05 Trans Ratios - BMW Luxury Touring Community
post #1 of 17 Old Mar 1st, 2013, 7:32 am Thread Starter
rattler50's Avatar
05 Trans Ratios
Does the 05 have a lower ratio in high gear than the previous trannies? It seems like the ratio is not very high when shifting compared to the lower gears. It's seems like it could use a higher gear ratio in 5th..............
2006 R1200RT
2005 K1200LT Ocean Blue
2003 K1200LTE Black
Totaled Oct 2, 2010
2006 Kawasaki Vulcan 2000
rattler50 is offline
post #2 of 17 Old Mar 1st, 2013, 7:43 pm
Re: 05 Trans Ratios
Here they are:
Pre 05 Post 04
1 3.864 3.85
2 3.022 3.022
3 2.393 2.393
4 1.819 1.827
5 1.511 1.523
post #3 of 17 Old Mar 2nd, 2013, 5:55 am
K100Dennis's Avatar
Re: 05 Trans Ratios
Interesting numbers John, I wonder what the actual gear teeth numbers are, as for the differences in the ratios for first and fifth to be that miniscule I would think a large number of teeth would be required (to get such a small difference).
Dennis
1987 Yamaha TY250R
1991 Aprilia Climber 280
1988 K100RT (the pack horse)
K100Dennis is offline
post #4 of 17 Old Mar 2nd, 2013, 7:21 am
bikerj's Avatar
Re: 05 Trans Ratios
Originally Posted by jzeiler
Here they are:
Pre 05 Post 04
1 3.864 3.85
2 3.022 3.022
3 2.393 2.393
4 1.819 1.827
5 1.511 1.523
Technically John, it sounds like your headings are mixed up. If it was accurate, then what you're saying is there is a period of time between 04 and 05 where they could have either combination of ratios. Is this in fact correct?
Jeff
Big D is my neck of the woods
08 HD wide glide
prior:
07 HD XL1200C (sold!
78 KZ750 twin
76 CB750F
71 CL175 Scrambler
73? Yamaha 100 enduro
[SIGPIC][/SIGPIC]
bikerj is offline
post #5 of 17 Old Mar 2nd, 2013, 11:57 am
Re: 05 Trans Ratios
Not really 1999-2004 is pre 05 and 2005-2009 is post 04. Where is the gap?
But I did wrestle with if that helps.
post #6 of 17 Old Mar 2nd, 2013, 12:02 pm
Re: 05 Trans Ratios
Start counting...
ID:	37834   Click image for larger version
ID:	37835   Click image for larger version
ID:	37836   Click image for larger version
post #7 of 17 Old Mar 2nd, 2013, 1:48 pm
bikerj's Avatar
Re: 05 Trans Ratios
I wonder how hard it would be for someone to change the ratio, such as for the fifth gear by installing a custom gear, or would more than one have to be changed?
I'm guessing the diameter of the gear would be the main dimension to figure out, besides the number of teeth.
Jeff
08 HD wide glide
prior:
78 KZ750 twin
76 CB750F
71 CL175 Scrambler
[SIGPIC][/SIGPIC]
bikerj is offline
post #8 of 17 Old Mar 2nd, 2013, 7:40 pm
Re: 05 Trans Ratios
It looks like there is room for changes to ratios except for 1st and 2nd. Not enough room for a lower first and second is trapped in the case machining.
post #9 of 17 Old Mar 3rd, 2013, 12:44 am
K100Dennis's Avatar
Re: 05 Trans Ratios
Yes, that's what we all need, a lower first gear, but unfortunately it isn't possible. If it were possible most of our clutch woes wold be gone. K100's never suffered from clutch burning like the K12's, and you could ride a trials section in first.
Dennis
1987 Yamaha TY250R
post #10 of 17 Old Mar 3rd, 2013, 8:33 am Thread Starter
rattler50's Avatar
Re: 05 Trans Ratios
The reason I asked is because when I blip the throttle to downshift to 4th it seems the engine is way ahead of the gear change. When I blip it in the lower gears it seems to mesh right up when I release the clutch. I don't remember it being like that on the 03. Maybe it's just me.........
2006 R1200RT
2003 K1200LTE Black
Totaled Oct 2, 2010
post #11 of 17 Old Mar 3rd, 2013, 2:47 pm
deanwoolsey's Avatar
Re: 05 Trans Ratios
Wasn't there a gear ratio change in the FD as well? I wonder what the effect would be to swap out an early and late model FD, realizing this would require some machining on the case. John? Anybody else?
deanwoolsey is offline
post #12 of 17 Old Mar 3rd, 2013, 4:15 pm
Enjoy The Ride
saddleman's Avatar
Re: 05 Trans Ratios
The difference on a 2000 LT & a 2004 LT with the different ratios is the 2000 LT runs about 300 rpm less in 5th gear.
Dave Selvig
2004 Black LT
2000 Canon Red LT
saddleman is online now
post #13 of 17 Old Mar 3rd, 2013, 5:04 pm
Re: 05 Trans Ratios
I was just thinking in terms of the 2.62 ratio vs the 2.75 in the older units. I'm not experienced enough to know if that would feel like much of a difference to the driver.
The reason I brought it up is that some Honda VTX 1800 riders use a FD from a VTX 1300 because of the gear ratio difference between the two. Apparently the two will swap out on the VTXs.
post #14 of 17 Old Mar 3rd, 2013, 6:13 pm
norton's Avatar
Re: 05 Trans Ratios
The LT could definitely benefit from a lower first and a taller fifth gear. Common John I'd be the first to buy it when you figure out how to do it.
norton is offline
post #15 of 17 Old Mar 3rd, 2013, 9:51 pm
Re: 05 Trans Ratios
I agree 100%. The too tall first gear is my biggest complaint about the LT by far. The too short 5th is somewhat of a nuisance, but not nearly as big a pain as the too tall first combined with a dry clutch. Dumb design choice by BMW.
post #16 of 17 Old Mar 3rd, 2013, 11:50 pm
K100Dennis's Avatar
Re: 05 Trans Ratios
I agree, I'd really like a lower first gear, but it requires a physically larger diameter driven gear and as John Z states, there isn't sufficient space within the standard casing to allow it. However, it may be possible to weld and machine the gearbox casing to provide the required clearance, but someone would need to be real keen to take on such a project. Plenty of engineering shops specialise in gear manufacture, so that wouldn't be a show stopper. For the Aussies, google Carr Gears as an example. A sacraficial gearbox is what is required.
Dennis
1987 Yamaha TY250R
post #17 of 17 Old Mar 4th, 2013, 12:43 pm
Re: 05 Trans Ratios
If first gear is good up to about 62, why would you want a taller 5th? The only time I am in 5th is on the interstate.
Trans & FD oul fill level/quantity Boatzo K1200LT 5 Aug 3rd, 2010 8:50 am
Trans & Final Drive Maint. fwkraft K1200LT 31 Jul 11th, 2010 10:37 am
Final Drive and Trans Oil hognot K1200LT 2 Jun 11th, 2009 8:12 pm
Dealer computer/factory trans reset? yechave K1200LT 5 Dec 18th, 2007 2:05 pm
trick tool 3/8 in rod coupler (trans plug rep.) zimbazi K1200LT 8 Apr 25th, 2006 11:21 pm
