A Wilbers Shock Question - BMW Luxury Touring Community
post #1 of 3 Old Mar 28th, 2006, 11:54 am Thread Starter
I wish to purchase Wilbers Shocks and will be ordering the remote preload adjuster and I am up in the air about the adjustable compression adjuster (high & low speed). Any one out there have a opinion on this--my dealer says the more adjustment you have on a shock the better. The shocks come standard with 22 position rebound adjustment and the high and low speed compression adjustments are supposedly changed when the rebound adjustment is changed.
rattso is offline
post #2 of 3 Old Mar 28th, 2006, 2:27 pm
Ranger6's Avatar
As Klaus at Wilbers USA will tell you, the average rider of an LT only needs the preload adjuster, which mounts right where the stock one does. Thats not to say you couldn't opt for the compression adjuster, but you likely just don't need it. Either way, put 'em on because they're great!
Al Hennigan
'03 Anthracite LTE
'09 GS Adventure
Middle Tennessee
Ranger6 is offline
post #3 of 3 Old Mar 28th, 2006, 3:01 pm
drmajor's Avatar
I have just the Pre-load adjuster and the bike really handles well.
The problem with too many adjustments is if you don't know what to do with them, they can spoil your day. If you know, they can improve the day.
David Major
Charleston, SC
-2003 LT
-2007 GS Adventure. White
drmajor is offline
Wilbers Shocks Questions rattso K1200LT 10 Apr 11th, 2006 10:08 am
Help on custom shock install/trailer RonKMiller K1200LT 11 Feb 23rd, 2006 12:05 pm
changing rear shock, step by step PhillWard Europe 1 Jan 24th, 2006 2:50 am
Replacement of rear shock suspension unit PhillWard Australia, New Zealand, and AsiaPac 3 Jan 17th, 2006 6:01 pm
Rear Shock Refill Motomadman K1200LT 3 Oct 21st, 2005 2:17 am
