new brake disc sensor ring must be re-marked? - BMW Luxury Touring Community
post #1 of 6 Old Feb 14th, 2013, 5:08 pm Thread Starter
Today I pulled the rear wheel for a tire change. And figured I would install my ebc rotor to get rid of the cowbell sound. All went well but I have a question. In the manual it says if you install a new brake disc the sensor ring must be re-marked? What does this mean and how do I do it?
oosel is offline
post #2 of 6 Old Feb 14th, 2013, 5:17 pm Thread Starter
Re: new brake disc sensor ring must be re-marked?
ok I read a little further in the manual and found my answer.
• Measure radial runout round the entire circumference
of the ABS sensor ring.
e Caution:
If replacement parts are fitted, the sensor ring must
be re-marked; remove the old mark.
• With a paint pencil, make a permanent mark at
the point on the ABS sensor ring at the greatest
distance from the ABS sensor.
• Installation is the reverse of the removal procedure:
pay particular attention to the following.
• Check/adjust ABS sensor gap.
X Tightening torque:
ABS sensor .................................................. .. 4 Nm
I have the feeler gauge but not the dial gauge or extension. How important in this step? Is there a way to do it without the special tools?
And how do I adjust the gap?
oosel is offline
post #3 of 6 Old Feb 14th, 2013, 5:52 pm
deanwoolsey's Avatar
The ABS sensor gap must be within the specs printed on the side/top of your final drive. Ideally it will be within spec all the way around the ring as it is turned. If it is too far out of spec it will trigger an ABS fault. It is adjusted using shims which fit between the sensor and the FD case. Setting the gap can be a problem if you set it in the wrong spot as this can cause the ring to contact the sensor. Find the spot where the ring is closest to the sensor and set the gap at that spot, therefore the "mark" on the ring.
deanwoolsey is offline
post #4 of 6 Old Feb 14th, 2013, 6:23 pm Thread Starter
Thank you, that sounds simple enough.
oosel is offline
post #5 of 6 Old Feb 14th, 2013, 7:54 pm
Just backwards. Set the gap at the farthest point as you don't want the sensor to lose sight of the ring. Then roll it around to make sure it doesn't hit ( don't worry it won't).
post #6 of 6 Old Feb 14th, 2013, 9:30 pm
I can't deny doing it backwards. I set mine at the high point with the gap at the narrow end of acceptable. I'm sure John has it right.
Another Brake Problem and a Near Miss chuckle K1200LT 31 Mar 14th, 2016 11:56 am
Final drive replaced last November and still??? nearmisses K1200LT 11 Nov 17th, 2010 11:19 am
rear brake disc simon2611 K1200LT 0 Nov 4th, 2010 11:14 am
Brake Question chuckle K1200LT 13 Jun 30th, 2010 3:36 pm
K1200LT rear brake disc cherryman K1200LT 21 Jun 4th, 2008 8:54 pm
