2005 k1200lt battery connection pic or explanation - BMW Luxury Touring Community
post #1 of 4 Old Jun 2nd, 2013, 10:35 am Thread Starter
I am looking for a picture or good explanation of the - and + battery connections on my bike. I recently had some work done and thing the battery connections may not be correct. My electronics are acting wonky. Display is erratic, center stand light flashing, reverse not working. I have a black wire with a yellow tracer and a faded red sleeve connected to the neg side of my battery?
ScottNSLT is offline
post #2 of 4 Old Jun 2nd, 2013, 11:07 am
norton's Avatar
Re: 2005 k1200lt battery connection pic or explanation
I changed my battery recently and the positive wires are toward the front of the bike. so the batteries positive should also be toward the front.
norton is offline
post #3 of 4 Old Jun 2nd, 2013, 11:53 am
jaxbobg's Avatar
Surprised you don't have more problems with computer and displays. On my 2009 the black/yellow is on the pos (+). terminal.
I only have 3 wires on each terminal block... one (+) and one (-) run to Centech AP2 fuse block for accessory connections. I think the other two on the + side are for the starter and electrical harness. Not sure where the other 2 ground side wires go.
jaxbobg is offline
post #4 of 4 Old Jun 2nd, 2013, 12:02 pm
A Stock unmodified 05 will have a single metal strap on the negative that feeds a grounding tie point behind the battery where there is a collection of brown wires +one Black w/yellow stripe and a brown sleeve (this is for the reverser controller {RC}. The positive should have two wire bundles sheathed in black with red sleeves. One is a Black w/yellow stripe and a red sleeve (for the RC). The other is a collection of several wires into one terminal. I have three other wires on my positive that I have added fuse boxes with and other accessories.
The last time I helped some one with crazy operation of "stuff" we found that a brown wire had been connected to the frame vs. the tie point behind the battery. This causes all kinds of grief as BMW does not use the frame as a ground return.
Replacement Battery for 2003 K1200LT curtamus K1200LT 22 Jun 30th, 2012 5:05 pm
Swap 2005 engine to 2002 K1200LT? john_loucks K1200LT 8 May 4th, 2012 4:14 pm
2005 K1200LT Will Not Start LarryD K1200LT 10 Nov 27th, 2011 7:39 pm
Which one to buy ? pre 2005 vs. post 2005 k1200lt? beemermike K1200LT 25 Oct 13th, 2010 11:06 am
Solar Battery Charger for the K1200LT??? JohnnyBSurfing Batteries, Chargers, & Electrical 11 Feb 4th, 2007 12:53 pm
