Muffler Chrome Removal? - BMW Luxury Touring Community
post #1 of 4 Old Mar 31st, 2006, 11:41 pm Thread Starter
kdog's Avatar
Hi y'all. Has anybody had occassion to remove the chrome jacket from an LT muffler? I'm not talking about the heat shield, but rather the chrome sleeve around the muffler. There are two screws that appear to hold it on. I've removed the two screws, but the curved exhaust tip keeps the chrome sleeve from sliding off.
Background for the curious. I have a big rock ding in a header pipe. I have a line on a used LT exhaust, but the chrome is trashed. If I can move my chrome to the used exhaust, I can get out of this cheap.
Any words of wisdom, insults or jibes, would be welcome.
-joel
kdog is offline
post #2 of 4 Old Apr 1st, 2006, 7:50 am
been there - done that.
If memory serves, there's a 'keeper' on the top of the chrome. loosen the rider peg assembly and you'll see it.
The chrome will slide off the end of the exhaust, in spite of the downturn, but it's like removing a tight girdle. If what you want is under the girdle, you'll get it off!
Careful replacing the chrome, it kinda 'snaps' in place, I almost caught a finger under it.
dcwchfc is offline
post #3 of 4 Old Apr 1st, 2006, 10:29 pm Thread Starter
kdog's Avatar
Thanks, Dave. I was hoping somebody out there had done this operation, and that has given me hope. However, perhaps they've changed the design a bit. I'm not sure what you mean by a keeper, but there doesn't appear to be any other fasteners anywhere else on the chrome on this baby, aside from the two screws I mentioned previously. The exhaust system is off the bike too, so I can flip it around any way I want to look at it. You're right -- it's a very tight "girdle" fit. But I can't seem get it to change trajectory at all to clear that downturned exhaust tube. Thanks again for your response.
-joel
kdog is offline
post #4 of 4 Old Apr 3rd, 2006, 12:50 pm Thread Starter
kdog's Avatar
Got it
Just to follow up my own post, in case this info may prove useful to somebody in the future....
I finally got the chrome sleeve off. What did it was to use a dremel tool to grind down the end of the turn-down exhaust tip enough to clear the opening. I took maybe 1/8" off in the areas were it was hanging up.
regards,
-joel
kdog is offline
Running Rich Canistor Removal Motomadman K1200LT 8 Aug 7th, 2006 9:25 pm
Cleaning muffler tip? atps1234 K1200LT 21 Dec 28th, 2005 1:21 am
chrome strips loose on fan vent bikesnumbnuts K1200LT 3 Oct 23rd, 2005 3:28 pm
chrome strips loose bikesnumbnuts K1200LT 5 Oct 2nd, 2005 6:00 pm
