (actually, you don't see -- it's buried inside components). I'm sure there are exceptions, but they ain't common. (Different story for non-electrical wire, like craft wire, but the last spools of that I saw all said, "not for electrical use" -- and for this application, if you could get the solder to stick, it would work Just Fine.)
The thickness won't matter either, not for the tiny amount of power being carried.
NickHolland is offline
post #6 of 8 Old Aug 11th, 2013, 11:55 am
jers99lt's Avatar
Jer,
Jim
Hi Jim,
You're probably correct in what you read. I suffer from being an electronic tech in a past life and thought each pad had its own identifier, so JB - JC was a single cross connection. I was a newby owner at the time and was very intimidated with the whole project. Wrenching is not something I'm that experienced with. Glad to see you, and probably everyone else, noticed it was two seperate jumper locations.
Jer
Jerry Palma
jers99lt is offline
post #7 of 8 Old Aug 12th, 2013, 1:11 pm Thread Starter
Smile Re: Supplies for Speedo correction?
After taking the speedo apart and seeing how tiny everything was, I found it much easier (and cheaper) to just take the speedo to a local TV repair shop. The tech soldered some copper wire in place for me. He soldered both jumpers in about 30 seconds. I'm sure it is a much better job than I would have done and it cost me a whole $5. Can't wait to get it on the highway and see if it worked.
Jim_B is offline
post #8 of 8 Old Aug 12th, 2013, 1:20 pm
That is great news and a good idea for those that are not familiar with soldering small stuff!!Hope you like the change.
Stock Market Correction 1LIFE2LIVE Chit Chat 7 Aug 18th, 2011 8:20 pm
HOLD the praise on Speedo Correction! hallzee K1200LT 10 Jul 17th, 2010 5:40 am
Speedo Correction - it works! hallzee K1200LT 9 Jul 15th, 2010 8:21 pm
Speedo Correction old1951 K1200LT 0 Oct 28th, 2007 8:14 pm
speedo correction for older RT retiredjj RT Series 0 Sep 13th, 2006 10:18 pm
