K1200LT Rear Brake Indexing for Rebuild Reference - BMW Luxury Touring Community
post #1 of 5 Old Mar 5th, 2013, 1:05 pm Thread Starter
I'm in the process of removing my rear drive to send it away for rebuild and am not sure about how to index the rear brake as per the K1200LT service manual. Is there a simple way to do this? What marks on the disc / rear drive should I use, given that during rebuild the rear drive will be handled quite a bit and may remove any marks I make beforehand?
As a reference here is the verbiage from the manual on page 34.9:
"Mark the installed position of the brake disc on the
rear wheel drive, so that vertical runout of the sensor
ring is not altered."
Any help is greatly appreciated.
Bill Edwards
Boerne, TX
1jusbill1 is online now
post #2 of 5 Old Mar 5th, 2013, 4:56 pm
Enjoy The Ride
saddleman's Avatar
Re: K1200LT Rear Brake Indexing for Rebuild Reference
It does not to be indexed. It also doesn't need any Locktite on the threads because the bolts can't go anywhere when the wheel is installed.
Dave Selvig
2004 Black LT
2000 Canon Red LT
saddleman is offline
post #3 of 5 Old Mar 5th, 2013, 5:27 pm
deanwoolsey's Avatar
I agree with Dave, but if you feel the need to mark it, just get a center punch and choose a bolt hole. Then just punch the hub and the ring.
deanwoolsey is offline
post #4 of 5 Old Mar 5th, 2013, 5:44 pm Thread Starter
Thanks guys!
Bill
post #5 of 5 Old Mar 5th, 2013, 6:50 pm
Didn't index ole Toad's ring and didn't Loctite the bolts. BTW - I'll ping Woody to remind him to bring the cut-out socket with him tamale at lunchtime. I've got a 30MM socket if you need one.
Rear brake issues kamike K1200LT 29 Sep 16th, 2014 8:26 pm
rear brake disk problems k1200lt giokas K1200LT 1 Jul 18th, 2008 1:10 pm
'04 LT and Squealing Rear Brake...yeah another thread petevandyke K1200LT 10 Nov 3rd, 2007 1:46 pm
No rear brake??? JCarver K1200LT 9 Aug 13th, 2007 10:36 am
Rear brake dragging '00, bleeding abs? waynelt K1200LT 2 Aug 6th, 2007 2:12 pm
