08 final drive in an 02 - BMW Luxury Touring Community
post #1 of 12 Old Feb 28th, 2013, 12:37 pm Thread Starter
I found an 08 final drive on ebay at a reasonable price , with 20,876 miles on it. My question is: will it work on an 02 lt?
02 K1200LTE (103K)
01 Honda Valkyrie (49K)
1998 Goldwing Aspencade (58K)
65 Chevelle coupe
USAF, E7 retired
(509-760-6382) if you are in the area and need help
olddog1946 is offline
post #2 of 12 Old Feb 28th, 2013, 12:44 pm
dougholck's Avatar
Re: 08 final drive in an 02
Why not rebuild yours?
96K on my origional 02 FD and begining to think rebuild but I do have an 03 spare off a trike conversion just in case.
When/if you change FD be sure to change Pivot Bearings also.
Doug Holck
Lodi, Ca
I don't always ride motorcycles,
but when I do I prefer BMW's.
Ride safely my friends
3 Continents -10 Countries - 50 States
02 K1200LTe
04 1150GS Adventure
08 Suzuki DR650
CCR 05, 06, 07, 08, 09, 10, 11, 12, 13, 14
See you 2015 in Coeur d' Alene, Idaho
BMW MOA 109760
AMA Charter Life Member 518333
International Fellowship of Motorcycling Rotarians
HDDC POSSE
dougholck is offline
post #3 of 12 Old Feb 28th, 2013, 1:21 pm
deputy5211's Avatar
I have a low mileage PRE-05 FD that I would trade for the '08 if you would like, just under 20k on it. That would give me a spare for my '05 and a compatible FD for your scoot.
PM for contact details if you want to discuss further.
Antony (Tripod)
Dallas' Northern Suburbs
and many, many others.
deputy5211 is offline
post #4 of 12 Old Feb 28th, 2013, 4:51 pm
deanwoolsey's Avatar
Contact Tony as they do not interchange.
deanwoolsey is offline
post #5 of 12 Old Feb 28th, 2013, 5:44 pm
Enjoy The Ride
saddleman's Avatar
2002 to 2009 FD's are the same part number.
Dave Selvig
2004 Black LT
2000 Canon Red LT
saddleman is offline
post #6 of 12 Old Feb 28th, 2013, 6:10 pm
Nope. Just checked the microfiche. 2004 and up uses a different case. I believe the difference is that 2003 and before use a speedo sensor in the FD and the 2004 and up use a speedo input from the tranny or ABS, not sure which. Then again, I try to be incorrect at least a couple of times a day.
post #7 of 12 Old Feb 28th, 2013, 6:50 pm
Enjoy The Ride
saddleman's Avatar
1999 to 01 2001 part # 33112333164 These have the speed sensor in the FD & have the Brembo brake caliper.
After 01 2001 to 2009 part # 33117661909 These FD's don't have the speed sensor hole & the gear ratio is different. This is also when the linked brakes came out & the caliper has BMW on it.
Dave Selvig
2004 Black LT
2000 Canon Red LT
post #8 of 12 Old Feb 28th, 2013, 6:54 pm
My mistake. Didn't read the fine print. Hate it when that happens.
post #9 of 12 Old Feb 28th, 2013, 9:16 pm
Dave's correct even if he does drive on studded tires .
post #10 of 12 Old Mar 1st, 2013, 6:47 am
CharlieVT's Avatar
Saddleman is correct. BMW states that the final drives changed with a a build data of 01/01.
The essential changes are the presence of a hole for mounting the speedometer sensor in the pre-02 models. Later models lack this hole. Also as noted by Saddleman, the pinion gear/crown gear set ratio was changed.
Since your bike is a 2002, presumably is has the later type final drive that does not have a hole for a speedometer sensor. After 01/01 the speedometer input comes from the rear wheel ABS sensor.
Here's a pic of a pre-02 final drive:
(Note the back sensor on the final drive housing. If your bike has this, a 2008 FD will not work.)
Here's a pic of a post 01/01 final drive:
Name:	pre 02 final drive.jpg
ID:	37817   Click image for larger version
Name:	Post 02 final drive.jpg
CharlieVT is offline
post #11 of 12 Old Mar 1st, 2013, 1:04 pm
JoeTerry's Avatar
He needs another set with bigger studs and should go tear it up on a frozen lake.
So just to stir the pot, what kind of FD oil do you use when it's below 20F Dave?
Just Ride
JoeTerry is offline
post #12 of 12 Old Mar 1st, 2013, 4:50 pm
Enjoy The Ride
saddleman's Avatar
I use the oil that it came with. I drain it, look for flakes & then reinstall the same oil.
Dave Selvig
2004 Black LT
2000 Canon Red LT
What to do with a "used" FD jers99lt K1200LT 23 Dec 9th, 2011 11:31 am
HELP NEEDED - Final Drive cccpastorjack K1200LT 20 Aug 2nd, 2009 8:57 am
Final Drive murray K1200LT 22 Sep 28th, 2008 10:02 am
R1100RT Final Drive Oil Leak markbreen Other R-Bike Discussion 3 Jul 12th, 2006 10:11 am
