2002 headlight wiring - BMW Luxury Touring Community
post #1 of 5 Old Aug 5th, 2013, 11:02 pm Thread Starter
Does anyone know where the power for headlight is routed from. Taillight works but no power to headlight Or a link to a diagram I haven't been able to find yet. I was fixing brown wire ground now I've lost power to highbeam I haven't tested lowbeam but its not working. Thanks ahead of time to the best ppl on the net.
Mclane26296 is offline
post #2 of 5 Old Aug 6th, 2013, 1:44 pm
BecketMa's Avatar
Re: 2002 headlight wiring
If you didn't disconnect the battery check the fuses.
Since the headlight comes on when you turn the key on, you can use any line that goes hot when you turn the key on. The low beam stays on when the high beam is on.
I'll look up what else is on the headlight fuse.
BecketMa is offline
post #3 of 5 Old Aug 6th, 2013, 2:02 pm
BecketMa's Avatar
Front turn signals, horns, high and low, side light all share the same negative line straight to the battery.
high beam, low beam and high beam indicator light positive line goes to both multi function switches.
Right mulyifunction switch is fuse block 2, fuse 6, box 1, fuse 4 and box 3 fuse 12
BecketMa is offline
post #4 of 5 Old Aug 6th, 2013, 2:14 pm
BecketMa's Avatar
looks as if you should check box 1, fuse 1? which is 4 A and not fuse 4. :-)) for the headlight?
BecketMa is offline
post #5 of 5 Old Aug 6th, 2013, 2:57 pm
Jim_McG's Avatar
Here's the wiring diagram
File Type: pdf Wiring Diagram - 2001-2005 LT Frame.pdf (249.3 KB, 103 views)
Jim
Jim_McG is offline
Wiring diagram -2002 Lt needed. JohnWray K1200LT 9 Jun 22nd, 2017 8:49 am
Wiring diagrams for 2002 K1200LT Tat_n_Telle K1200LT 10 Feb 24th, 2014 8:20 am
2002 BMW K1200LT Headlight problem DesertCoyote K1200LT 10 Sep 17th, 2010 2:43 pm
2002 gps wiring colors which is which? dodgeman88 K1200LT 4 Jan 25th, 2007 12:07 pm
