Any long term success rebuilding center stand? - BMW Luxury Touring Community
 1Likes
  • 1 Post By smahon
post #1 of 25 Old Feb 9th, 2013, 3:09 pm Thread Starter
smahon's Avatar
So the site has sevral descriptions of people attempting electric center stand rebuilds along with procedures, but has anyone had any long term success doing it? Mine is nearly toast; takes 3-4 tries to lift the bike.
'15 GTLE
smahon is offline
post #2 of 25 Old Feb 9th, 2013, 10:25 pm
PATTERSON's Avatar
Re: Any long term success rebuilding center stand?
I rebuilt mine last summer....replaced the seals and wiper after cleaning every little thing on it. Took me 3 or 4 tries before getting the fluid level right.......and I am now very happy with it. If you get the seals for lower that $50 for the pair let me know. I'd like to have a spare set ...."just in case". I probably have something like around 8,000 miles on it now.
Good luck
Pat
Patterson/USAF1....'05 LT
and the little guy behind me is the world famous "Marty Hill"
Never look into a lazer with the remaining eye
363K on BMW's
PATTERSON is offline
post #3 of 25 Old Feb 10th, 2013, 1:31 pm
rowie's Avatar
I'm well on the way to needing something myself - my EHCS is pretty slow now. I understand the bulk of the issues tend to be fixed by getting the fluid level exactly right, so that will be my first port of call. I have some searching to do to find a suitable "how to".
BMWMOA member
Current rides:
Prior rides:
Suzuki GS425E (Australia)
Suzuki T250R (Australia)
rowie is offline
post #4 of 25 Old Feb 10th, 2013, 3:58 pm
I always have the seals and spare motors in stock. None of my rebuilds have come back. Mine is still going strong as well. It is not rocket science (I work in Huntsville AL a place with more Rocket PhDs than any where else in the country).
post #5 of 25 Old Feb 10th, 2013, 4:58 pm
..and I'm just a garage hack who has rebuilt mine several times, and now I think I've got it right also. Its working like a dream again since last rebuild.
I probably went way too far the first time and stripped everything completely apart as in Ari & Joe's rebuild instructions. Only replaced 1 of the seals as I couldn't find all the right ones, but I've had no leak problems from that.
I would recommend, if its not leaking, the first thing to do would be flush the oil and replace it without opening the thing up, making sure you get the advised amount in (John Z's recommendation is damn good) and also maybe drop a new motor on it if its over say 3-4 years old and gets used a lot. That little motor builds up a lot of carbon inside it, some guys have reported successfully replacing the brushes, but not me.
That's probably gonna cost you about $40-$50 all up and would minimise the chance of doing something that might cause further grief, like a blown seal or cracked casing.
Have fun!
post #6 of 25 Old Feb 11th, 2013, 8:16 am
cwo
cwo's Avatar
JZEILER rebuilt mine last year, and it works perfect. However, after watching him do the rebuild I wouldn't try it myself.
Chris Ogle
Life is ephemeral. Don't waste it lookin up big words.
cwo is offline
post #7 of 25 Old Feb 11th, 2013, 11:44 am Thread Starter
smahon's Avatar
Well, I figure it'll be a good winter project, though winter around here is intermittant and I find my self riding to work a lot. Will the bike run with the center stand off?
'15 GTLE
smahon is offline
post #8 of 25 Old Feb 11th, 2013, 4:28 pm
Absolutely... not a problem at all.
Just remember to park sensibly so you can use the sidestand.
Mind you, if you do the minimum amount that'll probably get it running fine again (oil & motor) that'll take a couple of hours at most before its back on the bike.
post #9 of 25 Old Feb 11th, 2013, 6:23 pm
You don't have to remove the center stand to remove the actuator. The bike won't even miss it as there is no feedback to the controller.
post #10 of 25 Old Feb 12th, 2013, 1:14 am Thread Starter
smahon's Avatar
So that's interesting. Right now the bike is on the lift, on the center stand, for other maint. Does this mean I can do the rebuild with the center stand deployed?
'15 GTLE
smahon is offline
post #11 of 25 Old Feb 12th, 2013, 3:40 am
John corrected my broad mis-statement :-)
Remove the EHCS actuator, leave the centre stand itself on the bike.
Yep, thats easiest way to do it... while its up on the stand.
Here's a clip showing you what to undo...
Some additional info...
You can remove that central cylindrical support piece the rod goes through to clean it up, beware there's a thin shim in there also. Regrease the support and reinstall.
But if you are going to leave the actuator itself off while riding, good idea to put a small bolt through the rod support hole and a nut on the end (in place of the rod) so the support can't fall out.
post #12 of 25 Old Feb 12th, 2013, 11:41 am
Yes, what Chris did. You don't need to do as much as Joe had in his write up and please don't go as far in the teardown as Ari did, at least don't if you will be sending it to me when you can't get it back together.
post #13 of 25 Old Mar 8th, 2013, 6:04 pm Thread Starter
smahon's Avatar
OK, I am ready to start this project and I found the motor on eBay, $29 shipped. Check.
