What exactly does it do? - BMW Luxury Touring Community
post #1 of 15 Old Mar 19th, 2013, 7:38 pm Thread Starter
norton's Avatar
I'm talking about the hydraulic knob under your seat that supposedly adjusts your suspension. I don't see how it could affect the spring pre-load for carrying heavier weights because screwing in the knob doesn't affect the spring at all it is pushing hydraulic fluid some where to adjust something. So it must only affect the dampening. Anyway would one of you mechanical guru's explain in detail so I know what it does, Thanks
norton is offline
post #2 of 15 Old Mar 19th, 2013, 8:06 pm
Re: What exactly does it do?
If it is still full of oil it is pushing a ring piston increasing the pre-load on the spring. If you don't see movement at the top of the spring it needs to have the oil replenished.
post #3 of 15 Old Mar 19th, 2013, 10:57 pm
mycamel's Avatar
what part of the Clymer manual is this in? trying to figure out what the technical name is and where it describes the oil levels, etc.how do you check it for fluid level? and what's the fluid in it?
Mike Hammel (My Camel) [WB9GMO/4]
2002 K1200LT-E
1998 ACE Burgundy (now 'retired')
1998 ACE Yellow/Black Tourer (now 'retired')
19?? Suzuki 500 (now 'retired')
1962 modifed 49cc>~55cc Sears MoPed (LONG 'retired')
US Army Security Agency 0582L68 ('64-68)
moderator and owner:
Retired from the business world (finally--sigh --poor and proud)
Georgia Patriot Guard Riders
Roswell, GA
mycamel is offline
post #4 of 15 Old Mar 20th, 2013, 6:12 am
Craigmri's Avatar
Mine is not working either. I would love to know how to service this.
Craig
Brooksville FL
2006 BMW K1200LT
Craigmri is offline
post #5 of 15 Old Mar 20th, 2013, 6:26 am
Good read starting here.
post #6 of 15 Old Mar 20th, 2013, 6:38 am
StClair's Avatar
or this:
http://www.bmwlt.com/forums/showthread.php?t=8406
Cheers, StClair
1977 Honda CB400F Super Sport
2007 G650 Xcountry
2008 K1200LT SE
1990 Kawasaki GTR 1000 (Concours) + Hedingham XL
1952 Francis Barnett Falcon 58
StClair is offline
post #7 of 15 Old Mar 20th, 2013, 8:17 am
johnbaker15's Avatar
Originally Posted by Dick
Dick,
Cut and paste got you on this one.
John Baker
2005 BMW K1200LT
1979 Suzuki GS1000E
1978 Honda CB350
1975 Suzuki GT380
johnbaker15 is offline
post #8 of 15 Old Mar 20th, 2013, 9:57 am
Originally Posted by johnbaker15
Dick,
Yeppir, sure did, John. Thanks for the headsup. Still getting used to an iPad touchie thang over my good laptop keyboard. My bad.
I think I fixed it - thanx again, John.
post #9 of 15 Old Mar 20th, 2013, 11:00 am Thread Starter
norton's Avatar
Thanks for the explanation, after reading the different posts it appears mine is low on fluid so I will attempt to fill it as the procedure seems simple enough. Thanks Guru's
norton is offline
post #10 of 15 Old Mar 20th, 2013, 11:23 am
blueknightga6's Avatar
You won't find it in the Clymer manual. But look at Dick's post and go to message 16 if it doesn't take you there. It has instructions along with pictures. I do mine at least twice a year. Sometimes it needs oil, sometimes not. I use hydraulic jack fluid available at any auto parts store.
"Uncrank" it all the way and ride around the neighborhood, especially two up and you'll see what it does. Then crank it down and do it again. Then you really see the difference. Uncranked it feel like you have a flat tire.
Chris Ehlbeck
blueknightga6 is offline
post #11 of 15 Old Mar 20th, 2013, 11:29 am
The key to making this work is to push the follower plate in through the hole. That will allow maximum fluid to be added.
post #12 of 15 Old Mar 21st, 2013, 11:13 am Thread Starter
norton's Avatar
Where does the fluid go if it is a closed system?
norton is offline
post #13 of 15 Old Mar 21st, 2013, 11:26 am
Jim_McG's Avatar
That seems to be a mystery. I have to turn mine in about 1.5 turns before feeling resistance and that's where I left it for solo riding without additional load. I assume cranking in more preload will raise the rear end / seat height which I want to avoid. Is that right?
Jim
Jim_McG is offline
post #14 of 15 Old Mar 21st, 2013, 11:36 am
It's something we've been wondering for a long time.
Chris Ehlbeck
post #15 of 15 Old Mar 21st, 2013, 7:19 pm Thread Starter
norton's Avatar
Does anyone know how much it will pre-load the spring ie: 1/4" 3/8" ?
norton is offline
