Battery change suprize - BMW Luxury Touring Community
post #1 of 6 Old Aug 6th, 2013, 9:32 pm Thread Starter
Pardon what might seem utter mechanical incompetance, but...
My older battery died sometime while I was away this summer. Replaced it today.
Upon connecting the battery, the starter immediately engaged. Disconnected battery. Turned key to off/lock, removed key and set kill switch to 'kill'. Reconnected battery - starter trying to kick over (this time no ignition and I didn't jump quite as high).
What am I missing?
Islandguy is offline
post #2 of 6 Old Aug 6th, 2013, 9:37 pm
johnbaker15's Avatar
Re: Battery change suprize
What am I missing?
The relay for the starter has welded its contacts together.
John Baker
2005 BMW K1200LT
1979 Suzuki GS1000E
1978 Honda CB350
1975 Suzuki GT380
johnbaker15 is offline
post #3 of 6 Old Aug 6th, 2013, 10:12 pm
patrick2000's Avatar
There is a backyard mechanics way of getting it to release, but I cannot remember it . Something like holding the starter button down and then connecting the battery? One of the oldtimers will surely chime in soon.
EDIT
OK...found this by doing a search http://www.bmwlt.com/ubbthreads/show...&sb=5&o=0&vc=1
patrick2000 is offline
post #4 of 6 Old Aug 6th, 2013, 10:18 pm
hdironhead78's Avatar
I'm not exactly an old-timer, but I've had the problem. Make sure the battery has full juice, and when you connect the battery, hit your starter button a bunch of times quickly; it will disengage; and you'll be riding.
The consensus is that you should replace the starter relay, its a good idea even though it still functions. (I'm guilty of 'forgetting' to replace the starter relay, and its been functioning fine for the last 15k miles or so.)
Paul L.
Upstate NY
2002 BMW K1200LTC
1998 Buell Thunderbolt S3T
1978 HD Sportster
1975 HD FXE
1978 Honda CB 750F Super Sport
hdironhead78 is offline
post #5 of 6 Old Aug 7th, 2013, 5:33 pm
james216's Avatar
Where is the starter relay located?
2004 K1200LT. Big Mama
I'm a 4 percenter.
james216 is offline
post #6 of 6 Old Aug 7th, 2013, 5:46 pm
deanwoolsey's Avatar
Right side of the bike, underneath most things and just about in the middle of everything else. If you look just in front of the battery you'll see the end of the alternator. I believe the relay is just in front of and close to the top of the alternator, but enclosed in a plastic box.
deanwoolsey is offline
battery change bosko K1200LT 5 May 20th, 2010 10:21 am
Any other battery change surprises? Lare K1200LT 13 Sep 8th, 2008 10:08 am
Battery Life Tailwheel Batteries, Chargers, & Electrical 6 Jul 22nd, 2008 5:37 pm
