Changing Transmission Fluid - BMW Luxury Touring Community
post #1 of 9 Old Apr 1st, 2006, 5:54 pm Thread Starter
I've been enjoying my '05 LT for about three months and 2000 miles so far. I have been having one hell of a time seeing my oil level through the site glass but I know it was just changed at 1300 miles so I am assuming (stupid) that it is ok since I can't see it. But the transmission fluid is a different matter.
The manual doesn't mention checking the trans fluid. Not a problem right now because I am having it changed at the dealer later this month over to fully synthetic, but what do I do after that? Do I just assume (stupid again) that the level is right or is there a way to KNOW its ok?
Your input is sincerely appreciated as always.
Steve
SMGray is offline
post #2 of 9 Old Apr 1st, 2006, 6:12 pm
grifscoots's Avatar
Just ride it and change it at specified interval. We've been changing our rear end fluid every oil change just to look at the magnet in the hopes of a intervention.
-=grif=-
Grok
grifscoots is offline
post #3 of 9 Old Apr 1st, 2006, 6:13 pm
ErnieA's Avatar
Smile
Steve
First off congratulations of owning such a nice machine. Engines can comsume oil through the cylinders and burn it during cumbustion. This is why it is so important to keep an eye on it. Unlike some motorcycles which combine engine and transmission oil your BMW has a sealed, gear oil specific, transmission. Your transmission churns in its own lube and is happy to just splash around. However, if you see a leak of oil under your said transmission be concerned.
You can pull off your right footpeg plate (carefully tie it up to protect the rear brake mastercylinder and hose) and pull your transmission fill plug. Your tansmission fluid level should be even with the bottom of the fill plug hole (or within a MM or so). IHTH
Ernie A
Milwaukie, OR
2013 R1200GSW
> 28k miles!
ErnieA is offline
post #4 of 9 Old Apr 1st, 2006, 8:11 pm
At least on my 05 I can only see oil in the sight glass on the center stand. If it is on the side stand on level gound I see nothing. Oh and if the transmission starts leaking you will notice it. Just had my rear seal replaced under warranty.
post #5 of 9 Old Apr 1st, 2006, 9:19 pm Thread Starter
Thanks for the help, guys. I appreciate it.
SMGray is offline
post #6 of 9 Old Apr 1st, 2006, 11:59 pm
dmatson's Avatar
On my 05' when I check mine in the morning before a ride with the bike on the center stand, not running, oil is above half way point in the site glass.
14' KTM 1190
03' KTM 450 EXC Dually
72' Honda SL 100
67' Triumph Bonneville
65' Honda CB160
70' Honda CB350
dmatson is offline
post #7 of 9 Old Apr 2nd, 2006, 12:39 am
If you are changing your bike's fluids you will need a 14mm allen wrench. Problem is, there isn't enough room to turn one.
Solution:
- get a 14mm allen wrench (you will probably only find this at a "bolt supply" house
- using a Dremel cutoff wheel, cut about an inch (or 25mm) or so off the long end of the allen
- now, you can put the 14mm allen into a 14mm socket with universal joint you can loosen, remove and reinstall the plug to the correct torque.
- I used a 14mm 12point combo wrench instead of the socket the first time... worked just as well.
Make sure bike is on CS when you check fluids... and please, clean the bike before you begin.
J.M.J...
Dcn Channing
post #8 of 9 Old Apr 2nd, 2006, 1:36 am
Hello Stephen, and welcome to a ride you are sure to enjoy!
You mentioned in your first post that you were switching to synthetic. Were you speaking of the transmission only or also the engine oil?
If you were including engine oil I would urge you to put another zero behind your mileage first-----to make certain that your rings are well seated.
jorawro is offline
post #9 of 9 Old Apr 2nd, 2006, 6:18 pm Thread Starter
Roy,
I'm switching to fully synthetic in the trans and rear drive only. I will probably wait until I reach 15,000 miles and then go fully synthtic in the crankcase also. Probably what you had in mind.
Steve
SMGray is offline
Can't find colored DOT 4 brake fluid Toolman K1200LT 7 Mar 5th, 2006 2:40 pm
Transmission fluid change - what a pain SeaMarshal K1200LT 14 Mar 5th, 2006 9:57 am
Does Old Brake Fluid Smell? Jerrod Maguire K1200LT 7 Dec 13th, 2005 3:00 pm
Changing brake fluid. TRANSMAN K1200LT 3 Oct 5th, 2005 7:34 pm
Brake fluid indicator issues Rich_in_Tampa K1200LT 2 Oct 2nd, 2005 11:30 am
