REverse = flakey - BMW Luxury Touring Community
post #1 of 5 Old Mar 30th, 2006, 3:02 pm Thread Starter
drmajor's Avatar
Question REverse = flakey
My reverse is misbehaving.
Works for a second or two then stops.
Release the button and reapply for another round. etc. etc.
I had the dealer check it and they said the white connector was loose.
It is still misbehaving. I had the plastic off and double checked the connector. It's solid.
I don't use it much, but when I need it, it would be nice to not have to play with it every time.
Any suggestions?
David Major
Charleston, SC
-2003 LT
-2007 GS Adventure. White
drmajor is offline
post #2 of 5 Old Mar 30th, 2006, 3:25 pm
Check the archives. Could be many things but seems the common fault is a driveline speed sensor.
humplatch is offline
post #3 of 5 Old Mar 30th, 2006, 8:01 pm
Any suggestions?
David - Toad starting acting up just like your scoot, in reverse --- the dealer's warranty invoice sez: *replace reverser module*.
No problems since, and that wuz 5 years ago. Might have your dealer check his stack of service bulletins; seems there wuz a rash of failing/failed reverse systems sometime ago, butt the failure rate has subsided of late.
post #4 of 5 Old Mar 30th, 2006, 9:53 pm
grunt n' shove it
My 2002 has only 6K and the reverse is wimpy. many times it's easier to grunt n' shove it. sounds like a good porno, "grunt n' shove it." Somehow ... to me using the starter motor to propel an 800+ lb machine is a bad design. The reverse has helped in a couple of tight uphill moves... but mostly the big yellow R on my dash gets lit very little. When i do engage the reverse it seems to surge 3 seconds then pause, then surge again, etc...
KYchris02 is offline
post #5 of 5 Old Mar 30th, 2006, 11:37 pm
BillCav's Avatar
Wonky reverse
My (05) is doing the same thing and has since I got it in March 05. I took it into the shop and they couldn't tell me whether it should go 5 ft or 25 ft. So I did my own research on this site and took printouts of the problems to them. The mechanic has since gone to BMW school in California and found three or four reasons why they don't run continually in reverse, virtually the same things I took him. It goes back in next week to have the problem fixed.
Cheers, Bill
BillCav is offline
BMW LT reverse BillCav K1200LT 25 Mar 16th, 2007 6:37 pm
just a couple of questions; reverse, etc. saileyboy K1200LT 9 Jan 7th, 2006 7:06 pm
LT Reverse distance Hitman_LT K1200LT 10 Dec 30th, 2005 10:39 pm
Where to find hot wire for reverse? pozo_izquierdo K1200LT 10 Nov 25th, 2005 1:48 pm
REverse problem drmajor K1200LT 11 Oct 25th, 2005 4:35 pm