In Joe's article he states he sourced the seals as follows:
I purchased Seals and O-Rings from:
Allied Metric Seals and Fasteners Inc.
2 Wilson Drive
Unit 4
Sparta, NJ 07871
Phone: 973-383-2487
FAX: 973-383-3329
[email protected]
I spoke to “Bill” In March 2008, seals were $4.00 per and O-Rings $0.50.
Minimum order Qty was 4 Seals and O-Rings
Is this still the only way to get them? I've read no less than 10 threads where someone asked where to get these things without anyone ever answering, so now I too resort to asking.
'15 GTLE
smahon is offline
post #14 of 25 Old Mar 8th, 2013, 9:18 pm
That is your best bet. I am using some from a Portland supplier but I have had to machine the seal backup ring as the seals are a bit thicker and the stock one will not fit. I also bought quite a few before I found that out.
post #15 of 25 Old Mar 8th, 2013, 10:42 pm
DanMartin's Avatar
I can sell you a pair for $12
DanMartin is offline
post #16 of 25 Old Mar 9th, 2013, 11:45 am
JWA
JWA's Avatar
The bike won't miss it but my tests on the workbench for my total conversion has taught me that the controller does in fact check for continuity in the relay circuit. If the circuit is open, the controller will blink at 4 hz and not power the relay. I do not knpw what the computer display will show (!, hourglass, or Electrical problem?) If the actuator is off, you won't need it anyway, but it avoids putting power on the terminals.
1999 K1200LT HL Basalt Grey/ Fleximum Sidecar
1983 Silverwing 650 leaner/1987 Velorex Sidecar
JWA is offline
post #17 of 25 Old Mar 9th, 2013, 2:27 pm
I don't know what you checked as there is no connection between the relay contacts and the controller. It will not know it isn't connected.
Name:	center stand.JPG
post #18 of 25 Old Mar 11th, 2013, 7:18 pm
JWA
JWA's Avatar
You are right John, I was referring to the EHCS relay circuit which is tested but that is not disconnected when we remove the pump and cylinder under the bike. Thje controller checks that the relay solenoid circuit is closed but has no way to check for the motor itself.
Sorry.
JWA is offline
post #19 of 25 Old Mar 11th, 2013, 7:24 pm
No problem, I was not aware it would fault if the relay coil is open. That is good to know!
I think I may have met the first one I cannot rebuild as it appears the seal on the pump drive gear shaft failed and filled the motor with oil. That wore the brushes into oblivion!
Will have to see if I can source that seal now!
post #20 of 25 Old Mar 11th, 2013, 8:23 pm Thread Starter
smahon's Avatar
PM sent.
'15 GTLE
smahon is offline
post #21 of 25 Old Feb 8th, 2015, 6:09 pm
Re: Rebuilding center stand?
Can someone message me if they're still rebuilding these pistons?
JZeiler... Dan...Bueller?
My piston has been off the bike for months.
If I can't get it rebuilt by someone on here I will get the seals and have my private BMW guy or independent mechanic do it.
Thanks!
MotoBri is offline
post #22 of 25 Old Feb 8th, 2015, 6:36 pm
Sent a PM.
Send it complete if you do.
post #23 of 25 Old Feb 16th, 2015, 3:03 pm
Foiler's Avatar
PM Sent
<center>
<a href="
target="_blank">
<img src="
uuuuuuuuuuuuuuuuuuuuvuuvuuuuuuuuuuuuvuuuuuu" border="0"></img>
<br>Free, personalized travel maps at mytriplogs.com</a>
<br>
</center>
Foiler is offline
post #24 of 25 Old Feb 16th, 2015, 8:12 pm
JamesW's Avatar
Yes Long term...rebuilt the motor including brushes as per Ari's farkels, who is in Finland and is a great person
Thanks Ari
JamesW is offline
post #25 of 25 Old Feb 17th, 2015, 6:09 pm Thread Starter
smahon's Avatar
Thanks Ari
Yes he is. 5 months after starting this thread my wife and I visited with him at his home.
JamesW likes this.
'15 GTLE
smahon is offline
Side & Center Stand Questions tonygret K1200LT 6 Jul 12th, 2008 5:32 pm
Center Stand Failure BMWWANDRR K1200LT 18 Jul 3rd, 2008 2:59 pm
Adding Oil to My Power Center Stand joegottberg K1200LT 19 Mar 28th, 2008 9:51 am
Has anyone replaced the hydraulic center stand for a manual one? DanDiver K1200LT 17 Oct 4th, 2007 10:02 am
2002 Model Center Stand Broke MattKas K1200LT 7 Nov 6th, 2006 12:37 pm
