09 front shock removal - BMW Luxury Touring Community
post #1 of 15 Old Aug 5th, 2012, 1:50 pm Thread Starter
grassman09's Avatar
I have searched the sight and I can not find picts and or instructions on how to remove / replace front shock.. Ok I have taken off the appropriate tupperware and have located the top nut of the shock. Now the big question is how do I the shock out from the bike. Picts would be great thanks. By the way it is an 09
IBA #34229
09 LT
05 RT 65000 miles sold
2 FD Dead
grassman09 is offline
post #2 of 15 Old Aug 5th, 2012, 3:33 pm
bob1811's Avatar
Re: 09 front shock removal
I assume that you have figured out the strategy for the removal of the top and bottom mounting bolts. You will then need to remove the front wheel (with associated tupperware) and jack up the frame in the front of the bike high enough to allow Paralever to drop down far enough to give you clearance to actually get the shock out mounting area. I was able to get the shock out without removing the wheel (2005 LT), but ended up removing it any way to make the new shock install easier and to avoid damaging an expensive new shock. I'm sorry, but I did not take any pics of the process...but it's fairly straight forward.
2005 Blue K1200LT
2010 R1200GS
BMW/MOA 94539
bob1811 is offline
post #3 of 15 Old Aug 5th, 2012, 3:54 pm
There might be some pics in this thread.
post #4 of 15 Old Aug 5th, 2012, 7:57 pm
If you remove the front wheel and unbolt the brake lines from the sliders you can drop the front down far enough to reach up and remove the rubber donut. Then the shock will go back up in the hole far enough to clear the lower mount. Reinstallation is the reverse put the shock in without the donut and then put in the lower bolt. Reach up and install the donut and then secure the top nut.
post #5 of 15 Old Aug 5th, 2012, 9:16 pm
kevincaron's Avatar
I checked the shop manual and couldn't find shock r&r anywhere in the book?!?!?!
Why am I here and what day is it??
kevincaron is offline
post #6 of 15 Old Aug 5th, 2012, 9:42 pm
... and don't drop the donut when you're reaching up there to put it on the new shock ...
2000 K1200LT - 94,000 mi. (49,000 mine since July 4th weekend, 2009)
BMW MOA 151654
rcoolbaugh is offline
post #7 of 15 Old Aug 5th, 2012, 9:46 pm
Look for "Removing and installing front suspension strut". I have it on page 31.17
BMW MOA 151654
post #8 of 15 Old Aug 5th, 2012, 10:28 pm
kevincaron's Avatar
Oh hell,,,, got it!!!!
Thanks,,,
post #9 of 15 Old Aug 6th, 2012, 10:05 am
I don't like the factory procedure as it has you undo the ball joint on the telelever. Green loctite is not fun to undo.
post #10 of 15 Old Aug 6th, 2012, 7:55 pm
Just need enough thermal persuasion! :-)
Voyager is online now
post #11 of 15 Old Aug 6th, 2012, 9:03 pm
Enjoy The Ride
saddleman's Avatar
That is exactly how I have done the last 20 or so front shock changes.
Dave Selvig
2004 Black LT
2000 Canon Red LT
saddleman is online now
post #12 of 15 Old Aug 6th, 2012, 10:00 pm Thread Starter
grassman09's Avatar
Smile Re: 09 front shock removal
Got the job done thank you for the advise
IBA #34229
09 LT
2 FD Dead
post #13 of 15 Old Aug 7th, 2012, 8:13 pm
Wow, you are rough on front shocks!
post #14 of 15 Old Aug 7th, 2012, 8:23 pm
Enjoy The Ride
saddleman's Avatar
I was told by the shop that rebuilt my Ohlin's (many times)that they have never seen anyone wear out front shocks like I do. What ever that means.
Dave Selvig
2004 Black LT
2000 Canon Red LT
post #15 of 15 Old Aug 7th, 2012, 10:55 pm
It is caused by all the, low speed in 5th gear, driving you do!!!
front cowling removal help itspossible K1200LT 7 Dec 31st, 2008 7:30 pm
front shock spring wt ? STARFIGHTER K1200LT 0 Jul 30th, 2008 8:03 pm
Shock removal hitch c00k1e K1200LT 3 Feb 18th, 2007 1:30 am
Front shock NOGILLS2 K1200LT 6 Apr 13th, 2006 5:27 pm
Front tire removal Q Rondeau K1200LT 11 Oct 7th, 2005 10:22 am
