Brake question - BMW Luxury Touring Community
post #1 of 7 Old Jan 30th, 2013, 8:55 pm Thread Starter
davebullock's Avatar
Brake question
I'm replacing the brake lines (103,000) and having trouble knowing how to remove the line from behind the driver's foot rest. I can work the upper part of the banjo off, but can't figure the way to get a 14 mm wrench on the bolt?
Any help is appreciated
Dave, winter project in WI
davebullock is offline
post #2 of 7 Old Jan 30th, 2013, 9:43 pm
Re: Brake question
You did unbolt the foot rest plate, didn't you? Doing this allows you to unbolt the master cylinder and get access to all the hoses and bolts.
Current:
2006 BMW K1200LT
2010 BMW R1200RT
Previous:
1999 BMW K1200LT
2007 Yamaha FZ6
1986 Suzuki GS550L
1985 Suzuki GS650L
1977 Kawasaki KZ650
1975 Kawasaki F7
1973 Honda CB175
r_figueroa is offline
post #3 of 7 Old Jan 31st, 2013, 9:26 am Thread Starter
Re: Brake question
Got it. I had the plate off, just didn't realize yet even more had to come apart to get the line off! Sent off this morning to HEL USA for new lines
post #4 of 7 Old Jan 31st, 2013, 6:38 pm
Re: Brake question
Hope you took a picture of the hose routing as the reservoir hose does go through some twists to get it all back together.
post #5 of 7 Old Feb 1st, 2013, 8:59 am
Re: Brake question
This attachment may be a picture of the twists John is referring to.
Hopefully the attachment makes it to the post.
Bill Edwards
Boerne, TX
1jusbill1 is online now
post #6 of 7 Old Feb 1st, 2013, 5:06 pm Thread Starter
Re: Brake question
Thanks, I had seen this, but was still sure there was something wrong when I turned the plate over and saw what looked like a tangle there-can't help but think there could have been a better design? The new brake lines should arrive next week,and I may be back for more help. Appreciate the time to send this along.
dave
post #7 of 7 Old Feb 1st, 2013, 7:00 pm
Re: Brake question
The tangle goes away when you rotate the foot plate to install, but if you don't put it in before hand it will be there when you flip it around.
Brake Question jimdeluca RT Series 12 Jan 14th, 2013 10:22 pm
Brake Bleed & Flush Question (not how to do it) blueknightga6 K1200LT 6 Jul 5th, 2012 6:17 pm
Brake flush- newbie question beemer100 K1200LT 19 Apr 13th, 2012 2:31 pm
Brake Fluid Question garyw K1200LT 6 Jan 28th, 2011 12:35 pm
Rear Brake Question BuffaloBSA RT Series 2 Aug 6th, 2006 12:46 pm
