Wiring question - BMW Luxury Touring Community
post #1 of 6 Old Mar 29th, 2006, 4:26 pm Thread Starter
slugbug's Avatar
Wiring question
I am trying to install a Kisan tailblazer deceleration and running light for the luggage rack brake light onto an 05 LT. It is a plug and play set up but I have to tap into a hot a hot wire also. I'm planning on tapping into the rear lighter plug, but wanted to make sure which wire to tap into. There are several brown wires and several green and purple wires. My question is can I tap into any one of the green/purple wires for a hot source?
Brian
slugbug is offline
post #2 of 6 Old Mar 29th, 2006, 4:28 pm
grifscoots's Avatar
Brown is always ground on our bikes. So, green & poiple will woik.
-=grif=-
Grok
grifscoots is offline
post #3 of 6 Old Mar 29th, 2006, 8:14 pm
Or you can tap into the rear seat warmer hot lead---green wire
Jon Bush
' 09 RT
"SAPHIRE"
bushj1 is offline
post #4 of 6 Old Mar 29th, 2006, 11:58 pm Thread Starter
slugbug's Avatar
Thanks for the help! I tapped into the rear heat (green wire) and I'm still not getting the running/brake light to work properly. Checked fuse to heated seat. it's OK, can't figure out what the problem is!
slugbug is offline
post #5 of 6 Old Mar 30th, 2006, 1:24 am
Use a volt meter and check for 12 VDC. Fuse may be good but other factors are involved. Is the key in the on position, sure you picked the switched hot for the seat, what method did you use to tap the wire (scotchlock, solder, butt splice)? Also, not sure about Kisan's unit but many such accessories are polarity sensitive.
mjordans2000 is offline
post #6 of 6 Old Mar 30th, 2006, 1:40 pm Thread Starter
slugbug's Avatar
I figured it out, I just had a loose connection where the Kisan plugs into the brake light. I feel stupid! Thanks to everyone with the help!!
slugbug is offline
Russell heated seat wiring question. BruceHarrisJr Ergonomics & Rider Comfort 4 Feb 20th, 2006 9:40 pm
Yet another wiring question RaffyK Chit Chat 7 Dec 18th, 2005 11:01 am
HID Wiring Diagram check Dezrae Lighting 8 Nov 4th, 2005 10:59 pm
Hella DE HID lights wiring question YumaLT Lighting 1 Oct 9th, 2005 12:13 am
Starcomm 1 wiring into stock harnes scoobydoo K1200LT 3 Oct 2nd, 2005 12:21 am
